Question about Video Game Consoles & Games
When I turn on my Wii it says "Repairing... Do not turn power off" What exactly does this mean?
    President:
  • 1,623 Answers
Lol april fool is what it means, your soft mod pri loader is playing a trick just press the a button and it will go away :)
if yopu found this useful please vote for me
Posted on Apr 02, 2011
Just bought a wii for my child and found the massege of "now repairing do not power off. The problem is the wii remote is not sync yet! Any help
sync the wii remote with 2 buttons, one where the sd card slot is on the wii, and the other where the batteries go in the wii remote. press both at the exact same time.
May 26, 2013 | Video Game Consoles & Games
Tip
Nintendo Wii Error Code 52030 The most likely cause of error 52030 is that the...
Nintendo Wii Error Code 52030<br /><br />The most likely cause of error <b>52030</b> is that the router securityinformation was entered incorrectly on your Wii or that your router is unableto assign an IP address to the Wii.<br /><br />If this problem <b>just started</b>, and your Wii was working before, then tryto <b>power cycle</b> your equipment. Turn off the modem, router and Wii. After10 seconds turn on the Modem, after 30 seconds turn on your router, and after30 seconds turn on the Wii.<br /><br />If this does not work then continue below,<br /><br /><b>Make sure</b> your wireless <a href="/../support/r9300725-nintendo_error_code_52030"><span><span>network<span>security</span></span></span></a> password and security typeis entered into your Nintendo Wii correctly. You can go into your routersconfiguration page to view the security key and view security type. If needed,you can change these. On most routers, you can access the configuration page byopening your Internet Browser and going to the router ip address(gatewayaddress) 192.168.1.1 This address may vary from router to router. Once you goto this address you should get a login page. Login and then go to your Wirelesssettings page to view the settings you need for your Wii. Once you verify thesecurity key and type, input these settings into your Wii and test theconnection. Click <a href="/../support/r9198848-connect_nintendo_wii_internet">here</a> for my <a href="/../support/r9300725-nintendo_error_code_52030"><span><span>tech</span></span></a> article on how to configureinternet settings on the Nintendo Wii.<br /><br />Tip - To view your gateway address in Windows do the following,<br />Go to Start &gt; Run and in the run box type "command" or"cmd". A black DOS window should open. In this window type"ipconfig /all" you should <a href="/../support/r9300725-nintendo_error_code_52030"><span><span>now</span></span></a> see a gateway address.<br /><br />-<b>Most home networks </b>will use DCHP. What is DCHP? This is Dynamic HostConfiguration Protocol. In short, it means your router or <a href="/../support/r9300725-nintendo_error_code_52030"><span><span>server</span></span></a> will assign IP and DNSaddresses out automatically, with no intervention needed from you. If you aremanually using settings(not using DCHP) you will need to assign an IP/DNSaddress to your Wii.<br /><br /><b>To get </b>to the Wii settings to input an IP address and DNS address, dothe following,<br /><br />Access the Wii System settings and select "Internet" from Page 2.<br />Select "Connection Settings" and choose the connection file youcurrently use (will have a red border around it).<br />Select "Change Settings," and click the right blue arrow twice toreach "Auto-Obtain IP Address."<br />Click on "No" and select "Advanced Settings."<br /><br />Enter in your IP address, DNS address and subnet mask information.<br /><br />A Wii connection test should confirm the internet is now working. Again, mosthome networks use DCHP so you may not need to set an IP address.<br /><br />-<b>Interference</b> can also cause this issue. Try and make sure there are nowireless devices around the Wii and router and the Wii is in an open areawithout devices blocking it.<br />-<b>Change your router's channel</b> setting to 1 or 11. By default, mostrouters broadcast on channel 6, which overlaps with other channels and may beweaker.<br /><br />If you are still having trouble, you may want to reach out to NintendoTechnical Support at 1-800-255-3700<br /><br />-G33k<br /><br />Check out some of my other tech articles!<br /><a href="/../support/r9300521-nintendo_wii_error_code_51031">Nintendo Wii Error Code 51031</a><br /><a href="/../support/r9300387-tuneup_utilities_prefetch_data_deleted">Tuneup utilities prefetch data deleted</a><br /><a href="/../support/r9275311-computer_freezes_computer_stuck">Computer freezes, computer stuck</a><br /><a href="/../support/r9256225-disable_enable_microsoft_windows_startup">How to disable/enable Microsoft Windows startup programs</a><br /><a href="/../support/r9223119-garmin_gps_stuck_not_updating_no">Garmin GPS - stuck , not updating, no signal problems</a><br /><br />Keywords<br /><b>Nintendo Wii Error Code 52030, Wii error code 52030, Wii 52030, Nintendo Wiiinternet issues, Wii internet, Nintendo Wii internet</b>
on Jun 02, 2011 | Nintendo Wii Console
No power plugged in outlet working plugged into back no lights comming on
Either 1) your Wii's power adapter is broken, or 2) your Wii is broken. If you have a friend who has a Wii, you could try borrowing their power adapter and seeing if the Wii turns on. If it does, then you know your power adapter was broken, and you can purchase a replacement.Otherwise, you're going to have to look into repairing the Wii. If you device is under warranty, Nintendo will repair it for you.
Consult Nintendo's troubleshooting guide here: http://www.nintendo.com/consumer/systems/wii/en_na/ts/index.jsp
Good luck.
Feb 28, 2011 | Nintendo Wii Console
My Wii has a red light when plugged in, and a green one while turned, on, the problem is, nothing is displayed on the tv or heard, also, the disk drive whirrs for a few second after turning on. The tv...
If the light is red, it means WiiConnect24 is turned off. Green means the system is turned on and it's normal for the Wii to whirr a bit when it's initially turned on.
Completely power down your system by pressing the power button for 10 seconds. If that doesn't work, unplug the AC Adapter from the Wii for a moment, then plug it back in.
That said, Nintendo recommends calling them if this doesn't fix your problem. Hope this helps.
Jan 06, 2011 | Nintendo Wii Console
Wii power problem!
You are not getting the correct voltage into the Wii, this can happen one of three ways. (1) The power converter you have is not converting the power correctly, (2) running on converters are not exactly matching the correct voltage and wattage has strained your power supply and damaged the Wii, or (3) the power supply itself just failed as a result of any number of normal electrical conditions.
Jun 09, 2010 | Nintendo Wii Console
No power to my wii. outlet is good.
Try the Wii in another working outlet just to see if it turns on. If it doesn't then try another AC Adapter in the Wii. If it still doesn't turn on with a new AC Adapter then that means the mainboad is bad inside of the Wii. If the Wii turns on then that means your old AC Adapter is bad.
Jun 04, 2010 | Nintendo Wii Console
Repairing wii, do not power off
hi this was an april fool....all you have to do is press a twice on wiimote
Apr 03, 2010 | Nintendo Wii Console
Wii screen do not shut off, repairing
This is an April fools joke as preloader has been installed on your wii, just press A on your wiimote to boot as normal, cheers
Apr 02, 2010 | Nintendo Wii Console
Hello my name is greg and we were having trouble with our electricity and we shut off the wrong sircut breaker and now our WII doesnt turn on but we are unsure if it is the power cord
The best way is checking the power cord with voltmeter or some unit like charger for mobile phone (plug it and look the phone charging).If the power cord is OK plug the Wii AC adapter.If Wii not turn on check the AC adapter with voltmeter.If working the problem is in your Wii console and it need repairing.If AC adapter not work just buy new.
Nov 09, 2009 | Nintendo Wii Console
Video Game Consoles & Games Logo
52 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
