Question about Zojirushi NP-HBC10 Rice Cooker
Zojirushi does not work when plugged in. Timer still works
My zojirushi BBCC-S15 is working well even though the timer stays at 8:00 and this indicates the battery needs to be replaced. The machine does not signal any sounds during the different stages. Just what...
The battery is a back-up for the time display. Actual clock time, not the delay timer time. The battery also backs up any custom settings you created using the Homemade mode. Hope this helps.
Jun 23, 2011 | Zojirushi BBCC-X20 Home Bakery Supreme...
My rice cooker doesn't work... the clock doesn't work .... just completely no power. so where can I take it to get it fix from australia
The manual for your Zojirushi NP-HBC18 Rice Cooker can be found here:
http://www.zojirushi.com/servicesupport/manuals/manual_pdf/nphbc.pdf
Refer to page 12 of the pdf for Troubleshooting and page 13 for Error Displays
It may be that the stored Lithium Battery requires replacement.
Suggest you contact their Customer Service for information on the battery and how to replace and whether there are Service centers in Australia:
http://www.zojirushi.com/support/customer_service.html
Mar 15, 2011 | Zojirushi NP-HBC18 Rice Cooker
There is no response/change in the display when I plug the rice cooker in. None of the buttons are operational, yet the display still reads normally (time, timer), but does not change when I push any of...
You need to have the fuzzy logic board replaced. It will cost at least $50.00 according to the Zojirushi repair person I spoke with. I'm having the same problem. The buttons just stopped working.
Apr 04, 2009 | Zojirushi NH-VBC18 10-Cup Rice Cooker
Add in beep doesn't work
Assuming that you still have your instruction manual, it will tell you how long each cycle is so you can set a timer to let you know. If that is all that is wrong with it, it might be sufficient.
orleydog
Mar 29, 2009 | Zojirushi BBCC-V20 Home Bakery Traditional...
Not working
Please see weather any visual indications is turned on when u plug in the socket. Also see on what voltage it functions before connecting it to mains.
Thankyou
Feb 10, 2008 | Zojirushi NS-PC10 5-Cup Rice Cooker
Zojirushi BBCC-S15 Flashing Lights won't reset
Reading my manual...the built-in lithium battery can be good for 4-5 years. The blinking"8:00 am" would indicate the problem. I am at that point now, but to send in the machine to fix it would be a challenge...
Susanna
Nov 22, 2007 | Zojirushi Kitchen Appliances - Others
Zojirushi NP-HBC10 Rice Cooker Logo
108 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
30yrmech
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
