Question about Whirlpool Washing Machines
My whirlpool front loader AWM 285-800 just stopped mid cycle last week. now it still has water in it and no matter which cycle i turn it to (even just to "drain") it spins for about 2 seconds and then just clicks through the numbers to the end of the cycle without actually doing anything. Also when i took my clothes out they had black marks like an oil leak. Does anyone know what the problem might be and how i might fix it/which part to source? Thanks,
  • 3 Answers
SOURCE: I have a whirlpool front
Probably needs a new "mother board." I've had to replace mine 3 times. It's expensive too.
Posted on Dec 28, 2008
  • 220 Answers
SOURCE: AWM 8143 front loader- rubber door needs to be replaced
Yes,it is called a bellow.If the tear is small enough and just on the front rim of the seal try gluing it with super glue,it will get you by till you can get it replaced.
Posted on Sep 07, 2009
Testimonial: "Thank you so much!!! :)"
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Top Loader Stopped working mid-cycle & rattling
It sounds like you have a broken motor coupling. If you manually advance the dial does it drain? The washer is a direct drive model that uses an electric drive motor to run the gearcase (transmission) and the drain pump. Even with the coupler broken (and worse-case scenario - the gearcase) the washer will still drain due to the way it is designed.
If the washer will fill and drain, but won't agitate or spin, this is usually a sign that the motor coupling has broken. The noise of the motor engaging, rattling noises, lack of agitation and ability to still drain are other common symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
If you confirmed that the washer will not drain, you could have a pump that has something caught in it. The drain on these washers on have one moving part - the impeller. If something gets caught in it, the pump will not drain. You can access the pump by following this link:
http://www.fixya.com/support/r397094-replacing_water_pump
Use the steps in the link provided to access the drain pump and remove the hoses to check inside the pump for any foreign objects (underwires from bras, undergarments and panty hose are common items). If the wash tub is still full of water an easy way to drain it with no mess is to use a wet/dry shop vac to pull the water from the tub. Simple gravity works too by removing one of the drain hoses, but is not recommended if the washer is in your home. These wash tubs have a 35 gallon capacity. If you have no shop vac and cannot risk allowing the washer to drain by pulling one of the drain hoses, you need to bail.
If the pump is defective, the part number is 3363892 and can be purchased at appliancepartspros.com for about $42.
If you have questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Sep 14, 2009
Testimonial: "Thanks! No it will not drain either. It just stopped when it hit the drain for the rinse cycle & started that terrible noise. "
Hit it again
  • 13 Answers
SOURCE: Whirlpool AWM 6100/s - stopping
Yeah. This is a pump problem. Our machine first did this about 3 months ago. I took the filter plug out and removed about 10 coins from around the pump impeller area! I removed the pump and dismantled it. Unfortunately water was getting in past the seal on the pump spindle. I cleaned it all out and reassembled it. Worked fine till a couple of weeks ago. It has worn out the spindle "bearings" and because of the loose play it gets stuck, intermittently. If you are by the machine when the drain cycle starts , you can give the filter housing a few bangs(take off the circular cover) . The pump will start up .It makes a grumbly sound, as it is knackered. But once started will generally keep going.The answer however is a new pump. And probably a pact with everyone in your household to be more careful not to leave stuff in the clothes you put in the machine. Our washer has got through 2 mobile phones. a packet of bradding nails, a lot of cash, both coins and notes.Various other stuff that i wont mention! The pump gets very hot when it is trying to turn but cant because of debris on the impeller. This will lead to the pump failing after a time.
Posted on Jan 27, 2010
  • 56 Answers
SOURCE: Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Posted on Feb 11, 2010
We have whirlpool awm 029, that keeps stopping mid cycle, will restart when turn on / off switch
No cold water will stop it b4 rinse change water valve or turn cold water on all the way
Nov 20, 2016 | Whirlpool Washing Machines
I have a whirlpool awm 8121 6th sense front loader. when i select the cycle, usually rapid, and press the start button the machine commences to fill with water. when it comes time for the actual washing...
If your machine is reasonably old, perhaps take a look at the bushes of the motor . Before that, take the manual and run the test cycles by following the instructions; it might provide you with answers
Oct 14, 2017 | Whirlpool AWM8123 Front Load Washer
Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Leaking water from a whirlpool AWM - 293 front loader
I too have this model machine. The leak in my case traced to the fill up hose that attaches to the drum. The seal at this point seems to be a weak point and requires either a replacement that will only last another couple of years or you could try what I did.
I removed the rubber hose from the drum. Dried and cleaned it thoroughly. placed a fair bit of sealant (silcone) on both parts and reassembled and let sit for a couple of days till it cured. This will need to be redone in about 3 years (that is my average- have owned it for 10years).
Jul 26, 2009 | Whirlpool Washing Machines
Rotating programme unit stops mid cycle, all programmes
according to that i think the problem come from timer after you fix this problem pleas donot select your program during conncting electrical power thankyou
May 27, 2009 | Whirlpool AWM5145/2 Front Load Washer
Washing cycle starts and takes hours even for short cycle.
Try checking for good water supply.
Pull out detergent tray and check for good water supply during filling.
if poor filling-
Try checking the hoses.
Turn taps off, disconnect from machine, place hose end in sink, turn tap on and check for good water flow.
if the hose has a red indicator in the side of the hose (end which is fitted to the tap) - Red indicator is a failed hose.(for models with Water Stop hose type "B")
Oct 05, 2008 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
85 people viewed this question
Dan Webster
Dan Webster
Sal De
