Question about Samsung LN-S2651D 26 in. LCD Television
My Samsung LN-S2651D has suddenly lost the picture. The sound works, the remote control changes channels, etc, the lcd backlighting seems to be on, but the screen remains black with no trace of an image. What part do I need?
  • 718 Answers
This sounds like the LCD Back light Inverter board has failed. The board may need to be replaced. (First check the menu option to make sure the Back-light option is not set to zero or a really low value !)
One test you can try is this.
With the set on place a bright flashlight against the screen. Look around the edge of the flashlight. You should see an image moving. You can not see the full image because the back light is off !
You can find inverter boards for your set from;
shopjimmy.com
Ebay.com
alltvparts.com
other sites by search the internet.
IF YOU KNOW HOW TO WORK WITH ELECTRONICS REPAIR( replacing board) or have a friend with knowledge/skill you can fix it.
>Unplug the set and disconnect any cables.
> Lay the set face down on a cloth covered smooth surface.
>Remove the back cover.
> Remove the metal shielding covering the board
> Disconnect the cables plugged into the board.
> Remove the screws holding the board in place.
> The new board should have the same part number as the board you are replacing.
> Install the new board with screws.
> Reconnect the cables.
> Replace the metal shielding covering the board
> Replace the back cover.
The Inverter board looks something like;
Posted on Apr 02, 2011
Samsung LN-S2651D LCD TV no picture
What happens when you turn the TV on? Is there a clicking noise or popping sound?
May 28, 2014 | Samsung LN-T4665F 46 in. LCD Television
There is a Video problem with my Samsung LCD. The sound is clear but Colour Balance Setting is disturb. The Colour is mixing with each other. Can You tell me the procedure for My TV Setting?
Before you set up try a reset
Resetting The Picture And Sound To The Factory Settings
as far as advanced settings are concerned, set the contrast backlight and brightness so you can see the best blacks without it looking too milky, the best whites so you can discern the whites and they aren't clipped, then look at colour balance if it looks wrong when you turn the colour off.
it shouldn't be very far out in factory settings. Operation How To Change The Picture Settings On Your LCD TV LCD TV...
May 12, 2014 | Samsung LN-S2651D 26 in. LCD Television
My samsung LN-S2651D Comes on with perfect picture then after 5 minutes or so picture strarts to get white snow going down the screen
Tuner fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 24, 2014 | Samsung LN-S2651D 26 in. LCD Television
Volume bar stands at 200 every time i start my Samsung LCD
set the volume down extremely low power the tv down by plugging out and put on again should be then at set volume,the tv's now days have memory so it should start up at volume preset
Dec 21, 2013 | Samsung LN-S2651D 26 in. LCD Television
My Samsung LN-S2651D has sound but no picture
Check with Samsung, this model should still be under the 3 year warranty. You are having a problem with the backlight power supply. You can look on the back of the unit for the manuf. date, if its less than 3 years then go to www.samsung.com and process the online service request form.
I hope this helps,if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 20, 2010 | Samsung LN-S2651D 26 in. LCD Television
Can't get HD cable channels on Samsung TV
Have you check with the cable company to make sure they are broadcasting to you in HD ?
It takes more bandwith so some cable companies will charge extra for it so you will have to check.
Apr 17, 2010 | Samsung LN-S2651D 26 in. LCD Television
How hard it is to replace by yourself main board Samsung LN-T4065
You need to do some more diagnosing of the problem. If you get sound and change channels take a bright flashlight and place it again the screen. Look for an image around the edge of the flashlight.
If you see an image that means the LCD controller board (TCON) is probably good.
The problem is probably one of three causes;
1) Inverter board is bad
2) CCFT (cold cathode fluorescent light) are bad.
3) Power to the inverter board is bad. You can also check the connectors.
Mar 30, 2009 | Samsung 32 in. LCD Monitor TV
Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Aug 24, 2008 | Samsung LN-S2651D 26 in. LCD Television
Samsung lcd tv
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 07, 2008 | Samsung LN-S2651D 26 in. LCD Television
Samsung LN-S2651D 26 in. LCD Television Logo
240 people viewed this question
Jerry Greenberg
Jerry Greenberg
