Hi, I need to relocate the split air conditioner, but I don't know the first step and next steps. Thank you,
    Scholar:
  • 133 Answers
If you are not a service technician you probably won't have the tools you will need to accomplish the move. Here is what it takes, step bye step. 1. Pull the fuses or turn off the electrical breaker in the house. 2. Hook up a gauge manifold to the Condensing unit ports for the liquid and suction lines. 3. Hook up a Refrigerant recovery machine to the manifold. 4. Recover the refrigerant into recovery tanks down to a trace, no vacuum. 5. Disconnect the electrical whip and control wiring from the condenser. 6. Close off the service valves on the liquid and suction lines at the condenser. 7. Slowly unscrew the copper line connections to the condensing unit to relieve any pressure that may exist from Refrigerant boiling out of the oil in the compressor and quickly cap them. 8. Move the unit to your new, firm and level location. 9. Remove the old electrical disconnect and whip and move it to the condenser. 10. Buy a new line set of the proper length or extend the old one with Refrigeration copper and couplings preserving the condenser couplings. 11. Replace the liquid line drier and reconnect the copper lines to the condensing unit. Replace the "O" Rings if needed to insure a good seal. 12. Hook up a vacuum pump to your gauge manifold. 13. Open the isolation valves on the condenser. Depending on the oil type in the system, evacuate to 250 Microns. 13. Charge system with 50 pounds of Nitrogen and a little Refrigerant for a trace test. 14. Watch your gauges for a drop in pressure indicating a leak. 15. Check all fittings and any splices with a good Halogen gas detector. 16. Evacuate the system again to the point of vaporization of the oil in the compressor being careful not to boil it off. 17. Close off all ports on your manifold and install a small drier to your Refrigerant line. 18. Re-install the recovered Refrigerant, running it through the small drier on your manifold. 19. Re-check for leaks. 20. Install the electrical whip on the contacter and the control wires on the contacter coil. 21.Start the AC and check the running amps against the name plate Full Load Amps (FLA) or Regular Load Amps (RLA) and check the Refrigerant charge against the units chart. Either in your owners manual or glued to the electrical access cover.
Method 2 = Instead of recovering the refrigerant, you can pump it into the condensing unit. With your gauge manifold tied in, close the liquid line isolation valve. Run the compressor till the compound gauge reads 1 pound and close the suction line isolation valve. Doing it this way will eliminate the need for the recovery machine and heavy tanks. All else remains the same.
Special tools needed = Compound gauge (meaning it reads both pressure and vacuum). High pressure gauge, gauge manifold and at least 3 hoses, a vacuum pump, leak detector (or soap bubbles) and an amp probe. Please rate this response. Thanks for asking!
Posted on Apr 02, 2011
How can uninstal and shifting split air conditioner
This is not a DIY job. You need equipment to remove the A/C gas before dismantling the A/C system and after relocating and installing the A/C the system needs purging of air and then re-gassing.
I suggest you get an A/C installer to do this work.
Apr 05, 2013 | Heating & Cooling
I have a tempstar 2000 heat pump approx. 6yrs.We have the compressor go bad 3 different times and replaced by the original installer.Now Action Air of Florida says they don,t know why so many compressors...
no compressors don't just go bad first of all is unit a split system or a package unit.if its a split system need to make sure copper from evap.coil to outdoor unit sized properly.next need to make sure your ductwork is sized properly undersized ductwork makes comp. run much harder.sounds like non-condensibles in system
Mar 22, 2012 | Heating & Cooling
Dalkin VRV system air conditioner not cooling
Most the time when unit does not get cold,but air is still attempting to blow air, it is because it needs to be cleaned. Sometimes filter or vents are dirty. Try and use a can of compressed air and blow it out real good, next step is check the thermostat to see if you hear a click sound when turning it to a certain temp. If not, it can be the switch it self or the relay that triggers it. If you can give me a few more details of what it is doing or not, maybe I can get down to the root. In other words, you say it does not get cool. But, does it blow air>? fans turning? fuses ok? right source of power to it (amps?) mike
Nov 29, 2011 | Cfm Daikin R410a Split System Air...
Hi, I have a Daewoo air conditioner split (model dsb-070L/dsb-091L/dsb-070LH/dsb-091LH, I'm not sure about the exact model number). The remote is not working anymore, and I don't know why;...
Hi Josematamoro
Did you find a solution to your problem. I have the same problem and not sure what to do. I have contacted a airconditioning maintenance person who said he would try and look for the part to fix it.
Cheryl
Jul 31, 2011 | Heating & Cooling
Hi do you fix suspicious gas leaks? Not sure what the problem is but everytime the ducted heating comes on there is a gas smell coming out of the vents? I am guessing it is a gas leak. This problem...
With the AC on check to see if you are getting a 20 degree split between the supply air and the return air if so no worry's. The smell is most likely dust burning off the heating coils let it go for a bit and it will go away if its dust
Jul 04, 2011 | Heating & Cooling
Need a new remote
I would contact your local LG. Also many electronic places sell universal ac remotes (check the packaging to ensure that it can control LG's). The universals are cheaper and easy to set up (they come with step-by-step setup instructions). Hope this helps I take the time to answer your question so please rate me
May 28, 2010 | LG Art Cool LA121CNP wall/window Air...
The air conditioner unit is not coming on. had message to change batteries in wall control changed batteries but unit will not come on Kelvinator DS3BC
Hi, Have you checked to see if there is power to this unit? I have not looked up the type of system you have, wall/window unit, central split system and so on. If the thermostat display said weak batteries and you installed them, it should start if it is programmed properly. If it is, the next step is to determine if it has power. If it does and will not start, we need to troubleshoot further into it. Get back to me on this. Let me know the type system you have. Thank you,
Shastalaker7
May 08, 2010 | Heating & Cooling
How to clean my samsung aircondioner unit?
HI, Step 1 Your first step to getting your air conditioner to run better is to do proper maintenance. First turn the unit off.
  • Step 2 Next, you will need to remove the filter and see if it needs cleaning. Most time this alone can make it run better. Sometimes more is needed.
  • Step 3 If cleaning the filter worked, then you are done. If not the following steps can be followed. Unplug your unit.
  • Step 4 Remove it from the window.
  • Step 5 Using the tools needed, take the casing off of the unit.
  • Step 6 Set the casing aside. Look at the unit itself, is it covered in dust and build up? If so, taking a cloth gently clean off the debris.
  • Step 7 If you notice that there is more debris covering the unit all over, you can take a water hose and spray out the unit. Although this is not recommended, I have done it in an attempt to getting mine up and running.
  • Step 8 Once you have cleaned the unit itself. Take the glass cleaner and cloth, cleaning both inside and outside of the casing. Allow it to dry for a few moments then reassemble. Plug in your unit and check to make sure it is working before putting it back in the window, there isn't needed in putting a unit in that still doesn't cool.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • If cleaning the unit doesn't help it to work better, than having it serviced by a tech is a must if you choose to keep and not replace.
    • Again I do not recommend the water hose. I done it myself risking tearing the unit up completely.
    thank you,
    vijay (vote for me)
    Sep 24, 2009 | Samsung Heating & Cooling
    Hi we have a ge air/cond split system which i want to move to another position i know the system does have an accumulator in the main unit i just wanted to know how to reclaim the gas back into the...
    need gauges attatched to the low side (Fat pipe)at the condenser unit which is outside.Use the allan key and close off the high side(small pipe ) at the condensing unit. With the unit running watch the gauges untill needle reaches 0. Quickly close valve off on fat pipe and then switch off. You can then dissmantle and relocate unit. Note, before opening valves again, you must pull a vacume to remove moisture otherwise you will have no end of problems.
    Sep 14, 2009 | GE Heating & Cooling
    Heating & Cooling Logo
    281 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Donni Steen
