Question about JBL PSW-D112 Speaker
There is no power coming out of my jbl psw-d112 speaker...no cut cords, no shorts, is there a way to reset?
4 Suggested Answers
  • 4 Answers
SOURCE: JBL PSW D112 Distorted Sound
SYLVAN.
THE FILTERS /FILTRES ON YOUR SPEAKERS ARE TORN OR DAMAGED. IF YOU STILL HAVE WARRENTY ON THEY FROM JBL YOU CAN RETURN THEM FOR NEW ONES, PROVIDING THAT IS COVERED. IF NOT. I PERSONALLY RECOMMEND YOU BUY YOU SOME NEW ONES. REPAIRING WOULD BE OK, BUT IT WILL HAPPEN AGAIN VERY QUICKLY.
Thank you. Let me know what your decissions are
Posted on Nov 24, 2007
  • 14 Answers
SOURCE: power not working
If it is fused check to see if the fuse is blown... Start with power and work you way down from there.
Power to the sub.
Signal to the sub
Cabling to sub
Check the speaker itself to see if it is good.
john
Posted on Aug 20, 2008
SOURCE: JBL PSW-D112 Speaker fuse blow immediately after replaced
The Problem in this unit is the Amplifier module S64AMI,which is surrended in a black heatsink, filled with epoxy, not serviceable, the bad news is that JBL discontinued this module and is really hard to find, sorry....
Posted on Nov 21, 2009
Have a PSW-D112 sub woofer that needs a new amp. Repair facility says original amp took a catastrophic power surge and it's toasted. JBL says repair parts not available. Please advise on source for...
Go to Parts Express and buy the Bash 300w digital subwoofer amp.It fits almost exact except it is one inch shorter.Just use mdf to fill the space and this amp will outperform the original.I have done this and it's not really difficult,pretty straight forward.
They usually sell for around $149,but they have sales often around $99.Good luck.
Oct 28, 2010 | JBL PSW-D110 Speaker
I have moved from place to place...and all the sudden I can't get my jbl psw-d112 woofer to work....i took it apart and think maybe the blue and black wire came off the actually woofer...i need to know...
Are you not sure the wires came off? If they're off, reconnect them and get back to us. Absolute polarity doesn't matter. You can always reverse the phasing with the external Phase control.
When you say you replaced the fuse, was that a wild guess or was the fuse really blown?
Jun 20, 2010 | JBL PSW-D112 Speaker
When my jbl psw-d112 is on it will run just fine for a few min then it will sound like the speaker is blown. the green power light that is next to the vol level knob starts to turn red. What does this...
That model is known to have issues with the amps.Your problem is caused by a couple of components on the board shorting out.If you pull the amp out you will find on the large board behind the speaker terminal a couple of burned components.
The easiest fix is to buy a Bash 300w amp from Parts Express and replace the original amp.The Bash amp fits pretty well except that it is about an inch shorter.You can fill the hole with some mdf and have a sub that actually performs better than the original and with less heat build up as it is digital.Hope this helps,it's not complicated really.
May 01, 2010 | JBL PSW-D112 Speaker
JBL subwoofer PSW-D115
Hi Im a Certified Repair technician, I seen few problems with this unit, there is a amplifier module inside this unit, is really hard to find since JBL discontinued this almost immediately.
Sorry no really worth to bother........
Apr 10, 2009 | JBL PSW-D112 Speaker
JBL SUB ACR10 SUBWOOFER
I would suggest to check the rectifiers first, very unlikely that the capacitors became shorted.
Sep 04, 2008 | JBL PSW-D112 Speaker
Power not working
Power to the sub.
Signal to the sub
Cabling to sub
john
Aug 16, 2008 | JBL PSW-D112 Speaker
The fuse is designed to protect the circuit and prevent fire. When a fuse blows it is because it is getting to much current through it.
In some cases it could be because you replaced the fuse with one that did not meet the specs of the required fuse, there are different types of fuses and you should always replace with exactly the same type of fuse.
Do not replace with a higher Amp fuse, you could end up frying the amp at least. It's not a safe thing to do since there is an off chance of fire from using the wrong fuse.
If you have the right type of fuse installed and it is still blowing, then refer the unit to a qualified service center for repair, or look for a new replacement Amp.
john
Jun 27, 2008 | JBL PSW-D112 Speaker
your memory is low on resources need to increase memory.everything on ur pc uses mem.audio and video devices use an aweful lot.if you have open another program not only will ur audio be distorted but ur other program will be running slow.
correct? need to add more ram.
Mar 07, 2008 | HP Pavilion dv4000 Notebook
SYLVAN.
Nov 22, 2007 | JBL PSW-D112 Speaker
JBL PSW-D112 Speaker Logo
126 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
