Question about Proscan 26LB30QD 26 in. LCD HDTV
Proscan lcd model 40LD45qc keeps turning itself off even when its not hot
4 Suggested Answers
  • 20 Answers
SOURCE: Proscan 40" LCD-Screen Freezes
They actually state that you have to unplug it and replug it in to fix this problem in the owners manual so it's not just a isolated issue. I to have this problem daily now and this is the 2nd set after returning the first one due to same reason.
Posted on Oct 12, 2009
  • 608 Answers
SOURCE: My Proscan 40LD45QC cut off
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Posted on Dec 14, 2010
ginko
  • 19396 Answers
SOURCE: tengo proscan 40ld45qc se apaga
Hola.
La tele se queda en estandby porque el procesador central situado en la placa base de la tele (main digital controller pcb) encuentra un problema como una tension incorrecta o un corto circuito.
Esto es devido usualmente a componentes que necesitan ser reemplazados. La parte que falla mas amenudo en este modelo es la placa de alimentazion y los condensadores en esta placa.
Aqui piezas de repuesto para esta tele: 40LD45QC
Posted on Dec 30, 2010
How do I run Channel auto scan?
Download the user manual to this set, by the link:
PROSCAN 40LD45QC User Manual
It has all details. http://electronicshelponline.blogspot.com/
Jul 31, 2015 | Televison & Video
My proscan 42la45h model lcd the tv has power but wont turn on. Any suggestions
check fuses. if it turns on via remote control replace batteries. First remove from mains / power for a good ten minutes and see if this brings any benefit. There is not a lot to go wrong with fp tvs really.
If the issue is not one of these, and it does turn on via remote it might be that the control handset is faulty.
After this you can think about getting the set itself diagnosed/inspected
May 29, 2015 | Proscan Televison & Video
Proscan 40LD45QC The screen flickers
check cable or ant connection make sure good connection disconnect and reconnect still have problem may need service depends on age of unit.
Dec 27, 2014 | Proscan Televison & Video
Proscan 32la25Q Backlight not comming on
You either have a faulty backlight or one or more of the inverter transformers is bad,
a close inspection of the picture when on will show a bad tube as it will be lighter or darker than the rest,transformers may be hot to the touch
Len..
Oct 13, 2014 | Proscan 32LA25Q 32 in. LCD TV
No screen proscan 42la30h
Lcd/Backlight! Main Problem On the led,lcd is the Bad lcd ribbon or Bord, Try turning off all the lights and Turning it on, then kneel down to the ground and see if u can see Channels changing when u click up/dwn or volume or even the Fuzzy look when theres no cable going to it. if u can see then its probably a bad board or chip.
Hope This Helps :)
Mar 08, 2012 | Proscan 42LA30H 42 in. LCD Television
SCREEN CRACKED FOR MODEL #40LD45QC. NEED TO BUY REPLACEMENT SCREEN. PLS. HELP!
Yu can find used screen at www.interliquidparts.com you have to find the screen number from your TV. It is located on the back of the screen on a white sticker.
Jun 08, 2011 | Proscan 40LD45Q TV
The problem is with the set. I would return it.
Jun 09, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Can't get Satalite remote model IRC 451 to work with my tv
theres nothing much i can tell you, i searched google through maybe 5 pages, everyones having the same problems. i'll keep looking for you though
May 01, 2009 | Proscan 32LA25Q 32 in. LCD TV
Proscan 26LB30QD 26 in. LCD HDTV Logo
206 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
