Question about Dynex S-Video A/V Selector Switch
I have a dvd player, xbox, and wii hooked up to the selector which is hooked up to my HDTV standard component inputs. The video from each device has a bar of distortion running across the screen when I switch it on. When I hook up any one device directly to the tv the picture is fine. Any ideas?
  • Dynex Master
  • 2,098 Answers
Hi n_trook,
To isolate the cable from fault swap the cable from the output of the Selector box feeding to your TV with a working one. If still the symptom persist the fault was came from the AV selector box. You must take it apart and check for bad solder joints (crack/cold/dried solder). Make some re-soldering in the board. Spray also some contact cleaner to the selector switch.
One more factor affecting the signal is the length of the cables. The longer the cable, much prone to signal distortion.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 02, 2011
Cannot hook up Wii rc jacks because dvd is using those ports sujest
Hook them both to a A/V selector switch and then to the TV.
Jan 09, 2013 | Nintendo Wii Console
I have a 32" flatscreen
Different video signals use different connections ...and we are speaking ONLY the video(NOT including the audio connections)
  • Composite Video (typically colored Yellow) uses 1 RCA connection on your TV
  • Svideo (uses 1 svideo connector on your TV) a circular connector with 4 pins in it
  • Component Video (typically colored Red/Green/Blue) uses 3 RCA connections on your TV
These are the common analog video signals....You cannot mix and match these and plug a composite (Sometimes called AV in menus) into component etc
If both your sources (wii/DVD) you want to use a component signal to your TV (which BTW is the best quality of the 3 I listed) you will need 2 component inputs on your TV
OR
run it through a high end receiver (that will act as your switcher)
OR
buy a small stand alone switcher, something like: http://www.amazon.com/4X1-HD-Component-Av-Selector/dp/B000BVIBGI/ref=pd_sim_sbs_e_4
settle for a lower quality DVD signal and use the Composite video out (yellow jack) into the Composite Video In on the TV and use the component for wii
I hope this helps,
Magoo
Mar 10, 2011 | LG 32LG30 32 in. LCD HDTV
Ihave a bose 321gsx, I want to hook up my hdtv . ,blue ray dvd and vcr. Brain is frozen right now. Could use some help.
How to Connect an HDTV to a DVD Player
Hooking up a DVD player to an HDTV, or high-definition TV, is just as simple as hooking one up to a standard-definition TV. While a regular DVD player may be hooked up to an HDTV, it does not necessarily mean it will have high-definition quality picture. Unless a Blu-Ray player is connected to the HDTV, only a standard-definition picture will be shown.
Things You'll Need:
* Component cables
Instructions
Turn off and unplug the HDTV set and the DVD player before attempting to connect component cables to them.
Match the red, green and blue colored cables to each of the color-coded counterparts on the back of the DVD player. Be sure the cables are being plugged into the TV-out section of the DVD player.
Plug the other end of the color coded cables into the HDTV set. There should only be a red, green and blue cable being plugged into the TV. It does not matter what input these cables are plugged in, but keep track of which particular one it is. Most HDTV sets will have more than one A/V input, which is why it's important to take note of where the component cables are located.
Power on the DVD player and the HDTV set. If not already plugged in, ensure both of these are properly plugged into an outlet.
Press the "Source" button using the HDTV remote and locate the input channel that has the component cables plugged into it. The HDTV set should now show the DVD player logo or an introduction to the DVD.
Do not purchase HDTV component cables to hook up a regular DVD player to an HDTV set. Unless using a Blu-Ray player, only standard component cables are required. HDTV sets consume a lot of energy and should be plugged directly into an electrical outlet rather than a power strip.
Turn off all electronics before connecting and disconnecting wires to reduce the chances of getting an electrical shock.
Ensure that you have the proper cables to hook up your new HDTV. Take inventory to see if you have an ANT-IN, DVI-D/HDCP IN, Video In or Component Video In cables. The placement of these plugs will be indicated in your user book.
Begin by connecting the coaxial cable to the back of your cable box. Run a video cable to the TV; an S-Video cable may be used as well if you do not have any other video cables.
Locate a digital audio cable, or analog audio cable. Connect the audio cable to the TV from the cable box.
Now connect all other components including DVDs, VCRs or LaserDISC players. Try using all digital audio and digital video connections for the most complete HDTV experience.
Use a splitter to connect multiple components such as cable box to DVD or TV to VCR to avoid running out of chords. Calibrate your HDTV before enjoying fully, adjust the brightness, contrast and color settings.
Tips & Warnings
You can utilize a program to help with proper calibration of your HDTV system; these instructional videos can be purchased from many electronic stores.
You can opt for the store from which you purchased your HDTV to hook up the system for you. They will often calibrate the system for you as well.
Hope it helped.
Have a nice day...
Feb 26, 2011 | Bose 3 2 1 GSX System
I am not sure i can get the dvd player to work or even how to play the wii on this tv
Hi
U can connect the wii on ur tv . connect the component video output of ur wii to the component video input of ur tv. normally component video connections need three RCA chord for video and one two RCA chord for audio input. component video will marked as Y,Pb, Pr.
ok
Dec 30, 2010 | Toshiba 27A33 27" TV
We need to connect a wii and a dvd player up to our 32 in Emerson? Unsure of which jacks to use?
First, you must figure out If your TV has component video inputs. This is a set of five cables (red, blue and green for video and red and white for audio) and will give you the best picture on an hdtv
Then, If your TV does not have the component video cables, you will be using the red white and yellow composite yellows the system came with. A very simple connection.
Last, If your TV does have the component video inputs, you will need to buy a set of the Nintendo Wii Component Video cables from Walmart, Target or any other gaming store. These will enable widescreen view and the best picture quality.
To connect your DVD player, you need to located the composite video inputs and s-video. Composite video is a yellow, female RCA jack, normally found next to two audio jacks, one red, the other white. The three jacks together provide an interface for audiovisual connections. The red RCA jack connects the right channel of a stereo system, while the white RCA jack connects the left. The yellow composite video jack rounds out the set.
When playing the Wii, you will need to be on the correct video input "Component"
When playing the DVD, you will be on "Composite/Svideo."
Dec 29, 2010 | Emerson LC320EM9 32 in. LCD HDTV
I am trying to hook up my wii to my LED TV. It
You don't need component cables. Just use the regular AV connector that comes with the Wii and put the video (yellow) in the video spot that is also labeled "VIDEO" and "Y" on the tv...but the red and white (left and right audio) need to go into the farthest red and white connections...DO NOT put them into the ones labeled "Component Pr and Pb." It works perfectly...I just had to figure this out myself.
Dec 27, 2009 | Samsung UN55B6000 54.6 in. LCD HDTV
DVD Hookup
The input buttons on the remote are shared, e.g. for component, press once for component1 and twice for component2. Same for HDMI inputs. If I remember correctly, the video button is shared by the composite input and the svideo input.
Or you can use the input button on the remote to get each input directly.
Please check what the DVD player is configured for. For 480p (PS) it can only output through component.
Dec 26, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
How do you hook up a wii to this thing?
ok u can hook it up though a dvd player if ur tv wont support it make sure ur on the right channel though
Dec 25, 2008 | EA Sports Tiger Woods PGA Tour 08 for...
I have the HT-S3100 model, and hooked up my tv, xbox360, and Wii to it. The audio works for all three, but the only video I can get is for the xbox. I am using the component hookup and it is hooked up...
On all tv's there should be independent input for all devices. Xbox 360 ,Wii, and tv. Take a look at input at the back of tv. The Xbox input should coincide audio/video. The same with each device. Then you use the tv's remote to select the input for each device. They should all work independently from each other. Such as component 1 for Xbox, component 2 for Wii, and depending on what type of tv input you use, such as coaxial, RCA, you note and put tv input setting on the device that you are going to use. If you have the audio working on each device, check the video input for each device. Make sure they correspond.
Oct 13, 2008 | Onkyo Audio Players & Recorders
Hi, I just purchased a Samsung series 3 330 model#LN40A330 I'am having problems with the AV inputs on back of television. I hooked up a DVD player to Component 1 it works fine Then I hooked up Nintendo...
I figured it out,
The solution to my problem was to update my video cables for my new HDTV.
I found out through trial and error that I can only have one Anolog device hooked up to the TV because with two Anolog devices hooked up the same way it must confuse the TV somehow making one of the inputs showing up in Black and White, So I purchased the color coded AV jacks and everthing works like a charm now.
Jun 21, 2008 | Samsung Televison & Video
Dynex S-Video A/V Selector Switch Logo
202 people viewed this question
Top Dynex Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Dynex Audio Player and Recorder Expert? Answer questions, earn points and help others
