Question about Montgomery Ward (223600UP) Heater
The heater will not stay burning - Montgomery Ward (223600UP) Heater
    Brigadier General:
  • 4,736 Answers
Depending on it's age, it's probably the Thermocouple going bad. Or you may have an insect nest inside the screen housing, around the pilot assembly, that needs to be removed. If you need to replace the thermocouple, I suspect the heater was manufactured for Montgomery Ward by Uniflame or Blue Rhino. Either should fit your heater.
Posted on Apr 02, 2011
The heater ignites well, but if it gets a clear blue flame (and it burns very quiet), the thermocouple will glow red and the heater stays on, but when it gets a opaque blue flame (it makes a sound when...
I would start by replacing the thermocouple. It is suppose to keep the gas valve open when in operation. If the mercury in the thermocouple dries out it won't keep the gas valve open and thus the flame goes out. If that does not work then you have a gas valve problem.
May 05, 2017 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Just installed this DV210SG Wall mounted panel heater, works great but smells like burning rubber, there is nothing burning, but sure smells bad! HELP!
There are manufacturing oils remaining on the metal. Allow it to stay on for about 1/2 hour. Open windows and door to ventilate. Smell will dissipate with use.
Nov 20, 2010 | Empire DV-215-SG Wall Mounted Panel Heater
Vent less gas heater wont stay burning. starts nice blue flame and than goes out no polite lite no flame.
If your heater does not stay burning then you should check each of the internal components over to ensure that they are working properly. Look at your heater's manual to do this. Failing this, the best thing to do is to buy a new one as the cost of repairing one can cost loads of money. Good luck :)
http://www.ventless-gas-heaters.com
Nov 29, 2009 | Desa International Comfort Glow Infrared...
CBP20T floor heater will not stay burning
It may be dirty, see link below for manual. I had the same problem and its now fixed.
http://12.153.20.74/manuals/107882-01M.pdf
Good Luck,
Boricuahbg
Dec 07, 2008 | Desa International CBP20T Wall Mounted...
REDDY HEATER PRO 200 WILL NOT STAY ON WITH TOP COVER ON
The nozzle is either restricted or worn to a point that the cone shaped fuel pattern is no longer producing a FOG, but is now producing a SPRAY and is not producing combustion. By removing the top cover the aerodynamics changes and allows the cone to expand & atomize better.
All bets are off, though, if you haven't checked the pressure on the air pump. Setting the pump pressure is easy but critical, especially if your heater has a glowbar & control board. Instructions are at www.reddyparts.com .
Check your heater over thoroughly for the exact model of your heater. "Pro 200" only designates a style and not all parts interchange from one PRO 200 to the other.
Oct 21, 2008 | Heating & Cooling
Torpedo heater ignites and then goes out reignites, goes out, etc.
We need to know more. Is this a kerosene or a propane fired heater?
Oct 15, 2008 | Heating & Cooling
Pilot stays lit, but burners underneathe do not light up or burn.
Check pump is working, if so could be stuck flow switch or gas valve fault get unit serviced
Aug 31, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Will not stay lit
This sounds like its being starved of oxygen. Check the air input vent and clean it.
Mar 18, 2008 | Dyna-Glo (PPH16-LP) Utility Heater
Will not stay burning
i think i may have solved it. i heated the thermal couppling and very gently bent the tip about 45 degrees. it has been running about an hour now i'll let you all know if this fails but so far so good
Mar 06, 2008 | Berkeley Forge G-PH001PSS Open Flame Patio...
Montgomery Ward (223600UP) Heater Logo
103 people viewed this question
Top Montgomery Ward Heating & Cooling Experts
paulcarew
Mack Baxter
Are you a Montgomery Ward Heating and Cooling Expert? Answer questions, earn points and help others
