I have a panasonic fax UL700 and I need to know how to program it to recieve transmission reports when I send Faxes
    Genius:
  • 2,120 Answers
Function 74 set 12 set 2 set stop
Posted on Aug 29, 2008
SOURCE:
Hi could you tell me how to print the report for sending please to keep as proof to a number it was sent
Customizing the Transmission Verification Report You can use the Transmission Report as proof that you sent a fax. This report lists the time and date of transmission and whether the transmission was successful (OK). If you select On or On+Image, the report will print for every fax you send. If you send a lot of faxes to the same place, you may need more than the job numbers to know which faxes you must send again. Selecting On+Image or Off+Image will print a section of the fax's first page on the report to help you remember. NOTE:When the Verification Report is turned Off or Off+Image, the Report will only print if there is a transmission error, with NG in the RESULT column. 1 Press Menu/Set, 2, 4, 1. 2 Press ? or ? to select Off+Image, On, On+Image or Off. Press Menu/Set. 3 Press Stop/Exit.
Jul 21, 2011 | Brother MFC-620CN All-In-One InkJet...
HOW TO PRINT FAX CONFIRMATIN PAGE MFC440CN
To print fax send confirmation report:
You can use the Transmission Verification Report as proof that you sent a fax. This
(OK). If you choose On or On+Image, the report will print for every fax you send.
Choosing On+Image or Off+Image will print a section of the fax's first page on the report
When the Transmission Verification Report is turned Off or Off+Image, the Report will
Apr 12, 2011 | Brother MultiFunction Center MFC-440CN...
HOW TO PRINT CONFIRMATION PAGE
Apr 12, 2011 | Brother MFC 420CN All-In-One InkJet...
Brother IntelliFax-2820 Plain Paper Laser Fax does not automatically print a transmission report each time we send a fax. Is there a way to automatically have that happen. We can't find it.
You need to set up the Transmission Verification Report and Journal Period in the menu table.
-OR-
Press Menu/Set, 2, 4, 2.
Note
is a transmission error, with ERROR in the
RESULT column.
2 Press ? or ? to select On, On+Image,
Off or Off+Image.
Press Menu/Set.
3 Press Stop/Exit.
Printing reports
1.XMIT Report
2.Journal Period
Nov 15, 2010 | Brother IntelliFax-2820 Laser Fax
Unable to recieved any faxes or confirmation reports
Probably the back up battery is dead, and has been set back to default settings.
I can't help you with the method of setting, but it has switched to "manual receive", instead of "automatic", and "tx report" (transmission report) is off.
....and "no" you can't install a new battery yourself, and depending on the model, I doubt it's worth having repaired
Apr 02, 2009 | NEC Office Equipment & Supplies
Can't stop the transmision report - continues to print page after page
Make sure the transmitter knows how to send a FAX, i personally wasted a lot of time and paper because the sender doesn't know that the FAX machine had an automatic document feeder and that all pages has to be put in position before sending, and not page by page while sending.
Also see in the FAX manual if it can avoid printing the transmission report. Most Panasonic Faxes can do that.
May 05, 2008 | Canon FAXPHONE L80 Laser
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
Confirmation print out
Your wanting what Brother calls a Transmission Verification
Report:
RESULT column.
a Press Menu, 2, 4, 1.
b Press a or b to choose Off+Image,
Press OK.
c Press Stop/Exit.
Nov 11, 2007 | Brother MFC 240C All-In-One InkJet Printer
Brother Intellifax 1270e
Make sure ribbon is installed correctly. Also check inside the tray area to see if the rubber roller and or the rubber separator pad is dislodged. Obviously not worth repairing unless under warranty.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jul 09, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Open Questions:
41 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
