Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
How do you get the round service cap off the front of the washer?
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
Hopefully the info below will supply you with the answer you requested and a little more.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
  1. Locate the round door on the front of the machine (about 6" in diameter, lower right corner) how do you get the round service cap off the front - macmarkus_26.jpg
  2. Find a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand or with thow do you get the round service cap off the front - macmarkus_32.jpg.
( you should also see a ring attached, if you pull this the door should unlatch, buhow do you get the round service cap off the front - macmarkus_31.jpgter out first if present is usually a good plan )
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
Posted on Apr 02, 2011
  • B. Wallman May 04, 2012
    there was no ring attached
  • K Richards Sep 25, 2012
    Same here. So how did you get the white plug out?
Washer has stopped and error says suds or blocked pump
Hi, there is a round cover on the front left corner. Install a pick in the small hole and turn the cover. You will see a twist cap behind the cover. Unscrew the cap and remove what ever is blocking the pump from turning. Watch out because the water in the tub will drain out.
That should fix the problem....
Jun 19, 2011 | Bosch Nexxt Premium WFMC6400UC Front Load...
Tip
Clean the drain hose in bottom of washer if water wont drain
I CAME TO THE SITE WITH THE PROBLEM OF MY WASHER NOT DRAINING. I HAVE HAD PROBLEMS WITH THIS FOR MONTHS. TAKING THE HOSES OFF. CLEANING THEM ETC... TODAY I FOUND THE BEST SOLUTION.. THE WOMAN WHO POSTED THAT SHE SAVED HER HUSBAND $300.00 BY TAKING THE BOTTOM OFF WASHER WAS RIGHT.....
BOTTOM OF FRONT LOADER.. THERE ARE THREE SCREWS.. YOU NEED ONE OF THOSE NOT PHILLIPS BUT ROUND LOOKING SCREW DRIVERS(SORRY).. ANYWAY TAKE OFF THREE SCREW.. ONE ON LEFT, RIGHT AND MIDDLE.. THERE IS A WHITE DRAIN HOSE WITH A CAP.. VERY HEAVY PLASTIC FRONT. IT IS HARD TO TWIST OFF CAP BUT KEEP TRYING. ANYWAY IT IS GONNA GET REALLY WET.. SOME WATER CAME OUT AT FIRST BUT I WAS NOT CONVINCED.. SO UNDRNEATH I STARTED TO SQUEEZE THE HOSE AND OUT POPPED 3 SOCKS AND AN ERASER.. THEN ALL THE WATER THAT WAS IN THE WASHER THAT WOULDNT DRAIN.. EVERYTHING WAS SOAKED INCLUDING ME AND MY SON SO BE READY WITH LOTS OF TOWELS. BUT IT WORKED. IM HAPPY TO SAY IM DOING MY FIRST LOAD NOW AND EVERYTHING IS RUNNING BEAUTIFUL...
on Jan 12, 2009 | Kenmore Elite 45986 Front Load Washer
I'm getting an F2 code on my Kitchaide front load
F2 on this unit is long drain. Take the front lower cover off (3 screws on the bottom) and you will see a round white cover about 4 inches round. That is the pump clean out. Before you twist that cap off be aware the water will come out have some towels ready. Take the cap off and you will see all the junk in there remove it and replace the cap. Thats it good luck..
Jun 06, 2011 | KitchenAid KHWS01PMT Front Load Washer
Every time I do a wash load on either daily wash or quick was my machine comes up with clean filter after its been through two thirds of the washing cycle and doesn't spin or empty. can u please advise?
There is a access panel that comes off/opens on the front bottom of the machine or back.
Open it and look for the round cap/plug that unscrews appro 3"round
Unscrew to take out the strainer, it is blocked
Be aware that you will need a pan and towel because water left in the drum will leak ou through here when removed.
Just loosen cap until pan is full and close, repeat until empty
Hope this helps
Jan 20, 2011 | Whirlpool AWM6100 Front Load Washer
Washer does not finish wash cycle. flashes F-21 half way through. Detergent is used up bu does not get to where is uses the fabric softener.
the filter/strainer is partially blocked. Take the kick panel or inspection cover off the bottom of the unit at the front(sometimes back) and you will see a round plastic cap that unscrews approx 3" round.After removing it you can pull the strainer out of it and clean it, there may be some residual water so have a towel or tray ready.Hope tis helps, any questions go ahead and ask
Jan 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
We saw water leaking out of the soap compartment at the top of the washer, close to the end of a washing cycle. What could be the problem?
access the service panel usually at the front on the bottom or back, and unscrew the round cap that contains the filter/strainer and make sure it is not blocked. Sounds lie it is restricted causing slow drain.Please let me know if this helps
Jan 20, 2011 | Kenmore Front Load Washer
Just started clicking. No action. Water will not
Locate the pump cover at the bottom, front of w/m. Pry the round cap out from the top with a small screw driver and unscrew the cap anticlockwise.
Clean the inside of coins, bits of cloth etc. This may solve your problem.
May 04, 2010 | Whirlpool GHW9200L Front Load Washer
Kenmore front load won't drain
Try this, on the access panel below the door(panel that goes across the front of the washer) remove the attaching screws at the bottom corners and pull the panel off, you should see a round,white plastic cap with finger hold bar across the middle of it, unscrew the cap by turning it counter clockwise, pull it towards you to open the trap,clean the filter trap out completely and reverse the order you took it apart to put it back togrether, try running the machine as normal. Good luck and Happy Holidays!
Dec 24, 2009 | Kenmore 46462 Front Load Washer
Please help
filter is the round cap in the front at the bottom. unscrew it (carefull, water may come out). unscrew filter and pull it out and clean
Oct 18, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Kenmore Elite Front Load Washer...F02 and SUD not draining!!!!
Probably something caught in pump. Remove lower panel if this one has it and you will see the pump. Loosen the round cover in middle to access clean-out.
Nov 08, 2007 | Kenmore 46462 Front Load Washer
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
803 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
