Question about Casio AW80-7AV Wrist Watch
Method of resetting time - Casio AW80-7AV Wrist Watch
Reset the time on a G shock GW 1500A
The least time-consuming method is to follow the instructions in the manual. Download the manual for the watch module from Casio worldwide site. The module number is a 4-digit number set inside a rectangle on the back of the watch. Usually on the periphery of the circle.
Nov 03, 2013 | Casio GW1500A-1AV G-Shock Atomic watch
I have an old Casio watch 863 SDB-500W, I have just change the battery . Light is working but nothing is display. How to reset it ?
To reset the watch, you need to 'short' the reset point with the battery. To do this, with the watch face down and the back removed the 'Reset' point is in the bottom right hand corner (a gold-coloured contact point). Use a pair of metal tweezers or an unbent paper-clip (anything as long as it's metal and will touch the reset point and the back of the battery at the same time). Maintain contact for about 5 seconds and you should get the display back.
I've just changed the battery in my SDB 500W and the above method worked. I did lose the audible 'beep' though and I'm currently on the net trying to find how to get it back. That's how I found your question... :)
Jul 24, 2011 | Bulova Watch
I cannot get my Seiko SNA304 chronograph second hand to reset after battery change. Keeps resetting to the 17 minute position, I have tried to use the manual instructions but with no success, Any help...
Seiko watches are a popular accessory for both men and women. The history of Seiko watches goes back to 1881 long time ago, when the company that was to become Seiko began. From the beginning, the method to set a Seiko watch has been designed to be a simple process.
The following are the steps to set a Seiko watch for the time, day and date function, and for setting the chronograph on an analog watch.
Set the Time:
  • THE CROWN
Pull the button on the side of the watch carefully, the crown, out to its most extended position. You will need to unlock the crown if your watch has a locking crown. To unlock, turn the crown counter clockwise. While the crown is pulled out in the setting position, the watch will cease functioning.
  • 12 O'CLOCK POSITION
Turn the crown clockwise to move the hands of the watch past the 12 o'clock position on the dial. The day and date will change to indicate AM setting but will not change for PM setting. It is recommended that you set a Seiko watch in the morning for instant day and date setting; however,this can be done manually.
  • FINISH
To finish setting the time, simply push the crown until it is flush with the side of the watch.
Good luck and thanks for using fixya.
Dec 18, 2010 | Seiko SNA304 Wrist Watch
I don't know how to wind the watch....can you help?
WIND AT THE SAME TIME EVERY DAY. This is extremely important. In order to ensure that your watch keeps good time it must be wound at the same time every day. Most people like to do this at night before bed.
WIND ALL THE WAY. The watch must be wound all the way, or it will slowly lose the proper time and require constant resetting. Also, if not wound all the way, the watch may stop keeping time earlier than expected.
WIND IN THE RIGHT DIRECTION. Most European watches wind clockwise when the face of the watch is pointing towards you. Determine which way your watch winds, and stick to that direction. To figure this out, try to turn it both ways. The wrong way will either be extremely loose, or extremely tight.
Tips & Warnings
Keeping your watch clean and free of dust and dirt will also add to its longevity.
Contact the watch's manufacturer for any special and/or specific care methods.
Don't under or over wind you watch. When you start to feel resistance, STOP.
Aug 17, 2010 | Watches
The chronograph hand of my TAG Formula1 starts at 2 seconds to 12 not at 12 o clock also after reset it stops at this point. What could be the problem?
If you pull out the crown to the first stop, then press the start/stop button that should move the second had on one second per press. The reset button moves one of the other dials. If you pull the crown out to the second stop, the start/stop moves the minute hand on, and the reset button moves the other small dial round.
Feb 19, 2010 | Tag Heuer Formula One
Sceletonized dial for the timer, not returning to top (12 o'clock) on reset.
Go to the jacques leman web site "www.jacqueslemans.com/" and you will see a menu on the left. Choose "instructions/ catalogues" .
Download the PDF file for your watch and you shopuldbe able to find the method of resetting the hands.
Feb 12, 2010 | Jacques Lemans F1 Analog Digital Watch
I Lost My Small Book on How to set my new Fossil watch Model JR9455-300703
Finally i got it while playing around with my fossil JR9455. . .
Here's the step by step method in setting the time:
1. press and hold light button and press start/split button
(light and start/split are both pressed by this time)
2. you should hear a beep
3. You should notice that the display changed
4. press mode to choose which setting you want to change
5. to change the values, just press start/split button to move up and reset/stop button to move down
6. to finish the setting just press light button again.
This method worked with my watch. I hope this helps. . .
-chickozai-
Jul 05, 2008 | Watches
Seiko chronograph alarm
Solution #3 (Posted by Guest on 5 Mar 08) is spot on. Quick and easy method to reset the chrono hands (it was not in my Seiko manual).
Interestingly, this can also be used to set the chrono ahead (or behind--with a little math) for offset timing measurements.
Jan 13, 2008 | Seiko SNA553 Alarm Chronograph
Casio AW80-7AV Wrist Watch Logo
78 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
