Question about Refrigerators
LG LSC27910SW Refridgerater is dead, no power, no lights, not cooling. It's plugged in and there's power to the outlet. Is there a reset button, or on/off switch?
fwadley
  • 482 Answers
SOURCE: power supply light has blinking green light
If the power box is bad, The computer will not come on. if you only get a green light, you would need to start with replaceing the power box, if you get a new one and the same thing happens, then the mother board is bad too.
Posted on Nov 27, 2007
JULIANFIX
  • 975 Answers
SOURCE: dead
IT COULD BE A FUSE , needs to be replace , if your handy , you can do it yourself , open unit , and check where the power supply is .look for a tiny glass tube type fuse , replace , and try again , hope this helps , please rate , AJ
Posted on May 07, 2008
SOURCE: Emerson MW 8115SS
Remove screws, remove cover, replace 20A 125v fuse. Should work.
Posted on Jan 27, 2009
SOURCE: GE MicroWave JES1136WL01 died while defrosting.
Mine has the same problems. After removing top cover, check fuse on power supply board (mine was OK). Then check thermo fuse located to the far left under the top cover( 2 black wires going to it) using a meter. I then jumped this fuse to see if this was the only problem. I hope to find a replacement thermofuse at the local hardware store.
Posted on Mar 07, 2009
  • 7 Answers
SOURCE: My Reset button wont reset
Just guessing, here. The reset is actually a "Ground Fault Interrupter" called a GFI. It's there to cut of power in case of a dangerous electrical condition--which you probably don't have.
Did you unplug the unit? If not do so, let the GFI cool for several minutes, and try to reset again. They're pretty hard to push in, maybe use a fingernail, you must hear a click or it's not reset.
Is there water in the outdoor unit, or is it filled with snow? This is the most likely cause of an actual GFI fault.
If the GFI itself has failed (unlikely), you could replace the entire power cord. You should then maintain safety by installing a GFI circuit breaker on that circuit, or you'll be in violation of codes that might affect your homeowners insurance.
There could actually be a problem with the unit. This would be that an electrical wire has come loose and is contacting the metal chassis, creating a shock hazard. Unlikely but possible.
If the receptacal you're plugging into is old and worn it might the problem. Worn receptacles might actually have tiny electrical arcs inside, which can trip a GFI. At a couple of bucks (DIY) it's worth a shot.
If there's actually an electrical fault in the unit it can be found and repaired, but the cost of repair could very well be more than it's worth. Warranty?
Posted on Mar 28, 2010
Why isn't it cooling?
Bad fan or not cooling gas on it is just like a car bra
Aug 22, 2015 | Refrigerators
My wife pushed the ice dispencer then power went out tried plugging into other outlets yet nothing
Do the other outlets you plugged it into have power and something else plugged into them work such as a toaster /blender ect?? if all outlets in kitchen out their probably is a GFCI type outlet that has the reset button on it. Sometimes their in the kitchen or depending how the house was wired when built they could be in a bathroom or even garage. One outlet has that reset button but could have up to 6 outlets wired to it
Aug 16, 2011 | LG LSC26905TT Side by Side Refrigerator
My power supply is blinking green light and my PC has no power
plug your pc directly to your wall outlet and see if it turns on. If it works, then the problem is your power supply. If power supply has a reset button, press it and try again. If pc does not turn on when plugged to wall outlet, then power supply for pc may be out.
Feb 16, 2010 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
Microwave dead
It has a reset button and two fuses her is the break down of unit.
http://appliancepartspros.com/partsearch/model.aspx?model_id=257786
but you should get a higher rated microwave.
Nov 26, 2009 | Ovens
1800HG Gateway Router, no power light
no fuse, the system just may be fried. try the reset button located on the bottom of the unit if no reaction router is dead.
Jul 10, 2009 | 2wire 1800HG Router (RG1800HG00)
After power outtage my f/p washer is dead -no lights nothing
Only reset is to unplug it. Are you sure you have power at the outlet? If you have 120V at the outlet the power surge may have blown the controller, not a cheap fix :(
Apr 12, 2009 | Fisher and Paykel Fisher & Paykel Washer
D-link dir 615
is unit in a surge protector? Any recent power surges? if you plug it in to a "good outlet" and nothing lights up at all (after a reset), either the ac adapter for the router is dead or the system board in the router is dead.
Mar 21, 2009 | D-Link DIR-625 (790069292637) Wireless...
Belkin G Wireless Router Not funciontoning: Power Light is Off
Its dead Jim.
I had one of those. Dead.
You can try hitting the reset button. Looking at the back there should be a small hole with a tiny button. Use a staightened paper clip or other object to hold it in for at least 30 seconds. That should set it back to factory defaults.
Doing that brought mine back to life momentarily , but it kept going out after a couple of hours and I had to repeat the process until it finally gave up the ghost for good.
Mar 04, 2009 | Belkin F5D7630uk4A Wireless Router
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
