I have a potterton 80 combi (baxi). The lockout light keeps coming on when hot tap is turned on. I have notice that the pressure gauge is below 1 bar. Could this be the problem, if so how do I increase the water pressure to 1.5 bar? I can find the valve to decrease but not the one to increase pressure. help!!
  • maur1 Aug 05, 2008
I found the valve to increase the water pressure and the boiler is now working.
Posted on Aug 06, 2008
Re: combi boiler.
if you have hot water at the taps but the heating isn't working make sure the thermostat is set high enough for the boiler to run check the time clock settings are on.
if these are working it could be a faulty diverter valve switch not sending a signal to the boiler to run.
Mar 23, 2009 | Water Heaters
Combi Boiler pressure gauge reading 0, and radiator half on!
The first thing you need to do is to put some more water into your heating system. This is usually done by allowing water from your (pressurised) domestic cold water supply to flow into the system: On older boilers, this is done with a connection (often made with a removable hose) on the pipework just outside the boiler. Newer boilers may have a built-in connection with some sort of removable link (sometimes looks like a plastic key).
Once you've got the boiler up to working pressure (typically about 1 bar - 15 psi), you should be able to bleed your upstairs radiator properly.
This may be all it takes, though the pressure excursions you're getting when you run the hot tap suggest there may be another problem. See what happens to the pressure as the boiler heats up and cools down. There really ought to be very little pressure difference between the two conditions. If you see significant changes, this usually means that the "pressure vessel" (or in hydraulic terms, system accumulaor) has lost its air charge.
The pressure vessel is a metal container inside the boiler, usually painted in red enamel. Somewhere near the top, you will find a schrader valve (like the one on a car tyre), and you can use this along with a tyre pump to replenish the air in the top of the vessel. This will reduce your pressure transients for a while, but you need to keep an eye on it. If the problem returns, you probably need to replace the pressure vessel (or clag another one into the plumbing alongside the boiler).
Feb 03, 2009 | ACCO Brands Water Heaters
Repressurise Potterton Performa 24 boiler
hope this is helpful. On my potterton 24 combi boiler it is the valve that sits the lowest, with a slight indent in the black tap. if you turn this for a short period you will hear a hiss and the pressure will quickly build to the desired pressure, when you can them turn the tap back off.
Jan 07, 2009 | Heating & Cooling
No hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Jan 03, 2009 | Combi Centre DX - Mango
Re pressurise the BAXI DUO TEC COMBI 28 HE A
I represurised mine by the following:
1. unscrew the left hand circular tap all the way
2. slowly unscrew the right hand circular tap untill you hear the water coming through.
3. turn off both taps when pressure is good
Dec 28, 2008 | Kitchen Appliances - Others
Combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Dec 22, 2008 | Water Heaters
Baxi/Potterton wall hung fan assisted combi boiler
does the boiler come on when the hot water tap is run if not change the hot water flow switch or the diaphram in the hot water flow valve it may be split
Nov 02, 2008 | Combi Centre DX - Mango
Baxi combi boiler 80e safty thermostat light on
baxi boiler relief valve blows off when heat is turned on when hot water is working it is fine
Oct 15, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Heating & Cooling Logo
351 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
