Question about Sun MySQL
MySQL data types
When i create a table, and run SHOW CREATE TABLE on it, sometimes the results are different than what i typed.
What is the reason for the change in the data?
  • 30 Answers
These are the types i know
1.VARCHARs with length less than 4 become CHARs
2.CHARs with length more than 3 become VARCHARs.
3.NOT NULL gets added to the columns declared as PRIMARY KEYs
4.Default values such as NULL are specified for each column
If there are more i'm sure folks around here will post them.
Posted on Aug 11, 2008
How can I restore my SQL database from .frm files?
You just copy the .frm files to the to the databse folder but you also need to copy the ib_logfiles and ibdata file into your data folder. I have just copy the .frm files and copy those files and just restart the server and my database is restored.
Best Professional Resume Writing Service Online from Washington USA...
Oct 22, 2015 | Oracle MySQL Enterprise Ed 1-4 Socket...
Tip
Dreamweaver Thought that Teaches You, to search a database with phpmysql...
OK, this should work... First of all, there is one great extension for DW & PHP ADOB object model that is free and great! Download it and install from www.interakt.ro its called PHAKT (NOT impakt, because its not free).
Install it and you will have another type of PHP ADOB document type.
Start project with PHP ADOB (not old PHP MYSQL).
Page 1
Create form that has come Editbox and one button. Name Edit box something like e.g. "Search" without quotes.
That form should have form action="results.php" and type set to POST NOT, Create Page 2 and name it results.php.
Create new recordset in dw like this
SELECT "
FROM table WHERE table.column.you.r.searching LIKE '%colname%' OR table.other.column LIKE '%colname%' ORDER BY table.tableid this means that we want to select ALL (*) records in table WHERE content of column is similar (Dav, will return Dave, David, Davidof...) to search keyword.
Next, in variables click + and add variable name colname default value set to % if you want to show all records if form is submited blank, or -1 if You want to show none if form is submited blank. Finaly for Run-time value type $HTTP_POST_VARS['search'] Runtime value is equal name of Edit box name you set up in first page...
Now, from bindings tab, select values and insert it on page, that You would like to show on page. Ill skip this part assuming You know how to format output and how to limit it but if you dont know ask in reply...
So now You have page with results. Test it and see if its working.
If it is, create page 3 and name it details.php. Now, select value from page that you want to link with details page and click on link. Select details.php page and click on parameters. For param name enter something like id since this should be PK in table and unique value, and for value click on lightning icon, and select primary key in your table. In live page link should be like details.php?id=<some_value>.
As for details page recordset it should look like
SELECT *
FROM table
WHERE table.id = 'colname'
create vars as for page 2, but change Runtime to $HTTP_GET_VARS['id']
and format output on page. That should be it, but since im typing it in "realtime" maby i forgot something...
Home I did helped You.
on Jan 21, 2010 | Computers & Internet
How to restore MySQL database Windows tool?
You can restore corrupt and delete SQL database file in few steps for MySQL Restore Toolbox. With this software you can also recover triggers, keys, indexes and table. Software support multiple MDF file recovery option. Software is supported by all Windows operating system. Get more ideas and download free trial version from -http://www.filerepairforum.com/forum/databases/databases-aa/mysql/1162-dump-mysql-database-file-is-error
May 29, 2015 | Sun MySQL
How to fix mysql error 1046?
For the database import, before you attempt to import the "flat" file data in, you need go to your local DB (MySQL) and create new database
After that you can import!
Also check this links:
http://www.repairtoolforsql.fixtoolbox.com/ Fix Toolbox for MySQL
http://www.sqlservercentral.com/Forums/Topic1618894-2893-1.aspx
Apr 09, 2015 | Quest Software Toad for MySQL
How to fix mySQL corrupt databases?
you should follow two steps:
Create an appropriately named database on the target machine
Load the file using the mysql command:
$ mysql -u [uname] -p[pass] [db_to_restore] < [backupfile.sql]
Have a look how you can restore your tut_backup.sql file to the Tutorials database.
$ mysql -u root -p Tutorials < tut_backup.sql
To restore compressed backup files you can do the following:
gunzip < [backupfile.sql.gz] ' mysql -u [uname] -p[pass] [dbname]
If you need to restore a database that already exists, you'll need to use mysqlimport
command. The syntax for mysqlimport is as follows:
mysqlimport -u [uname] -p[pass] [dbname] [backupfile.sql]
Or make use of Repair Toolbox for MySQL
Demo version is here-: http://www.sql.repairtoolbox.com/
Feb 08, 2015 | Microsoft SQL Server 2000 Standard Edition...
How to make a 7 row and a 7 coloum in a spreadsheet
Creating a table in Microsoft Excel 2007 allows you to work with that data independently of the rest of the worksheet. First you must define your table, though, which you can do either from scratch or from data already in the worksheet. The process is a simple one. Read on to learn how to define a table in Excel 2007
  • Start off by doing one of the following: Select the range of cells that you want to make into a table within your worksheet then proceed to Step 2 OR Start immediately with Step 2.
  • Click on the "Insert" tab at the top of the document.
  • Find the "Tables" group, then click on "Table." The "Create Table" dialog box will appear.
  • Type in a range for your table if you did not select a range in Step 1. If you did already select a range then that range will automatically appear in the dialog box.
  • Check the "My Table Has Headers" box if the data set you selected already contains the headers you want to use. If you don't check this box, the table will display default header names, which you can then go in and change.
  • Hit the "OK" button at the bottom of the Create Table dialog box to create your table.
  • Thanks for choosing Fixya............ Sandeep
    Mar 18, 2011 | Computers & Internet
    How to invoke a ms.access using parser
    To parse a Text field that contains two words separated by a comma, follow these steps:
    1. Open any existing database.
    2. Create a table with the following structure: Table: Parse2Words
      Field Name: Empl
      Data Type: Text
    3. View the Parse2Words table in Datasheet view and type the following three records in the Empl field: Smith, John
      Callahan, Laura
      Fuller, Andrew
    4. Create the following query based on the Parse2Words table: Query: QueryTest
      Field: FirstName: Right$([Empl],Len([Empl])- InStr(1,[Empl],",")-1)
      Show: True
      Field: LastName: Left$([Empl],InStr(1,[Empl],",")-1)
      Show: True
      NOTE: You can modify the QueryTest query to account for spaces between the two parts in the Empl field. For example, if the text in the Empl field is "Smith,John" without spaces, remove the -1 from the FirstName field expression.
    5. Run the query. Note that the QueryTest query separates the text in the Empl field into the two fields below: FirstName LastName
      John Smith
      Laura Callahan
      Andrew Fuller
    Jan 08, 2011 | Microsoft Office Access 2003 (077-02871)...
    Table Repair MySQL
    MySQL offers Check Table syntax that checks a table or tables for errors. It works for several storage engines like MyISAM, InnoDB, & Archive. If you run this syntax then you can the cause of problem & reported tables.
    If Check Table finds errors then you can repair reported tables by Repair MySQL Table syntax.
    Aug 06, 2008 | Sun MySQL
    MySQL Crashes
    could you give me more info plz
    Jul 28, 2008 | Sun MySQL
    Running SQL queries on Excel
    Another way to do it is to use the SQL Drill freeware Excel addin (http://www.sqldrill.com)
    hth
    Aug 14, 2007 | Microsoft Office 2003 Basic Edition...
    Sun MySQL Logo
    76 people viewed this question
    Top Sun Computers & Internet Experts
    Cosma Papouis
    Cosma Papouis
    Robin Hill
    Robin Hill
    Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
