Question about GE GSS25SGRSS Side by Side Refrigerator
GE side by side refrigerator is having a problem with the freezer. the ice cube dispenser is frosting up and ice cubes are backing up and not coming our properly
  • GE Master
  • 8,220 Answers
Well if the ice cubes are sticking together then the water valve is dripping like a faucet. Replace it.
Posted on Apr 02, 2011
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: Model PSC23MGMA BB GE side
Hi and welcome to FixYa, I am Kelly.
I think that the door flapper spring is broken or disconnected: PN WR02X10585
http://www.repairclinic.com/GE-Refrigerator-Model-PSC23MGMABB-ID-617640-Spring-Parts
It is item 63 of the below link BUT, it not listed in the below link so see above for ordering:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=219346
If there is a problem with the solenoid item 36 above, it can also cause the frosting problem:
Sears parts direct also has parts for this unit here:
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-PSC23MGMABB/0432/0165000/G0104039/00001?blt=06&prst=&shdMod=
I am sending this now and will look uo the crushed Ice problem and respond again soon,
Thanks for choosing FixYa,
Kelly
Posted on Jul 29, 2011
GSH22SXA & several problems
For some reason my post has disappeared. I left you with a lot of information and now All I have is a clarification request. Something is going on with the server here today.Sea Breeze
Oct 03, 2009 | GE GSS25JFM Side by Side Refrigerator
GE GSS25 continuely has frost on cube chute preventin cubes from discharging. Have had doors replaced under recall but problem came back.
I had the exact same problem. My neighbor has the same refrigerator, and told me that there is a solenoid in the door, behind the panel where you select between water, crushed or cubed ice. You can carefully remove that panel to expose the solenoid, which is on the right side of the dispenser water line. I have the model GE GSS25. The plunger on the solenoid gets rusty buildup on the outside of it from the moisture and water splashing from the dispenser. You might try wiping the exterior of the solenoid, and working it up and down so that it moves freely. If not, it's a cheap replacement part you can order from GE. The solenoid shuts the trap door which opens when you get ice from the dispenser. If the solenoid plunger does not move freely, then the trap door hangs open, and warm moist air enters the freezer through the ice shute, causing frost.
Sep 16, 2009 | GE GSS25JEMWW Side by Side
ICEMAKER FROSTING UP
Try to take some ice from the dispenser. Remove the glass and open the freezer door to look down inside the dispenser chute and see if the trap door has re-closed. If it remains open warm, humid air will enter the ice bucket and gradually freeze the cubes together. Trap door remaining open is generally caused by a rusted electrical coil which pulls the door open electrically then sticks, unable to re-close. Coil is located behind the panel that operates the dispenser. Relatively easily accessible.
Jul 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by Side only dispenses crushed ice
remove the ice cube tray assy, remove all the ice, save the cubes, wash the assy with warm water dry the assy, be sure the lever in the rear of this ice cube assy is moving and spring loaded, move the lever and it should snap back and return if so you know the unit is ok(the cube assy), now with the assy still out of the freezer close the freezer door and select crushed ice and push the pad where the glass normally hit to activate the ice cubes,if the operates and you here a thump and snap and hum most likely your ok,if not you could have a defective auger motor assy,but if you here all the sounds as decribed oped the freezer door and select cubed ice push actuator on despensor door with the freezer door closed, reopen and install the ice cube assy tray bucket assy,push it in firmley, and try it with some ice in the bucket you should be fine,if not replace auger motor assy..
nbcrca:)
Apr 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Feb 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Freezer wont stop running
check that the dispenser flap is sealing properly as an air leak here will produce frosty snow
Aug 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Cube dispenser does not work...
Is the ice in the bucket all frozen together as one big lump ??
Aug 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Freezer Side Ice Dispenser
It isn't supposed to free wheel and the only solution that I know of is tumbler replacement. I have the same issue and am currently hunting replacement parts.
Jun 16, 2008 | Refrigerators
Freezer/water not coming out
An Ice/thick frost build up on the back wall of the freezer if a side by side .The tank will be behind the crisper drawers you will see it frozen block of ice verses water in it you can tap it to see if the water moves.. Your water inlet valve on the disp. side maybe bad as well. Is the refrig section cooling ok??
Feb 11, 2008 | GE GSS20IEM Side by Side Refrigerator
GE GSS25SGRSS Side by Side Refrigerator Logo
203 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
