Question about KWorld PC to TV (0872880887527) Video Capture
My picture is fuzzy from toshiba netbook to tv. Any ideas?
  • KWorld Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
also
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Posted on Apr 02, 2011
I have a Toshiba 51H83 projection tv that has the picture intermittently going fuzzy and waved. What would be causing this. The set is 11 years old.
This may be due to the surface mount capacitors in the Picture in Picture module. They tend to dry out and cause this problem. Very repairable if the picture is fine otherwise. Talk to a local repair shop.
Dec 25, 2014 | Toshiba Televison & Video
Fuzzy picture wen connecting macbook to tv
Sounds like bad Earths to me... Is it better if it is OFF, the AC/DC power supply? If so then yes, bad earthing between units and earth.
Feb 03, 2010 | Televison & Video
Fuzzy picture and dark picture and color seperation when hot.
The colors seperating is a convergence problem, as far as being dim this may be related but the TV likely needs service adjustments.
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 05, 2009 | Toshiba TP55H60 55" Rear Projection...
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
Toshiba 32" tv wont give sharp picture (other tv does)
try to replace filter capacitor from power supply and in horizontal section.
Jan 26, 2009 | Toshiba 36A50 36" TV
Toshiba CX36H60 Cold start woes
check the capacitor in the SMPS and around Mr. Flyback
Nov 13, 2008 | Toshiba CX36H60 TV
Toshiba 32A33 32" TV
Hi and thanks for responding!
Purchased, March '04.
May 02, 2008 | Toshiba 32A33 32" TV
Fuzzy Picture when souce is not HD
sounds like you may have a problem with the digital scan card or next hyper module. i suggest calling your neighborhood tv repairman
Mar 30, 2008 | Toshiba 65HDX82 65" Rear Projection...
Fuzzy picture
does it look like this set?
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 11, 2007 | Toshiba 51H84 51" Rear Projection...
KWorld PC to TV (0872880887527) Video Capture Logo
94 people viewed this question
Top KWorld Televison & Video Experts
kenwal
Level 1 Expert
Oluwadamilola Adu
Oluwadamilola Adu
Are you a KWorld Televison and Video Expert? Answer questions, earn points and help others
