Have a Belkin router F5D7633-4 but put disc in to set up for new vista pc but is coming up incompatible as previous pc was xp.Also currently running on laptop xp which is ok!Is there somewhere i can download to make compatible?Have tried Belkin website but no luck!
    Champion:
  • 232 Answers
Try microsoft for updates that may fix this problem,check your network setting to be sure u have the proper network option installed.compare the seting for the computer that is working correctly to see what may be configured different
Posted on Aug 05, 2008
My pc doesnt reconize the belkin easy tranfer cable?
you have to have xp or vista to use the cable,next you need the disc that came with it,next you need to follow these instructions to a t,
25765837-ob2lulsg2cxkr1k21bthn3kl-2-0.png if you dont have the disc,then d/l it here,
  • Download OS compatibility: Windows XP Service Pack 2 32 bit, Windows Vista Service Pack 1 32 bit; size: 26.1 MB
Multilingual version
  • Download OS compatibility:Windows XP Service Pack 2 32 bit, Windows Vista Service Pack 1 32 bit; size: 395 MB
  • follow instructions
Jun 29, 2015 | Belkin Computers & Internet
Laptop can't connect to DSL-G604T
You need to configure your router and use WPA encryption so that all accessing device can connect to it.
The obvious reason why the dell laptop can't connect is because of the WPA encryption set. It is different compared with what your router is actually broadcasting: WPA2.
So you can choose one of the 2 things to alter. Change your router's WPA2 encryption to WPA or change your Dell's setup to WPA2.
Mar 05, 2010 | D-Link DSL-G604T Wireless Router
Belkin N+N storage router doesn't work wirelessly
Hi, I had something like that with my Belkin Router N+N with USB F6D6230-4 V1, only I had a configuration wit a wired XP pc, Wireless XP and Wireless Vista. With both XP pc’s it was really plug and play, but with the Vista pc I had some problems to access the on the router connected USB drive. The Vista pc was connected to the network, and had Inet access. Other shared (network) drives were accessible on the Vista pc.
The first thing I tried was if I could access the drive trough its IP address, (\\routerIP in my case \\192.168.2.1), and I did get a question for a username and password. The only thing is that I tried all the regular names like Admin, Administrator, and so on, with my password but I did not get access.
On the internet there was no help to find for this model router on the Belkin websites (diverent country’s), the data on the Belkin websites is out of date, there is no support to find for new models. ………. So finely I did took the phone and did call the support desk…
Solution to my problem:
The problem seems to be in the Belkin storage manager program, that program works not correct under Vista. When I enter the routers IP and use the username “guest” without a password, it get access to it from my Vista pc. The follow thing I did was press the right mouse button on the drive, and press on “make connection” So..
\\RouterIP
Username : guest
Password : none
Hope, that this is also the solution to your problem.
Greatings
Martin,
The Netherlands.
Feb 23, 2010 | Computers & Internet
Change of current belkin N150 password.
Contact Belkin for Care at 1-800-585-2494 Toll Free.
Sep 14, 2009 | Belkin (F5D8231-4) Wireless Router...
How do i install my new belkin systyem when ive
yes you can use it.
first connect your Belkin router to computer with lan cable .
Then access it wityh this link.
http://192.168.15.1
user name as "admin" and password as "admin"or
blank or
"password"
then configure your router as your old lynksys settings.then save settings and restart .
Aug 22, 2009 | Belkin N1 Vision Router
Two pcs running vista home edition wired to router ok. laptop wireless ok. advent pc running windows xp wireless cannot see belkin router but can see outher router in my area. router is a belkin N wireless...
Check the router settings, if the router is set to only use 802.11N wireless it won't pick up a computer that is using 802.11G or 802.11B wireless.
Good luck
Nov 14, 2008 | Belkin Computers & Internet
How do I copy the security key?
the solution to this one is you need to reconfigure the router. you need to disable the security settings for your router. (WEP or WPA) then try to put in a new SSID and new security key. that's the only way that you can get a new security/passphrase key for your network. for further assistance you need to contact the router manufacturer for router configuration.
i hope this helps.
Sep 13, 2008 | Computers & Internet
We have purchased a new notebook{higrade brand vista OS} to replace a packard bell using XP the XP laptop connected no problem the newone finds the belkin router but won't connect to the internet are...
Do you have a wireless security protocol enabled, and if so, what? Install a wired connection to the router (use an ehternet cable to connect your laptop's RJ-45--looks like a wide phone plug--into one of the Belkin router's network jacks). Go to the router's management page using your web browser (probably http://192.168.2.1). If you have not previously set the password in your router, simply leave the password field blank and CLICK "Submit". If you have previously password protected your Belkin router, use the known password. If you have forgotten your password... you'll need to reset your router.
Reest Router: there is usually a small hole into whiuch a pin or paper clip can be inserted for this purpose or a small button to press. Most Belkins--IIRC--have the button.
Once you are on the Belkin router's management page, look for the wireless link and set your security protocol to match what your wireless card is capable of, set the password, save and exit. Use the sasme password in configuring wireless networking in Windows.
Jul 17, 2008 | Belkin Computers & Internet
Belkin wireless g problem
well..that passphrase is from a secure connection..you might need to get a new set of drivers, and re install that router.
go here for those drivers(look for Belkin router)
Mar 25, 2008 | Computers & Internet
Belkin N1 Vision - unable to see networked printers
Go on the main PC and Press Start, Control Panel, Printers and Faxes, Right-Click On The Printer You Want To Share, Properties, Sharing...
... If it comes up ( If it doesn't skip to the next part )...
49a8fc3.jpg ... Click on "If you understand the security risks but..."
Click On...
Click Share this Printer, Apply, Ok. Now look on your laptop for network places and you will see the printer on the network.
If you need to contact me email jordylap1@fsmail.net
Jan 21, 2008 | Belkin (F5D5231-4) Router
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
