Have buy a ge handset speakerphone model 29111series but i dont have a guide in french. problemes.pleasesend me aguide in french.or iretourn for credite thank
Most likely cause is power supply has shorted functions possibly due to overcharging or power surge I suggest openin up one of the handsets to look for burns on board or loose connections also if there is moisture or metal shavings
Your GE phone doesn't have an accessory handset. Unfortunately you cannot replace it with just one handset. If the phone is within warranty, kindly return it to the manufacturer and have it replaced.
press "mute" key to access menu, press the up or down arrow key labeled "caller ID- volume" until you get to "handset setup", press the "mute" key again, press the down or up arrow until you have "defaultsetting" selected, press "mute" key, press "1", then press "mute" once more. At this point your handset will reset clearing the indicator for all the handsets. I've had to do this twice on my phones and it worked every time.
I
was having the same problem with the same model phone, and fixed the problem by rebooting the phone – unplugging the
AC and phone cord from the base station and plugging both back it, then removing and replacing
the handset to regenerate the security code.
I have the problem. I think it is because the battery i have in it was a Ni-MH and it should be a Ni-Cd. I am now looking for the right baterry Good luck Frank [email protected]
