Question about Vacuums
We have a Digitech cat QM 1500 (Battery Tester) and we no longer have the instructions. Being lai persons we have no idea how to use it. We are looking for some help in identifying what setting we should use for what battery. Looking forward to hearing from you.
Need battery for fhv1200
Black and Decker, does not provide a replacement battery for your model. It is supposed to last 4 years. I have been scouring the web in order to find a suitable replacement but can not find anything. Is there a model number on your battery pack that you can provide for further research?
Sep 03, 2013 | Black & Decker Black Decker FHV1200...
THE BATTERY WONT CHARGE ON MY DIGITAL MP4 PLAYER PLEASE HELP
The battery itself is need to be check for that. If you charge it for long time and still doesn't charge then the battery is defective. Be sure to replace it with the same type and ratings. Another way to test it is by using a digital tester. Set tester to DC range and point test probe to it's positive and negative terminal. If it measure below its indicated voltage it is defective and need to replace.
Thanks for asking
Jul 07, 2011 | Vacuums
Manual, for a aims 1500 pure sine inverter, not putting out. need manual or help in diagnosing the problem
The manual for aims1500 pure sine inverter is not available. The particular manual for this inverter is not not available.
Click the below link and check the inverter manual. You might find it helpful.
Click here: http://www.psui.com/pdf/75-1000-0001.pdf
Regards.
Jun 04, 2011 | Vacuums
My Breville portable vaccum cleaner BHV9 stopped working. I haven't used it for the last 1 year. is it the battery?
good day..
try to see the LED indicator of your vacuum if it is light to low battery charge it...if the indicator is not lights-up your battery is drain.. because when the battery is not used for the long time it is got drain.
try to remove the battery and test it using tester the reading of your tester must 12vdc if not or almost zero reading replace it
if the indicator is on normal lights so your battery is good and the motor is not function..
try to lubricate it with the oil to the bushing
thank you and good luck
Apr 06, 2011 | Vacuums
Not as powerful as it use to be
Your battery could be weakening. The batteries to these Roombas seem to only last about a year, before getting weak. It is recommended that you keep your Roomba in use a lot and also recharge it often to help the battery last longer. Seems strange to me, but that's what it says in the instructions. I haven't had mine very long yet, but I'm trying to follow what they say to keep my battery running longer than one year. Go to the website where they have an assortment of batteries available for you. Just be sure to get the correct one for your model.
Good Luck.
Mar 13, 2011 | iRobot Roomba 530 Robotic Vacuum
Hoover suction
I had a fur ball stuck in the pipe.  I took the end off and used a broom stick to clear it out.
Jan 13, 2010 | Miele Cat & Dog 326i Bagged Canister...
Hoover U5046 not picking up cat hair in carpet any longer - Just bought new bags - would like to get this to work
Please check the flat rubber belt from the motor shaft to the brush roll to assure it is not broken, or severely stretched.
Jan 01, 2010 | Hoover U5046-930 Turbopower Bagged Upright...
Vacuums Logo
427 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
