Question about Suzuki 25Note Chromatic Tone Chime Set
E5 flat and off pitch - Suzuki 25Note Chromatic Tone Chime Set
  • Suzuki Master
  • 5,603 Answers
Inspect for damage, especially hairline cracks. Also inspect for contamination or dirt that will change the resonant frequency. AND VERIFY the tuner you are using is accurate. Do not compare to a piano which MAY be out of tune... in fact, pianos are STRETCH tuned, that is the higher notes are SHARPED and the LOW notes are FLATTED deliberately. Comparing your chimes to a piano, the E5 would appear flat. Use a good electronic tuner to verify the pitch, not a piano,
Posted on Apr 02, 2011
After few years of use, some pitches (not all) in stromplate are flat.
You should contact them directly. Here's a link to the information
Jun 11, 2015 | Suzuki QChord
Pitch bend issues
Hi, try to find how to reset it or go to default mode,find out in the users manual.Hope it will solve your problem,
Oct 17, 2017 | Akai Ewi4000s Electronic Wind Instrument
I need to know how to raise and lower the pitch
In principle, the primary oscillator needs to be adjusted- some keyboards have a pitch or bend control that if not set correctly, it will affect the tone of the entire piano.
Apr 05, 2012 | Music
G5 is flat. How can I bring it up to pitch?
Is your question about G5 ppc mac. or about Suzuki g5 motor cycle.-------------I assume its about g5 ppc mac.-------
Try downloaded the latest version 2.5.1 to update the 2.2 version;.---------- 1) Open Finder and go to the Macintosh HD -> Library -> Receipts folder. In here you'll see the Pitch 'n Time Pro 2.5.1 Installer.pkg file - delete this.
2) Go to the Macintosh HD -> Library -> Application Support -> Digidesign -> Plug-Ins folder. In here you'll see the Pitch 'n Time Pro.dpm file - delete this.
3) Run the Pitch 'n Time Pro installer again.
----------------- If there is no installer.pkg. File.Then However,you will see these other two files as follows :---Pitch 'n Time Manual.pkg-------
Pitch 'n Time PlugIn.pkg--------
Delete this files.-------- Then try installing latest version and see.--------- ------------- Check out, keep updated, thanks.Helpmech.
Jul 31, 2011 | Suzuki 25Note Chromatic Tone Chime Set
Pitch bender failure.
That is NOT a very descriptive problem statement... If all notes are off pitch but the bender still varies the tone, read about "transpose" in your user manual. Often the transpose or even the A440 setting gets changed and synth will be off pitch. If the pitch bender causes NO change then the control may have a failure.
May 13, 2011 | Korg Pa2X Pro Synthesizer
E5 tone chime out of tune. Sounds flat. Have replaced the head and this has not solved the problem
Forgot to mention... the clapper has almost nothing to do with the tone.
Apr 20, 2011 | Suzuki Music
Tone chime E5 is out of tune and sounds flat. Have replaced the head and this did not solve the problem. What else do I need to do?
"sounds flat" ... What are you comparing this to? Pianos at that range are sharped due to stretch tuning so this would appear flat compared to the piano. Use a Korg or other brand tuner to verify. If it is flat, my educated guess is there is a crack in it. Dip it in a vegetable dye water mixture and usually cracks will show up. This is almost like Magnafluxing they use in the aircraft industry. These are likely made of aluminum and repair if cracked would be hard... one could try to have it welded and then filed down to tune it. I have done this with sleigh bells on a pipe organ, but those were brass.
Apr 20, 2011 | Suzuki 25Note Chromatic Tone Chime Set
I have a Suzuki tone chime C6 that is flat sounding. Is there any way that this can be fixed?
First inspect for mechanical damage such as cracks or dents. Do not confuse "flat" as off pitch with "dead" sound...
Get an electronic tuner and verify pitch before going further. If there is a crack, depending on the material it might be repairable. It is UNLIKELY that the pitch would be very far off as these are mechanical type resonators due to manufacturing defect. Also look for problem with the clapper...
Nov 24, 2010 | Suzuki 25Note Chromatic Tone Chime Set
I have several Kratt F to F pitch pipes that are out of tune in one or more notes. Can they be fixed. or can the tuning plate inside be replaced.
First try cleaning them. If there is contamination on the reeds it will lower the pitch. Clean the plate with 99% isoprophyl alcholol. Do not use chemicals such as brasso as they will etch the plate and change the pitch.
Aug 08, 2010 | Kratt Mk2 Chromatic Pitch Pipe (C To C)
Larry adler hohner chromatic 12 harmonica needs re tuning or new reedplates, any advice welcome.
Probably just needs cleaning. Search google for cleaning instructions. Dirt or deposits on the reeds increases the mass and will cause them to go flat in pitch.
Mar 21, 2010 | Hohner Super Chromonica Chromatic...
Suzuki 25Note Chromatic Tone Chime Set Logo
423 people viewed this question
Top Suzuki Music Experts
Michial Gueffroy
Are you a Suzuki Music Expert? Answer questions, earn points and help others
