Question about Samsung CLP 300 Laser Printer
Samsung CLP 300 won't print
My printer keeps shutting off. I've replaced the toner cartridges, I can find no paper jam. I've turned if off and on and unplugged it and replugged it. Pls. help
Try emptying the toner waste cartirdge, its on the left. Samsung CLP300's also won't accept toner refills. I've tried compatible toner cartridges myself and the printer just assumes that they're empty
Posted on Aug 11, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Samsung Master
  • 1,362 Answers
A few seconds after turned on?
after a half hour ?
in the first case it indicates a problem most likely with the fuser.
in the second case it might be on a timer.
Posted on Aug 07, 2008
My newly installed Samsung CLP-310 has a red light showing next to the <...> icon. Please could you help me to resolve the problem. Thx
Hi paulette,
if the light is red and TONER COLORS LED all LEDs off
• The machine is experiencing an error, such as jammed paper, open cover, empty paper, installed waste toner container, or full waste toner container.
• The machine is experiencing a service required error, such as LSU error, fuser error, or Contact your sales or service representative.
if the light is red and TONER COLORS LED each LED lights red.
• Each toner cartridge is totally exhausted. You can not print.
• Each toner cartridge is wrong.
Aug 01, 2011 | Samsung CLP 300 Laser Printer
When the printer is turned on, it warms up and then the red status button comes on. I've install new toner cartridges, dumped the waste toner tank, installed a new usb cable, in a different slot, and...
There is a lot of problems that can cause the red light to come on, toner cartridge problems, waste toner tank full, paper jam. The only way to know for sure is to check the smart panel software to see what the printer is reporting as the problem, then you can attempt to fix it.
Jun 29, 2011 | Samsung CLP 300 Laser Printer
Samsung CLP-300 paper does not seem to be catching when printing?
Hi. Kelly,
I think the issue is the due to paper pick-up roller. When the rollers get dirty or worn-out, the printer fails to pick the paper, which results in paper jam etc.. So, remove the paper tray and toner cartridge and locate the paper pick up roller in the middle. Clean it with damp (with luke-warm water) and lint-free cloth. I hope this would fix the issue. If the Roller is damaged or worn out, it needs to be replaced.
Hope this helps! Good Luck!
CreativeTECH
Feb 15, 2011 | Samsung CLP 300 Laser Printer
Why is red light on samsung clp- 315 and it is not printing
Does one of these situations apply to you?
The Status LED light is Red and the Toner lights are OFF (Check Smart Panel for message)
  • A Paper Jam has occurred.
  • The Front, Top, or Back Cover is open.
  • There is no paper in the Paper Tray.
  • There is a problem with the Waste Toner container.
  • A major error has occured.
The Status LED light is Blinking/Flashing Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Can still be used to print, but quality is unreliable)
The Status LED light is Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Printing is not available)
  • The Toner cartridge(s) are not installed properly.
Source: samsung troubleshooting guide for CLP-315
Sep 25, 2010 | Samsung CLP 315 Laser Printer
Printer stops when printing should begin with red light in status
There is a few reasons that cause the status light to turn red, paper jam, paper empty, toner cartridge empty, cover open and waste toner cartridge full. The PC Smart panel utility should give you an exact fault condition. Hope this helps.
Jul 08, 2010 | Samsung CLP 300 Laser Printer
Status light is red. No paper jam - will not print.
reset printer using hardware module or
replace toner cartridge
Jun 30, 2010 | Samsung CLP 300 Laser Printer
Why Samsung CLP-300 Printer making annoying/loud clicking noises?
So try to get the black toner cartridge out of the Machine. On zhe backside of the Cardridge is a gear. Try to turn the gear, maybe the Toner inside is clump together. When you can turn it very easy in both directions it's fine.
Oct 19, 2009 | Samsung CLP 300 Laser Printer
It doesnt print anything. the status light is red. i dont know whats wrong
A red Status light means 'paper jam'. A red light corresponding to one or more of the toner cartridges means empty cartridge. A flashing red light corresponding to one or more toner cartridges means low toner.
Aug 27, 2009 | Samsung CLP 300 Laser Printer
Samsung CLP-300 Printer has red light on, won't print, don't see any paper jam
I have to open the front panel as though I were going to replace the toner cartridge, but, instead I pull out the toner reclamation cartridge (the gray "L" shaped one to the left of the cyan cartridge) and then put it back in. This has cleared it each time for me.
Aug 10, 2008 | Samsung CLP 300 Laser Printer
Samsung ClP-500 install cyann toner
Please take your unit to an Authorized Service Center ASAP. Do not tur on the unit again. That burned fuse means that the temperature sensors inside the printer (thermistors) are not working correctly and the unit is overheating.
Oct 23, 2007 | Samsung CLP-500 Laser Printer
Samsung CLP 300 Laser Printer Logo
171 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
