Question about Sony WEGA KZ-32TS1 32 in. Television
I have Sony TV KZ-32TS1E and recently I'm having problem with the sound. Sometimes the sound disappear from out of the blue. I have to switch the TV off and let it switched for a while. Than,when I switch it on again the sound sometimes come up to life again. Is it worth to fix the TV?
5 Suggested Answers
SOURCE: Problem w/blue "bleed" on LCD TV screen
Sony has acknowledged this problem as being a defect in the optical block and has extended the warranty replacement on this part till december 2008. I have the kdf50we655 and had the same problem. It was repaired for free, but would have cost me about $1500.
Posted on Mar 23, 2008
  • 13 Answers
SOURCE: lose sound on sony bravia 40v4100 lcd tv
if you are using an hd cable box it might be just that. what happens is if the cable company is doing work around your area or some one on your block adds another cable line to there house you end up losing signal for your box. now if you pull the power plugg and let it reboot that could either fix the problem temporarly or not at all. you might need an amplifier hooked up to your cable lines or a new cable box all together. contact your cable provider and ask for some one to test your signal quality. i am also assuming that your not getting the same problem when your watching a dvd. i hope this helps you
Posted on Jan 26, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony KDL40S2010 Bravia LCD TV... turns off / on on it's own
If TV does not remain in standby and turns on itself then power switch on top of it could be defective and power supply board is also suspected. Take off its back cover and unplug top switch connector just to confirm is that cause of On-Off its own. If problem still exist then power supply board has problem and will be replaced. Let me know the results to move forward.
Posted on Jun 13, 2009
kidsasuke
  • 121 Answers
SOURCE: KZ-32TS1e cracked speaker grill.
If you can find a junker, you could rip one out of it. Try asking local repair shops if they have any dead units that they're just going to pitch. You should also figure out the dimensions of the grill, in case you have to find an improvised one from another set.
Posted on Jun 04, 2010
Jun 04, 2010 | Sony WEGA KZ-32TS1 32 in. Television
Permanent blue haze on screen; looks like
The fact that you continue to have sound while the picture disappears points to one of three potential issues.
Issue 1: the LCD Panel.
Issue 2: The Inverter Power Boards (though these tend to cause power/shutdown/no video at startup than video distortion)
Issue 3: the Time Control Board - a small board at the top of the LCD panel on the back that relays data to the rest of the screen.
Any one of these three repairs, you should call Sony if the unit is outside of manufacturer's warranty. They are expensive to perform, and the parts are not cheap. Hopefully you have an extended warranty to help with the issue.
Jan 24, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
52'' sony tv rear projection turns blue
it sounds like the blue crt is failing Pull the front off and turn the tv on
When it still has a good picture tap the blue crt
if it flashes blue with lines across the screen then you know it is a bad crt
It might not be worth fixing
Good luck
Jan 26, 2009 | Sony KP-57HW40 57" Rear Projection...
Loss of Sound on Sony Receiver
Did you get the switch replaced?
Jul 02, 2008 | Sony STR-DE835 Receiver
Error Code 5 flashes when unit shuts down
Good Day;
It sounds like the TV may have a shorted CRT, picture tube, but let's trouble shoot:
1. Unplug TV from wall.
2. Remove speaker grill, two on bottom, the screws are covered with plastic caps, right and left side on bottom next to floor.
3. Remove inner panel.
4. The blue tube is the one the right side, remove socket, with phillips driver, make sure it's not touching anything.
5. Plug and turn TV back on, if picture appears with no blue it's the tube.
6. If still shuts down, bad blue CRT driver IC.
CAUTION: Call a factory authorized service dealer to give you an estimate, if this sounds too hard.
Good Luck, Day, Big Irish.
Jun 18, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony trinitron 29 inch kv j29mn
Possibly dry solder joints or faulty coupling capacitors around the audio section.
Jan 20, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Black box showing up while viewing DVDs
Go to your TV remote, in the menu find the closed caption or sometimes it is on the remote itself. Turn off the closed caption. this should solve your problem. Good Luck
Mar 28, 2007 | Sony DAV-C990 System
Sony WEGA KZ-32TS1 32 in. Television Logo
174 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
