Question about B&W Bowers and Wilkins Zeppelin iPod Music Speaker System
After plugging in my zeppelin the light flashes red continuously after a pause of ten seconds and the unit does not respond to any command, any ideas?
    Scholar:
  • 159 Answers
The red flashing is a power supply problem, nothing tends to work with this issue.
contact b and w service or point of sale as they should arrange repair as this is a known problem with this product
Posted on Apr 13, 2011
How to go about fixing a code my 89 Dodge D 100 2
By cycling your ignition key 3 times in 5 seconds command codes to be flashed through check engine light key off,on,off,on then watch lamp first series is the ten digit and pause then single digit So a flash flash pause flash flash pause would be code 22 at the end of display is code 55 (end of message).
Aug 31, 2014 | Cars & Trucks
2yr old Pioneer pdp-506 50" panel with seperate receiver unit
YOUR MAIN CONTROLLER IC (processor) is damaged you cant try ressiting it but I'm sure it wont work you need to get it professionally repaird by a qualified technician
Jan 02, 2008 | Televison & Video
Replaced bulb in kdf60wf655, green light flashes for some time ten red light flashes continually
If there is no pause in the flashing sequence then you need to have a servicer look at it. This is a new one for me. To many different things could be wrong with it.
Mar 21, 2013 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony TV model KDL-46Z4100, standby light flashes 14 times, no picture, no sound
14 blinks to Sony Brand LCDs indicates a 'Backend error'. It means that, the main board to this TV should be checked for fault. In most cases the main board might need replacement, and a software update too. If you wish to know more details about this blinking code, check this link. It has details of blinking codes to several brands of TVs including Sony. Actually the work is a skilled one, need experience.
Jan 20, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a Sennheiser MM100 Bluetooth headphones that has stopped responding. It will not turn on/off and the LED light is blinking a continuous blue. How do I get it to function again?
Found this online. Hope it helps you out.
Switching the headset on
To switch the headset on:
Press and hold the Play/Pause button for 2 seconds.
An ascending confirmation beep is heard in the headset and the LED indicates the current operating mode. Flashing in blue indicates that the battery charge status is OK; flashing in red indicates a low
battery (see page 6).
The LED flashes several times every second:
The headset is paired to one or several Bluetooth devices and tries to connect to one of these devices.
The LED flashes slowly (once every second):
The headset is paired to one or several Bluetooth devices. However, there is no current connection because the
Bluetooth device is switched off or out of range.
The LED flashes once every 3 seconds:
The headset is paired to one or several Bluetooth devices. However, there is neither an audio transmission nor an active call.
The LED is glowing slowly every 4 seconds:
The headset is paired to one or several Bluetooth devices, a sound file is received via A2DP and played back or
paused.
The LED flashes once every second:
The headset is paired to one or several Bluetooth devices and there is currently an active call.
If you switch on the headset and keep the Play/Pause button pressed for 5 seconds, the headset will go into pairing mode (see ?Pairing the headset? on page 9).
The LED flashes alternatingly in red and blue for up to 60 seconds:
The headset is not yet paired to any Bluetooth device. Pair it as described under ?Pairing the headset? on page 9.
Oct 31, 2012 | Audio Players & Recorders
Whenever docked with ipod, the steady blue light on Zeppelin switched to the troublesome blinking red light. Does tis mean someting wrong with the contact/dock on zeppelin? How can we solve this problem?...
the red flashing light refers to the power supply board, either contact b and w service or point of sale to arrange return and repair. there is a mod for these power supply unit!
once this has been fixed they should check to make sure there are no other problems before returning, hope this helps.
Dec 26, 2010 | B&W Bowers and Wilkins Zeppelin iPod Music...
The zeppelin no longer plays 2 ipods, it flashes a blue light when pressing play but no music.
the flashing blue light normally indicates the ipod is on pause. if the unit is not on pause, the problem could be the arm or the interface board, they power suppy could also be the old type, so suggest you contact b and w service if you have not already. (if there is an issue, ask them if your serial number has the updated or the problematic power supply unit!)
Sep 18, 2010 | B&W Bowers and Wilkins Zeppelin iPod Music...
When playing music from my ipod on zeppelin during song there is a sudden pause for 2 or 3 seconds then song continues but much louder than before.
if it is jumping, then report to b and w. I believe they do not know the cause and more than likely replace the unit if they cannot fix. make sure you you make them aware of the jumping in output.
Jul 11, 2010 | B&W Bowers and Wilkins Zeppelin iPod Music...
B&W Bowers and Wilkins Zeppelin iPod Music Speaker System  Logo
222 people viewed this question
Top B&W Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Are you a B&W Audio Player and Recorder Expert? Answer questions, earn points and help others
