Question about KitchenAid Refrigerators
The control panel fades in then goes off. The freezer temperature flashes 5 then 10 then goes out. The call for service light and overtemp lights are not on. The refrigerator temp is at 45 from an independent thermometer and the built in thermometer flashes 34. There is a beep from the coil housing on top of the unit. The unit is a built-in KSSC48QMS01 side by side 6 years old. What can I try? I've turned the power off/on and tried the master rest switch.
  • KitchenAid Master
  • 12,061 Answers
Ok well the Power supply is the most likely culprit, this is evidenced by "The control panel fades in then goes off" this then indicates the supply side, as well as the supply, there may well be something else that is causing the supply to fail, it may get worse unit it fails completely.
There isn't really a lot one can do with a unit of this age as well, DIY here isn't really an option. Getting the parts, will/would be the big problem. The best professional advise I can give, that will enable you to obtain a good result, at the very best cost, is to do as follows.
Contact a local or head office of Kitchenaid, ask them for a referral to an authorised servicing center, then contact them, and FIRST ask them for a "Quote" as to the cost and type of repairs. Now you see this way, you can get an idea of costings and exactly what's wrong, then you can make an informed decision as to what to do, repair or replace.
You see i am finding more and more, and especially with "Older" units, customers, are preferring to put, any larger monies that would have been spent on repairs, towards the cost of a new unit, with a warranty.
As an aside here, and I make all my clients aware of this, statistics prove, that any unit that is repaired will generally fail again, within the next 12 - 18 months, regardless.
So there you have it.
Posted on Apr 02, 2011
2 Suggested Answers
allbrands
  • 600 Answers
SOURCE: The control panel fades in
Hello, Thank You for using FixYa. I will be helping you today.So the control panel is flashing on and off? Also can you turn the unit on and listen if the fan in the freezer is running or is it starting and stopping? And did you notice any frost on the lower back wall in the freezer?
Thank You and please rate my answer if it was helpful..
Posted on Jun 23, 2011
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Fridge working intermittently.
i guess there is some problem with the thermostat
get it changed.....
Oct 08, 2008 | Refrigerators
Blue lights are flashing on control panel when I open the door
Codes are usually flashed in a group, count flashes and write down the number of flashes in each group, separated by longer off periods. Report back the codes.
Jun 02, 2015 | Refrigerators
The alarm light is flashing what do I do to stop it.
Hello Mrs. Mavis;
My name is Peter. I am a retired field service refrigeration.
The alarm light is a good thing. It is telling you that something is wrong. Generally, the alarm goes off when there is a temperature problem in either the freezer section or your fresh food section.
You only have one cooling source and that is in your freezer. Your freezer will satisfy its own temperature before it feeds your fresh food section.
Ok, Your freezer temperature should be between -2 & + 2 degrees F. Your fresh food section should be between 35 & 40 degrees. F. Adjust you temperature settings accordingly. Wait for a few hours to see if the alarm goes off.
Another problem with maintaining temperature control; people tend to over pack their freezer or fresh food section. Check to make sure your food product does not over extend the shelves. Also check the racks on the doors. Check to see if food product does not over hang the racks.
You also need to maintain your refrigerator. You have a cooling coil like the radiator in your car, it gets rid of heat. You must keep this clean. A dirty condenser coil can effect your temperature by as much as 40 degrees F. This coil is located either under in the front of your refrigerator or a canister looking item in the back of your refrigerator behind the lower cover.
Look at the back of your freezer wall. Is there a lot of frost or ice?
This could be either a defrost heater or freezer fan motor.
Call me. Lets talk about this more. 443-306-1362.
Nov 04, 2014 | Refrigerators
Temperature light at back of fridge randomly goes from red/green and the temperature in the fridge does not appear to be stable?
on a fisher paykel I would call them direct, their help desk can walk you through some checks to see what the error is... if I needed service on this unit I would use who they suggest.. because if the servicer does not have access to the factory on FP HE IS GOING TO BE GUESSING WITH YOUR POCKETBOOK in hand... we work on FP everyday and we call often....... I hope this helps.... ken
Sep 29, 2014 | Fisher and Paykel Refrigerators
First the freezer alarm beeping with red light flashing, inside light went out and freezer standard electronic temperature control display unit no longer lights up.
Hi Loretta, I am happy to assist you!
Based on the symptoms you are describing, it sounds like your freezer may possibly have a communication problem with the control board, a potential wiring failure, or faulty temperature control. Before reaching out to a professional, let's try resetting your freezer. This can be done by either unplugging it or flipping off the circuit breaker. It is important to wait approximately ten minutes. If it proves ineffective, In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the exact diagnosis of the appliance.
Best regards!
Jan 31, 2014 | Frigidaire Freezers
The ice cube indicator is blinking
From the manual:
The Control Center monitors refrigerator and
freezer temperatures as well as the ice maker
system. If there is a temperature or ice maker
problem, you'll be alerted by a flashing
SERVICE indicator light. This same SERVICE
light will also flash if the condenser needs
cleaning. Before calling for service, please
check and see if your condenser area needs
cleaning. Refer to Condenser Cleaning,
page 22.
CONDENSER CLEANING
In all Built-In models, the condenser is located
behind the grille. First, remove the grille. Then
using a soft bristle brush, vacuum to remove
dust and lint from the condenser. NOTE: To
avoid bending the condenser fins, be sure to
vacuum in the direction of the fins (up and
down). Clean the condenser area every three
to six months.
CAUTION
Before cleaning the unit, shut the electricity
off at the control panel. When you
clean the condenser, wear gloves to avoid
injury from the sharp condenser fins.
Failure to clean the condenser could
result in temperature loss or mechanical
failure or damage.
Mar 14, 2011 | Sub-Zero 650 / O Bottom Freezer...
My au Falcon teperature light comes on about a minute after the engine is started, the temperature gauge shows low temperature, the radiator is not boiling, I have taken the temperature sender unit out of...
The low water level sensor is in the overflow bottle, not the overtemp sensor.
The overtemp sensor will be on the motor somewhere.
To check you have the right sensor- short the sensor to ground and observe the overtemp light operation.
You likely have a faulty over temperature switch sensor.
Jun 06, 2009 | 2006 Ford Taurus
Refrigerators Logo
172 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
