SOURCE: paslode finish nailer wont fire
CHECK THE SPARK! IF YOU HAVE A JOBSITE RADIO YOU CAN HEAR THE SPARK ON THE AM BAND AND TELL IF THE TOOL IS FIRING!
SOURCE: I purchased a new FN16250K-2 finish nailer today. I loaded it w/
It can be confusing these days knowing exactly how each nailer works. For example your nailer has three different triggers available that will function differently. The black trigger is the contact trigger that will fire a nail every time the safety hits the work or (bump fire with trigger held); with the grey trigger one must depress the safety foot against the work first ~ then squeeze trigger. To fire again you must release the trigger withdraw the gun ~ re-depress the safety and squeeze the trigger to fire again. A third black trigger is available that will fire the gun with mechanical arm for production work. You can test the gun for defect by disconnecting air, removing the nails, remove the trigger retainer pin, remove the trigger. Then connect air and press the gun against wood and press the trigger pin with your finger. Not good to dry fire these guns; thats why it is necessary to place gun against wood to absorbe energy. If the gun does not fire return for exchange. Good Luck
SOURCE: nail gun double fires
There is one main part that can be the cause of the problem.
The trigger. Check to see if there is anything out of the ordinary with this. There should be some moving components attached to the trigger itself. Is any part of the trigger touching the button in the body of the gun when safety is not depressed. If the lever on the trigger is pushing on the button, even a little bit, It will allow the gun to fire again and again.
SOURCE: when I pull the trigger, the nailer just goes
The first thing that comes to mind is they are not being oiled properly. Follow the directions for the number of drops of air tool oil to put in daily. If they have been run dry, this makes quick work of the Orings and requires rebuilding the nailer with new Orings.
The second thing is if contamination has gotten into the cylinder bottom thaat can happen if a jam has ever occured.
Dis-assemble the nailer and inspect for these conditions.
SOURCE: Gun fires, leaves good indentation, no nail. WCE
Remove nails and use thin tool to push driver all the way up to top of cylinder. If the gun fires one nail then skips, the driver is not returning to top of cylinder. If no nails fire, then nails are not feeding into proper position. Driver must return to top to allow nails to feed into position. Most common problems are bent driver, worn piston oring and bad batch of nails(head too large). Good luck
