Question about Whirlpool WFW8300SW
Button cracked is this common for a 2 year old whirlpool duet sport washer
SOURCE: whirlpool duet sport washer
F01 finally fixed after 2 repairmen and 2 circuit boards replaced/5 weeks of loaundromat! ! HINT have your repair technician check the boards. Be sure to have them especially check which wires are connected to which areas of the board. It could be that the wires are connected to the wrong place on the board. Good luck!
Posted on Sep 26, 2007
sdmc73
  • 121 Answers
SOURCE: whirlpool duet sport washer 3.6 WFW8410SW cycle will not start
set it to spin dran cycle and select no spin and push the rinse hold button 4 times it should read c00 on the dis play and go thew to c08 it will lock the door frist and then go thew all the cycles it will flash on a c# that has trouble
Posted on Nov 29, 2008
SOURCE: Whirlpool Duet Sport front loading washer - smells like mold
www.affresh.com
http://www.nufreshnow.com/
Posted on Mar 15, 2009
  • 3230 Answers
SOURCE: Error Code F-01
Hi, After about year and half Whirlpool duet sport gave F01 error code. The technician manual is located under the lower front panel. There are three possible reasons for F0: 1) EEPROM ERROOR. Unplug a washer for two minutes. Try running it again. (Did not work for me). 2) MAIN RELAYS ERROR. The tech manual suggests replacing CCU. The following is what I did and it fixed the problem, however. Unplug the washer. Remove the top cover by removing the three screws on the back. The CCU unit is in the right bottom corner if standing in front of the washer – it has a lot of wiring. Plug in the unit. While listening to the CCU start any washing cycle. After pressing START you should hear the relay to click. If it clicks twice, within a less than a second, it has a problem. Unplug the washer. Without disconnecting any wires remove the CCU cage from the washer wall. Stand now on the right hand side of the washer in such way that the CCU cage is under your left hand. Pull the right upper corner of the CCU plastic cage (it has a tab) away from you, slide the cage to the right by about an inch, and pull the entire cage away from you. Now knock on the back side of the cage 4-5 times with a bit of force (watch “Armageddon” movie for more instructions on it). Install the CCU cage back. Plug in the unit. Try some washing cycle again. If it did not help, repeat the procedure. If it did not work again, see the following. 3) PUMP DRIVE ERROR. The tech manual suggests replacing CCU.
Posted on Jun 06, 2009
SOURCE: Whirlpool duet Sport wfw8300sw02, is a piece of
i have front load duet sport model wfw8300sw02 which had an f28 error code, upon checking the water pump i had to remove sock. Now it still refuse to through any selection. The following parts checked out ok drive motor, water pump, pressure switch, door switch, water solenoid. The door solenoid switch and the line filter gave infinity readings
Posted on Aug 31, 2010
F-27 Code, replaced water inlet valve control and pressure switch. Cleaned filter, cleaned drain hose. Still getting F-27 code after it ran two loads of wash after fix yesterday.
There are several different versions of the Duet over the decades ... model series GHW ... then WTW ...then WFW and they have different error codes and diagnostics. I think yours could be in the WTW series and the following might work to clear the code .. but no guarantees:
To remove the code, press PAUSE or the CANCEL button 2 TIMES and the POWER BUTTON ONE TIME. If the code is still shows then unplug the washer 5 minutes
Mar 12, 2018 | Whirlpool Washing Machines
SOS: We bought a used Whirlpool Duet sport washer and dryer, which the owners said were about 2 1/2 to 3 years old. We do not have manual for it so cannot figure out why the washing machine window blinks...
F-20 on display (Water Inlet Problem-no water or insufficient water supply)
  1. Select PAUSE/CANCEL twice to cancel the cycle.
  2. Unplug washer or disconnect power.
  3. Are water faucets completely turned on?
  4. Are screens at inlet hose connection clear of obstructions.
To view the manual in an Adobe PDF format right click and select open to go to the owner's manual site.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=WFW8400TE&siteCd=MT_EN_US&userType=Consumer
Feb 22, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
I tried to start a load and an F-1 code flashes. I have a Duet Sport front load washer (2 years old).
Go to the Whirlpool webside and download a manual for free. They are good folks.
Here is mine...
https://secured.whirlpool.com/Service/.../Duet%20Job%20Aid.pdf
G.
Apr 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport washing machine with a leaking door.
You need to check if the door is not loose on the washer, make sure you tighten all the screws on the door
Jan 07, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Wirlpool Duet Sport Washer shows no indication of power
That happened to mine I had to replace the "brain" of the washer....the part was about $170. I think it is called the control panel.
There is a test you can run...look in the manual.
Jun 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport ~ E28 Error Code
serial communication error between central control and motor control.
Check connections at ccu (top front right corner) and mcu (bottom by motor), check belt drive for wear.
Did motor run ? Any other codes in diagnostic? (any one modifier button 4 sec on 4 secs off 5 times.) F codes are failures and C codes are portions of test cycle(automaticly run)
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to replace whirlpool washer Drum, baffle
Just order a new one from an online parts store and put it in.  The new ones dont screw from behind.  They just snap in. By the way, the rest of the baffles will break as well. So you may as well by a couple.  But there not cheap-You can order them through Sears and pay 23.95 each.
Mar 09, 2009 | Whirlpool 8572546 Duet Sport Stacking Kit
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet ht wouldn't start
remove the lower front panel,3 screws,side up and off,there is a tech sheet inside on the panel that should help you ,let me know what you find-mike
Oct 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WFW8300SW Logo
55 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
