How do I know when to use the fuser wiper cavity cover or the oil fuser wiper or the wax fuser wiper on my Lexmark T642?
  • tmanion223 Apr 02, 2011
    Baron, Thank You for your response. Unfortunately my customer has replaced whatever was in the fuser cavity with a style of wiper that I have seen in much older printers. It has dry, felt strip that contacts the fuser roller. This tends to accumulate hardened toner residue and eventually scores the fuser roller causing print defects. In the Lexmark 4061-XXX manual there is listed a Fuser Wiper Cavity Cover - 40X0120, an Oil Fuser Wiper (Black Housing) - 40X2665 and a Wax Fuser Wiper (Gray Housing) - 40X2666. Through a fair amount of Google-ing I read a Lexmark article stating that the Wax Wiper was to be used when duplexing vinyl labels ( I know. Who the heck would do that?) - but even though it's in the parts list I couldn't find the application for the Oil Wiper. I've seen the Fuser Wiper Cavity Cover used in some Lexmarks. It's a piece of hard plastic with no wick that shields the Fuser Wiper Cover Assy (outer cover) from the fuser heat. It has no contact with the fuser roller and therefore does not accumulate hardened toner buildup. I'm wondering if that is all that is needed for high volume printing on regular paper - but I can't find it written. I would really appreciate your opinion.
  • 1,915 Answers
The T642 is a monochrome printer and as such does not have an Oil wiper. The only wiper that should be needed with this printer is the hard plastic one that ships with the printer. These wipers are permanent and are only replaced when you install a new fuser. Oil wipers are usually only used with color laser printers.
Posted on Apr 02, 2011
  • Mark Schmit
    Mark Schmit Apr 02, 2011
    We have clients running 200K copies every six months through these printers and we only ever use the starndard insert that ships with the fusers. I also have had customers replace the hard insert with the old cloth wipers with the same tragic results. If the customer is printing on standard media I would stick to the standard insert.
What can i do when my lexmark T642 printer displays 922.02 service fuser error when the printer was never used?
It could be the connector to the fuser from the LVPS is not connected properly. It could also be the Thermistor on the fuser is bad.
Jan 31, 2017 | Lexmark T642 Laser Printer
How to reset fuser kit on X656de
  • 01: Lift the paper bail, and then remove the fuser wiper cover
  • 02: Remove the top rear door
  • 03: Open the fuser cover
  • 04: Remove the fuser
  • 05: Remove the new fuser from the packaging
  • 06: Insert the fuser
  • 07: Close the fuser cover
  • 08: Attach the top rear door
  • 09: Lift the paper bail, and then insert the fuser wiper cover
Or watch this video
Lexmark Product Videos
click on Service Maintenance
then click on Replacing the fuser
Manual X651de X652de X654de X656de X656dte X658d X658de X658dme X658dfe...
May 11, 2014 | Lexmark X656de AllInOne Laser Printer
I tried to replace the fuser wand, but some of the tabs broke off and now it won't stay.
You might need to replace the Fuser Wiper Cover Assembly. The part number for the said part is 40X0001. Please contact any Lexmark Authorized Service Provider or contact our Technical Support Hotline.
Nov 07, 2012 | Lexmark T642 Laser Printer
Service fuser error, what does that mean?
The Fuser is the part that melts the toner onto the page. It is located in the rear of the machine, the rear cover must be removed to expose it.
Most likley it is a contact issue, on the heater. A new fuser will be required, or if you are inclined, remove the fuser and clean the AC contacts on both sides.
www.partsnow.com for a new fuser
Jan 16, 2011 | Lexmark T642 Laser Printer
I have a Lexmark T642. Where does the felt strip
The felt strips were not put in on the Newer T 630/T640 and up series as they were causing scoring on the fusers. They would act like sand paper and score it beyond use. There are no more which is a great thing.
Feb 26, 2010 | Lexmark T642 Laser Printer
920.07 code on a t642
a 920 error means your fuser is under temperature at standby. you should replace the thermistor it cycles the fuser on and off to maintain these temps
Nov 06, 2009 | Lexmark T642 Laser Printer
Lexmark T642 display says paper jam check rear door. There is nothing jammed! What can I do
The sensor in the fuser unit is jammed/broken. The fuser will need to be repaired or replaced.
Aug 13, 2009 | Lexmark T642 Laser Printer
HOW DO YOU INSTALL THE FUSER WIPER IN A LEXMARK T634?
The fuser wipe is located under the small fuser cover or it is also known as the fuser cover wick. Here is a video that shows how to install.
Dec 02, 2008 | Lexmark T634 Laser Printer
Wiper blade
When you say wiper blade, do you mean the one in the cartridge? There's also a cleaning wand in the top of the fuser.
Dec 18, 2007 | Lexmark T642 Laser Printer
451 people viewed this question
k24674
jasbo
jasbo
