Question about Watches
The battery is dead and I am trying to figure out how to get to the battery
Hello i have replaced the battery on my tissot t touch expert & display not working? Any suggestions. Battery was completely dead before change?
If the battery was dead too long the fumes from the battery might have damage the electronics and that's not good it will have to go back to tissot for a new movement What I'm going to tell u is very inportant. Never let a watch set dead I don't care if it's a windup or an automatic or even a battery watch. U must always keep the running because all the lubriactions will set up and not performed properly. Just like a car setting dead too kind In ur case the battery has cause the problem
Apr 22, 2017 | Tissot Watches
Danbury clock 'things remembered'. How do I access the battery? I cannot figure out how to find the battery. The battery is dead after two years and I need to replace it. It is not obvious how to...
The things remembered clock is just tension fit in the housing. Easiest way to get it out is to get a plastic suction cup. Press the suction cup onto the face of the clock and pull and jiggle till the clock comes out. This way you wont gouge up the wood trying to pry the clock out with a screwdriver. It takes an N cell battery: https://en.wikipedia.org/wiki/N_battery
Jan 31, 2014 | Watches
I just replaced the battery on my Timex WR100 watch, but can't seem to reset it correctly. There is a sticker on the original battery "AFTER BATTERY INSERTION SHORT AC PAD AND BATTERY (+) TO...
It sounds like you're not far off. Peel the sticker back a little, and see if there is a small contact point (usually yellow metal) - this should be marked 'AC'. Short this to the + for 3 seconds, then repeat for good measure. If that doesn't sort it, try taking the battery out, wait about 30 seconds then put it back in and reset if necessary. If there's still no display, obtain a known working battery and try again.
If you still have no display, it's time to give up and admit it's dead.... unless you've been using a plastic coated paper clip.
Good luck.
May 19, 2017 | Timex Watches
Replaced dead battery on casio watch wr50m, can't figure out how to restart it
Thank you for contacting FixYa.
Take off white plastic cover so that the only metal cover is seen
2) Notice in upper right corner there is a "golden" pad - tiny one and in the metal cover there is an engraving AC. Use some needle like (conducting) object and connect this pin to metal cover (ground) - this will reset your watch.
Best Regards. Jewel
Sep 02, 2010 | Casio Watches
There is no display on the watch at all, like the battery is dead but it is less than a year old. Is there some combination of buttons to push?
mcdevito75 here, Sorry, but a watch battery that is less than 1 year old can still be weak or dead, You have to try a new battery first. Battery could have gotton loose, or have dirty contacts. Look for a small watch repair shop in your area. It"s possible you shut the watch off also, Press and hold the MODE button 2-3 seconds see if the display comes back.
Jul 19, 2010 | Timex Ironman 30 Lap 53952 Wrist Watch
Battery change Citizen Promaster Watch Model# C112.
mcdevito75 here, You should be able to get some help online at citizenwatchserv.com in the meantime you can try to press and hold in the MODE button, press and hold it in for a couple of seconds. Also< IO wouldn"t be surprised if the battery has to come out and installed again, same new battery just simply have it taken out and put back in, maybe some sort of re-set. Check out the website, don"t do anything till then.
Jul 18, 2010 | Citizen Watches
I am trying to figure out how to change the background of this watch. It says just push the button but when i do nothing happens. Anything i haven't been doing correctly
Not knowing what watch you have, most likely the battery for the background is dead. Most of these type of watches have two batteries. One for the actual watch and another for the background. Take your watch to a watchmaker and they can properly change the battery or diagnose what is wrong. if the battery is not the issue.
Hope this helps.
Ken
Yellowstone Watch, Inc.
www.yellowstonewatch.com
May 20, 2010 | Watches
Watch not working
Synchronization of the chronograph hand do not affect any watch movement to work properly and it is ment for correct time measuring only.
If your watch does not work properly there is some kind of fault in it and you will need to see a watchmaker to diagnoze it.
Feb 15, 2009 | Cartier Roadster W62019X6 Wrist Watch
Watches Logo
16 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
