Question about Car Audio & Video
If i have a 4 channel 2000 watt amp, can i use 1600 watt wires if i only have 2 subs hooked up to it?
    Problem Solver:
  • 18 Answers
Yes, you will be fine. 4 gauge power wire is sufficient for a couple of reasons, the primary one being that most of the companies that are boasting 2000 watts for a 4 channel amp are off brand "web-retail only" companies, and they severely over rate the power output of their amplifiers. Secondly the supposed 2000 watts is peak power and not rms power. Peak power means how much power that amp can put out during absolue climax of the music or during a tone burst. RMS power is how much that amp will put out continously to your speakers or in this case, your subs. If you look at the spec sheet of that amp, in all actuallity you're probably only getting 200-300 watts rms even bridged.
On a side note, if you really want to push your subs hard, you might want to consider getting a mono block or "class d" amplifier and use that 4 channel amp to push your surround speakers. Class d/mono block amps are specifically designed to push subwoofers and will give you the most efficient power out and the best heat dissipation to withstand the output required to drive subwoofers. You'll get better bass and also more adjustability to tweak the sound levels coming out of your subs. Hope that helps.
Posted on Apr 02, 2011
Testimonial: "thanks a lot, really helped."
Crunch 2000.4 car amp, need help tuneing
re-check the speaker connections are correct and use a matching ohm test speaker on the other connections for a sound check. Sounds like hi frequency output into the sub amp. Sub-woofers are a mono signal!!
Jul 17, 2017 | Crunch Car Audio & Video
I was wondering what wattage amp I should have for my 2 kenwood excelon 1600 watt rms 12s an if I should wire them parallel
first thing are the subs 1600rms a piece? If so, buddy you need about 3000 watts rms. No less than 2000 to do them justice. Wiring parallel depends on the ohm load of the subs, if they are dvc's and the lowest ohm load the amp can handle. Not all amps are 1ohm stable.
Dec 24, 2014 | Car Audio & Video
I have a lanzar vector VCT-2210 2000 watt amp hooked up to two menace 1300 watt subs. when i turn the volume up on the head unit the amp goes into protection mode. i checked all my wiring and it seems all...
Things to check: Is the wire between the amp and the subs heavy enough to pass 167 amps? 2000 * 12 = 166.66666 amps. Max volts on the subs are 10 volts....close enough. Are you sure you're using the line out on the head unit? You may be over driving the amp if it's anything else.If the head unit doesn't have line out connectors then you'll need to get an attenuator for each channel. Do you have caps on the 12 v power in wires? They'll keep the headlights from dimming and the alternator will last longer if you do.
Apr 09, 2014 | Lanzar VCT2210 Vector Series 2 Channel...
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
I have to hook up 4 amps in my car. 4 channel 700 watt ken wood, 2 channel 800 watt Sony, 4 channel 740 watt Jensen ,and a 2 channel Rockford fosgate. Which is best way to hook them up so I'm not ki
Pace posted on Saturday, March 05, 2005 - 01:08 GMT Your subs are dual 4 ohm voice coils so if you want to bridge your 2 channel amplifier to your two subs then wire them parallel, meaning the + to + and - to - ( Do this to both subwoofers), Then run a wire from one positive and one negative on each sub and bring the two positives together and the two negatives together and hook both positives to the far positive connection on your amp and connect both negatives to the other negative on your amp,
This will create a 4 ohm load on your amp.
Although if it's a two channel and you have two subs it's usually pointless to bridge them because if you use one channel per subwoofer its going to be the same as if both subs were bridged. example) 800 watts x 1 bridged power of your amplifie (4 ohms) is the same power as 400 watts x 2 at 2 ohms.
Nov 26, 2012 | Computers & Internet
How can i hook up my 2 pyle pla 2378's to a sony cdx gt09 cd player and get the maximum wattage from my subs
your amp should work with any cd player. the only way to make sure to get maximum wattage out of your subs, is to make sure that they are wired properly to get the correct impedance at your amp
Oct 16, 2012 | Pyle NEW PLA2378 2000W 2 CH CAR AUDIO...
I have a PPI PCX-2400 and want to power two TREO subs that handle 2500 watts apiece. What is the best way to ire the PPI to these subs so that I get as much power from the amp to the subs without causing...
That would depend on the impedance (resistance) of the subs. Your best bet would be to use the full power of the amp to one channel (i.e. bridged) instead of to two separate channels (i.e. stereo). Two 4 ohm subs wired in parallel would present a 2 ohm load to the amp, which should allow you to get all 1600w out of it.
This explains series vs parallel quite well:
http://www.termpro.com/articles/spkrz.html
Mar 03, 2011 | PPI PCX-2400 Car Audio Amplifier
PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
How do I fix the problem so they work again.?
A 1000 WATT AMP HAS PROBABLY GONE INTO PROTECTION MODE BECAUSE YOU ARE TRYING TO RUN 1600 WATT SUBS COMBINED
Jun 08, 2009 | Car Audio & Video
Wiring issues
ok here is how it goes power wire from the battery all the way to amp..then ground wire from amp to a good ground on car then the remote wire which you have to run from the amp to the back of your stereo which in most cases is blue then hook subs from the sub box to the amp
May 30, 2009 | Legacy 2 Channel 1600 Watt Bridgeable...
Car Audio & Video Logo
343 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
