Question about Acer TRAVELMATE 8371-944G25 LAPTOP LCD SCREEN 13.3" WXGA HD LED DIODE (SUBSTITUTE REPLACEMENT LCD SC...
Hi I'm using an Acer TravelMate 8371. Its LCD screen backlights have recently malfunctioned, where I can tell 3 out of the 4 light "balls" which are located at the bottom of the screen are dead, leave only the right one are giving light to read the screen. How can I fix it? Jonathan
usuallyno
  • 13 Answers
SOURCE: acer travelmate 4000 laptop Big problem
I guess I can assume that you have it plugged into the ac power, so you know its not a power problem. We also know its not a problem with the power switch since the light turns on. So that leaves, motherboard, cpu, and ram possible problems. Ram would unlikely cause such a hault. Even with no ram, I believe the computer would make horrible beeping noises. So if its a problem with the motherboard or cpu, its pretty much trash, unless you want to waste the money on ebay or some place for another cpu to try to swap.
Posted on Aug 23, 2007
SOURCE: acer travelmate 2303lc done recovery since then no display on screen
Hi
My cd rom does not seem to be working at all. Lights come on and I can hear how it is reading a disc but when i go into the d drive its just blank. Haven't been using the pc for a while so i dont have the recovery cd anymore? Please help?
Many thanks
Posted on Nov 12, 2008
deanam
  • 15 Answers
SOURCE: Backlight flickering
Matrix. Backlight lamp is flicking, you shoud change the matrix. If it is in guarantee, that is not you priblem, but if it is not..... the cheapest way is to find someone to chenge just the lamp. if you can
Posted on Apr 28, 2009
  • 85 Answers
SOURCE: Acer TravelMate 230LC PC Notebook, lcd screen does nothing just b
Shine a flashlight at the screen, if you can faintly see the image then your backlight has failed and you will have to contact acer to have it replaced.
Posted on Oct 04, 2009
  • 20 Answers
SOURCE: Acer Travelmate 2410 lcd inverter connector
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
jakauiay46
Posted on Jan 03, 2010
Biometric fingerprint scanner acer
That is because it has not been removed from User Accounts.
Dec 29, 2013 | Acer TravelMate 8371 Timeline (LXTTD03077)...
I have an acer 8371 not charging
it sounds like one of three things:
1. Battery itself no longer functions
2. Laptop Charger has inadequate amperage
3. The motherboard is defective (most likely).
If you have another battery, or a friend with the same battery, you can try that first (and someone else's laptop charger).
If the problem is the motherboard, you can try to have it repaired but I don't trust many companies to do this kind of work. I outsource my motherboard jobs to a company called Laptop Rescue (http://www.laptoprescue.com/laptop-repair-2/). Coincidentally, they also sell laptop chargers in case that's the problem. Hopefully it's just a charger or battery issue and not a motherboard.
If you can confirm your laptop charger is dead, just purchase a new one:
Replacement Acer TravelMate 8371 AC Adapter 65Watt 19V 3.42A
Oct 26, 2012 | Acer TravelMate 8371 Timeline (LXTTD03077)...
My Acer 8371 won't charge battery. Most proppably problem in the 8371 end rather than in battery. Pinout for battery connector for checking the voltages ? br, Pekka
i am having the same issue on my travelmate8371
it is definitely the laptop itself with the issue as i have my old battery and a brand new one, i have used the old battery much and used the spare one from time to time.
my laptop randomly shutdown and cannot recognize that there is a battery in it
being years after getting it through my highschool i must wonder if it an issue fixable today
Aug 09, 2012 | Acer TravelMate 8371 Timeline (LXTTD03077)...
My screen intermittently goes blank (without lighting). I can see that there is something displayed and a connection to an external monitor shows that everything is working fine. I've disassembled the...
I've seen this problem time and time again. Replacing the inverter fixed it every time. HOWEVER it could always be the CCFL backlight as well. Both fortunately are VERY inexpensive. Changing the inverter is easy but the CCFL will be a little harder. Take your time and remember how to put it all back together and you'll save that $100. I'm sure it's either of those two that's causing the backlight issues. NO NEED to change the entire LCD.
Aug 22, 2011 | Acer TRAVELMATE 8371-944G25 LAPTOP LCD...
Cant use f10 button when i press alt f10 on my acer 8371
Please tell me what you are trying to do when pressing the F10 button on you laptop. What problem are you having with the laptop?
I will watch for your reply.
Brian
Feb 05, 2011 | Acer TravelMate 8371 Timeline (LXTTD03077)...
Acer TravelMate 230LC PC Notebook, lcd screen does nothing just black the power light comes on thats it what could it be
Oct 04, 2009 | Acer TravelMate 2300 Notebook
ACER 4100 TRAVELMATE
If this happened suddenly, the backlight power supply (inverter)  has probably failed. It could be the backlight itself but they normally will dim or flicker before they die.
Try shining a light at an angle on the display with the computer turned on and look at it from an angle too. You may be able to see video very faintly; if you do, then it is as described above; a backlight problem, not the LCD display itself.
Jan 22, 2009 | Acer TravelMate 4100 Notebook
Backlight faliure
Its a florescent backlight and is an integral part of the LCD screen.
You need to replace the entore screen, not just the backlight.
I hate to tell you this, but unless you can find a screen on E-bay or similar site it is going to cost you almost as much as a new computer.
You can buy a used travelmate 240 for around $200 and drop yyour hard drive into it and be up and running as before in a matter of minutes. Then you may be able to sell the old one as a working base with a bad screen to recoup some of what you paid out.
Good luck.
Jan 01, 2008 | Acer TravelMate 240 Notebook
Acer TRAVELMATE 8371-944G25 LAPTOP LCD SCREEN 13.3" WXGA HD LED DIODE (SUBSTITUTE REPLACEMENT LCD SC... Logo
178 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
