I have a CAPF Goodman Coil that apparently needs cleaned due to lack of circulation. The repair company wants 1000 dollars. Is there a way to clean the coil on your own and there is warning label that references PSI. Is iit possible to clean the coil without breaking the lines? Is the PSI warning in reference to the lines or the removing of the panel?
    Scholar:
  • 133 Answers
I think you are referring to the Evaporator Coil on top of your furnace. If so, the PSI warning is due to the pressure inside the copper lines. The newer refrigerants can run over 400 PSI with the unit running. This coil can easily be cleaned by you if you go slow and be careful. Most Evaporators are installed in the plenum with no access provided. That drives up the time needed to get to it and close it up when finished. You need to cut a hole in the sheet metal for access. When finished, you will need to cover the hole. Its normally best to go in from the back. Directly opposite the 2 copper lines. Make a small hole in the center of the box (Plenum) about 2 inches above the furnace. That will start you above the drain pan and under the coil. Continue to expand the hole slowly, a little at a time, up and out, side to side. Find the layout of the coil. It will be either "45 degrees Horizontal" or "A" shaped. Mark the out side of the duct to match the position of the coil so you can be sure not to rupture it while cutting the rest of the access.Finish cutting the hole and look at the fan side of the coil. If its plugged, there will a thin mat of everything imaginable covering the bottom side of the coil. I normally use a stiff brush to clean off the mat. Be careful not to bend over the fins while brushing. A few won't make any difference though. Most hardware stores or Home Depot type places stock sheet metal and screws. Be carefull when driving those screws. If you do puncture the coil, keep a towel handy to throw over it. DON'T TRY TO STOP IT. Refrigerant will freeze skin on contact and it will be mixed with oil. Just take it slow and you will be fine. $1,000.00 is a good save.
Posted on Apr 02, 2011
  • Roger Jelinek Apr 02, 2011
    P.S. The Evaporator and copper lines are effectively one piece. I suggest going through the back because there is usually a metal plate around the lines on the inside that limits your work space. Also, the "Plenum" or Box is the thing on top the furnace the lines go into. Good luck!
Updraft evaporator pan cracked and leaked at male hose bib
Yes its possible to break it. Takes alot of force usually only happens during shipping due to hard fall.
Aug 29, 2012 | Goodman Manufacturing CAPF Cased...
New a/c goodman unit last year air coming out of vents not cold but everything seems to be running fine
Hello, this could be due to a lack of airlow or a low regrigerant charge. First check the air filter and make sure it is clean, make sure the blower motor wheel is clean and not dirty, also it would be a good idea to check tne evaporator coil and make sure it is clean. If the unit does not have any airflow problems most likely it is low on refrigerant due to a leak, in this case you will need a hvac tech to come out and repair the leak and charge the unit back up with refrigerant.
Jun 01, 2011 | Goodman CLJ36AR42 Air Conditioner
My 4 ton goodman heat pump goes into defrost and than after the cycle return in cooling stage at least the indoor coil starts freezing is the expansion valve working corectly
The reason for indoor coil freezing due to coil dust blocked-(Clean coil). 2. Less rpm of indoor f.motor. (Replace capacitor). 3. Short of gas. (Find leak and repair and then recharge gas.)
Jan 04, 2011 | Heating & Cooling
Furnace will run for couple of hours or day or two, then wont. honestly believe its the flame sensor, been watching it through panel..coil lights up, flame comes on, hence furnace runs..when it goes out,...
you will most likely break your flame sensor if you attempt cleaning it with sandpaper.
Make sure the sensor is cool and remove it. Clean the sensor with a dollar bill and clean the ground with sandpaper.
If it still fails, replace the sensor
Jan 17, 2010 | Goodman GMS90703BXA Heater
Goodman Model # cpke241AB not cooling always running
First locate the air handler.Open the access panel and you will see the evap coil.You will clean the coil in the unit,I use a wire brush and coil/evap cleaner.I dont typically clean the blower but if you must there will be 2 or 3 screws and some electrical that you will need to disconnect.then the blower assembly will slide out and you can clean it outside,Note where you disconnect the electrical connections --good luck!
Sep 08, 2009 | Goodman CLQ36AR49 Air Conditioner
The air conditioner is blowing very cold air
there are a couple of possibilities here. 1) lack of air flow, due to dirty filter, dirty fan blades/vanes, dirty coil, slow blower motor. 2) lack of refrigerant due to leak or starving metering device. The first one you can deal with: statrt by checking the filter; clean it if dirty. Is the air coming out slower than usual? If so the coil, (the piece that gets cold) fan is dirty; clean them. If it is low refrigerant you will need a professional to repair it or buy a new one. Hope this helps
Aug 17, 2009 | Kenmore 75085 Air Conditioner
I just installed a GSC140421 using a coil CAPF
hey there, the matching coil for your unit is a Model# CAPF4860C6A. The coil you have installed is a 13 seer where the condenser is a 14 seer. Myy guess at this point without being there is you have a hot house (80 psi suction) while eliminating more heat from the condenser (180 psi). I am also guessing you are using r-22? If you could post your super heat and subcool readings and if ou have a txv or fixed orifice (guessing txv?) I could help you pinpoint the problem.
seth
Aug 02, 2009 | Goodman Heating & Cooling
Changed the compacitor unit ran fine for half a day..then would not blow cold air..so i let it thaw overnight turned it back onit was fine..then after 5 hours..back to not blowing cold air..any...
if you let it thaw it sounds like your coil froze up
a frozen coil is usually due to lack of air flow (a dirty air filter or bad blower motor) if both of these are ok then you probably are low on refrigerant
i would suggest finding someone who specializes in goodman or someone who is certified to handle refrigerant to check your refrigerant pressures
Jul 29, 2009 | Goodman CKL24AR24 Air Conditioner
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
