Question about Samsung Washing Machines
Washing machine is connected with water intake, but when i start the machine, no water is drawn into the machine
  • Samsung Master
  • 43,501 Answers
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Apr 02, 2011
Water comes in on rinse mode but not on any wash mode
that's the water solenoid fill valve, in the wash cycle the fill water is selected to flow through the detergent drawer, (so the detergent is drawn in) if the solenoid is broken it only works for some parts of the cycle (like your issue).
I've had this issue on my own machine, and fixed it myself. it should be as easy as removing a couple of screws to remove the top plate on the machine, then the solenoid is right on top, at the rear of the machine (behind the detergent drawer) just undo some hose clamps and a couple of spade connected or clip connected wires (that drive the solenoid) and replace with a new module.
as i don't know the model I cannot specify the replacement part
Jan 28, 2016 | Washing Machines
How to drain water from my lg WFT75A31EP washing machine after washing the clothes?
If the drain pump is faulty and you are unable to pump the water out of the tub, simply take the drain hose and lower it into a container to catch the water which will be drawn out by gravity.
If this fails, check the drain hose for foreign materials clogging it.
Nov 16, 2015 | LG Washing Machines
My machine will not take the conditioner into the wash
in this case, do the following test. Since the machine starts to fill water a little pull out dispenser drawer and make sure water intake to softener compartment. There is possible 2 failures. First, clogged the holes for intake water above softener compartment and water doesn't intake to softener compartment. Second, faulty water dispenser so water intake to the pre-wash or wash compartment.
Dado
Oct 06, 2014 | Zanussi Washing Machines
When I press the button to start the dryer, the water intake starts. The unit is a stacked combo washer dryer. When plugged in and set to wash no water comes in. Only when the dryer button is pressed does...
Hello Julien, thank you for your inquiry!
Based on the symptoms you are describing it sounds like your laundry center is experiencing an issue with the power supply. Either the power supply is not connected correctly or it's an internal power supply issue within the unit. Regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website.
Oct 19, 2013 | Frigidaire FEX831CS Top Load Stacked...
Samsung Washing Machine WA80v3 not working properly
Did the water start without you setting the cycle?
Nov 28, 2012 | Washing Machines
My WMS38 Hotpoint washing machine has the wash, rinse and spin and final spin lights on but nothing happens when the start button is pressed
Assuming tap water is turned on. If there is no water intake, the machine will not start. Check for the sound of water pouring in the machine. Check the water inlet filter, if it is jammed with foreign materials such as rust deposits, small stones, soil etc. Then check for the proper functioning of inlet water solenoid valve. Sometimes the valve gets stuck.
Nov 25, 2011 | Hotpoint Washing Machines
After about 10 mins error code H2O is displayed.
the h2o message means the machine isn't getting enough water. check pressure and water intake pipe.
Mar 15, 2009 | Washing Machines
Asko Quattro 6661 water inlet fault
I had the same problem with my unit. The manual tells you to disconnect the water intake at the machine and clean the screen. This wasn't my problem because as you said the problem doesn't occur until the Rinse cycle which means there is water supply to start the Wash cycle.
From the back of the unit, remove the three screws and take of the lid. You'll notice that there are three separate motors do pump water inside the machine at the water intake. When standing in front of the machine, the motor on the right controls the rinse cycle. I connected an AC volt meter to that pump and started the rinse cycle. 240v showed up at the pump, but the water flow was poor. I simply squished up and down the rubber hose connecting this motor to the detergent unit and was unable to free the clog and water began to flow.
Jan 07, 2009 | Asko W6661 Front Load Washer
Doesnt stop pouring water
it is suppose to turn off, bad fill valve.
Nov 08, 2008 | Washing Machines
Washing Machines Logo
651 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
