Question about ViewSonic VG2021m LCD Monitor
This viewsonic has a unique problem: when powered up, it enters the screen brightness dialog and rapidly cycles between selecting bright/contrast submenus, circa 4 cycles per second. Unresponsive to any controls, and rebooting it has no effect. The rest of the screen will respond to software operation. Sounds like a logic board problem to me? Or a broken microswitch, even though it feels like it is working properly..
  • bkr2c Apr 04, 2011
    Thanks! I have repaired other LCDs before for bad caps, so will give this one a try.
  • 11,361 Answers
You may have unstable DC due to bad caps as shown in my pictures here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VG2021/?action=view&current=DNS2197.jpg
Which can cause a lot of strange symptom.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Apr 02, 2011
Why can't I control the brightness or contrast on my Viewsonic monitor?
Look to see if there is an "auto" setting, this would override the manual settings.
Apr 03, 2015 | ViewSonic Computers & Internet
The Bright/Contrast window, controlled from the monitor itself, keeps popping up. The select pane continues to switch between the Bright selection and the Contrast selection. When it finally stops...
Sounds like your monitor is going bad. You might get some more use out of it if you power it off for a couple hours and try again but my guess is this is a heat-related failure that is common on ViewSonic monitors.
Jun 30, 2017 | ViewSonic Vx2250wmled LCD Monitor
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
Feb 04, 2011 | Televison & Video
How do I adjust lamp brightnesss for a Viewsonic PJ550 LCD projector?
hi,
may be ur projector lamps reflector may be faulty. when it comes to the end of its life. the coting inside th reflector will get bubbled and it will peeled of. that's why the light is very low. u can't increase the brightness of lamp. because it is connected to a well regulated power supply. and the supply voltage is as per the specifications of the lamp. you can adjust the brightness through menu. for that press MENU button and selects PICTURE 1 using down arrow and then press ENTER. select BRIGHTNESS and press ENTER. using up and down arrow adjust the brightness. if still not get the desired brightness lamp should replaced.
ok
Dec 15, 2010 | ViewSonic PJ550 Multimedia Projector
Need to reduce the brightness on the screen. I
You can down load user manual and read the instruction on how to adjust the monitor.
http://www.viewsonic.com/assets/027/7939.pdf
May 12, 2010 | ViewSonic VA1930WM LCD Monitor
Brightness/contrast
You can try both of this steps:
1. Press and hold the Fn key and press either arrow up or down to increase or decrease the brightness.
2. Restart the computer and tap F2 key 5-10 times during the dell logo splash screen to go to BIOS information. select video by pressing the arrow down key, then press enter. select either Brightness or Brighness AC then press enter, then select the brightness that you desired.
Apr 06, 2010 | Dell XPS M1710 Notebook
Brightness and contrast decreased automatically
check that you were not running any programs that you have allowed to automatically change settings, enter control panel and set settings to allow manual changes only!
Sep 04, 2009 | ViewSonic E70f (White) 17 in.CRT...
Always seen brightness and contrast not exit
try turning it on and off, wait a few hours then turn it back on. it that dont work, turn it off then leave it till the next day then try. it should work.
Jul 28, 2009 | ViewSonic E70f 17" CRT Monitor
ViewSonic E70fB Brightness & Contrast problem
Sounds like the buttons or the button panel are messed up. Or it has gotten moisture in it.
The only time i have seen this was when one of the buttons were malfunctioning, and we ended up replacing the monitor.
Oct 03, 2017 | ViewSonic E70fb 17" CRT Monitor
Viewsonic VG2021m contrast/brightness menu won't go away
I had same problem. The solution I got was to unplug power cord, and hold down each switch on monitor for 30 secs and switch on. IT WORKED! Hope it helps you too.,
Fred
Apr 12, 2009 | ViewSonic Graphic VG2021m LCD Monitor
ViewSonic VG2021m LCD Monitor Logo
360 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
