Question about Fisher and Paykel Fisher & Paykel Washer
When I turn on a Fisher Paykel smartdrive 601 no lights etc come on (that is turn it on at the pwer point).
  • gavin691 Apr 02, 2011
    are they worth replacing? Or best to replace the whole machine?
    very useful, just wondering what else I could try before deciding to replace the machine
    President:
  • 1,554 Answers
Make sure first that the circuit breaker is not tripped and there's power at the power outlet. Flip the breaker off then on again and if the machine still doesn't turn on lift the console up into service position. The problem is likely in the motor controller module, display module, or the wire harness connecting the two. Check the motor controller module and the display module for burn marks particularly the former. Also check the condition of the wire harness connecting the two including the connectors.
The motor controller module is most the likely burned out. It has been found that water damage or short circuit on the drain pump motor leads to the burning out of the motor controller module. Make sure the drain pump is good and not leaking before replacing the motor controller module if found burned out.
Let us know if you need further advice. Please accept the solution should you find it helpful or informative. Accepting the solution will not stop you from communicating with the expert. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Apr 02, 2011
  • Jahn27
    Jahn27 Apr 02, 2011
    A leaky in the thermistor seal will also cause the motor controller module to burn out. Water may accumulate and pools up in the area where the motor controller module sits.
  • 4,323 Answers
Hi
The power board is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 01, 2011
  • 1 more comment
  • Daniel Scott
    Daniel Scott Apr 02, 2011
    Replacing it will cost you around $200 if your get this done by a professional
  • Daniel Scott
    what happen? you did not find this helpful?
  • Daniel Scott
    Replace the power board....no light are coming on so the control board (power board) is dead....post back for further assistance
Smartdrive 601 leaking
If the tap is leaking replace the washer in hose end. It's a common garden hose washer. If you mean there is water in the tub your inlet water valve needs likely needs replaced.
Jan 11, 2013 | Fisher and Paykel Fisher & Paykel Washer
Hi I have a Fisher and Paykel Smartdrive 601, and the cold water is dribbling out when I put it through a cycle, do you know what the cause is, and how can I fix it??
Your cold water valve is not seating when off,
Try swapping the hot valve for the cold to see if that will fix the problem. if it fixers the problem buy a new cold valve.
Oct 13, 2012 | Fisher and Paykel Fisher & Paykel Washer
Washing Machine F&P MW511. Washed, then rinsed using the fabric softener, partially spun then stopped. Will not turn on at all now (no power)
Hmmmmm - I think you may actually have a faulty controller module - without a working module it generally means no power on etc for Smartdrive washers..
Jun 26, 2011 | Fisher and Paykel Fisher & Paykel Washer
Fisher paykel smartdrive 601
I can talk you through diagnostics if you want to go on live chat cheers
Mar 13, 2009 | Fisher and Paykel Fisher & Paykel Washer
Fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Mar 12, 2008 | Washing Machines
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
