Question about Home
I can remove the tub jets in a 1990 Hydroswirl whirlpool tub but would like to remove the brass trim. Any ideas on how to remove trim? Same for trim on air control valve?
4 Suggested Answers
frcs68
  • 1605 Answers
SOURCE: I want to change the brass colored suction, jets....
call whirlpool or go to local bath and kitchen shop or local plumbing store. they should be able to give a price and tell you how to change all of the items.
Posted on Dec 04, 2008
  • 81 Answers
SOURCE: where can I buy just the brass trim on the jet for
The trim for any brand whirlpool (w/p) tub must be ordered from that specific tub manufacturer. They will need to know exactly what your particular model is.
The model of your w/p tub, and serial number, is most often, but not always, located on the motor end of your unit but not on the motor itself. Access to this end of the tub, if installed to code, should get you the information you need, otherwise you are out of options'
Posted on Jun 03, 2010
uspartscente
  • 717 Answers
SOURCE: I have a 13 yr old royal whirlpool tub and the tub
yes. you can locate those parts online @ http://www.uspartscenter.com/royalbath.aspx
these guys can help you source the trim pieces you need.
Posted on Jan 07, 2011
The jets are cracking and coming loose from the tub, why and what is the fix ?
This cracking of jet trim is common. It is caused by the trim being too tight on the fitting of the tub.
You can change the trim on your tub by matching up what you have in your tub to what is shown online or email me photos and I will match them up for you.
uspartscenter@gmail.com
Rod
US Parts Center
Nov 06, 2013 | Home
Have an older jet spa tub where do I get new gold rings for around jets
Click on the Link below. Jet Trim have to be matched up by sight.
Find the brand name of your bahtub and click on the name.
http://www.uspartscenter.com/category-s/4954.htm
Match up each item in your tub to what is shown online.
If you are unable to match the pieces up to what is shown online to what you have in your tub you may email us photos and we will match them up for you.
send photos to: photos@uspartscenter.com
Rod
US Parts Center
888-521-6183
Feb 20, 2013 | Home
I have a 14 year old Aker whirlpool tub. During bathroom remodeling, I found a leak where the pipe comes out of the jet. I could not repair it. Are the jets available yet? I found two numbers on the...
Jet bodies match only the jet trim that goes with them. These are a set and are not interchangeable with other models or brands of jet. Each Bath Part in unique in subtle ways only.
In order to find the correct jet body you need to match up the face of the jet trim to what is shown online. Once you know that brand of jet trim we can find you the correct jet body.
I would invite you to search our site at US Parts Center and see if you can find the jet face that you have.
Once you do we will be able to match up the correct jet body for you.
Rod
US Parts Center
888-521-6183
Jan 15, 2013 | Whirlpool Royal A-909 Bathtub
How do you remove and clean, or where do you find replacement jet knobs for americh jetted tub?
their jets un-thread counter clockwise. you will need to contact Americh directly. they will be able to sell you new jet trim.
Feb 19, 2011 | Americh Madison 2 6036 Bath Tub
I have a 13 yr old royal whirlpool tub and the tub is in great shape but the jet trim has colored. I would like to get the jet trim but I can not seem to find it any where. Any suggestions?
Jan 07, 2011 | Whirlpool Home
Where can I buy just the brass trim on the jet for my whirlpool tub (aker)?
Jun 03, 2010 | Whirlpool Royal A-909 Bathtub
How to remove jet rings on jetted tub
It depends on the brand of jet and tub, if it is a gold or silver trim ring, they will generally pry off with a screwdriver, just be careful not to damage the tub when doing so. When prying, move the screwdriver around the jet an inch at a time, just like opening a can of paint. Some rings will screw on, but most just pry off.
Mar 24, 2010 | American Standard Home
Jets don't work in the jetted tub.
First the obvious, most are electrically connected to a ground fault device, ether an outlet or a breaker. BEFORE ADDING WATER, check these out to make sure they are not tripped. Most all tubs have a minimum water level which must be reached before the jets will operate. This is usually a piece of trim located above the depth of the jets. Make sure the tub is filled to cover this part. If you cant identify the water level device fill the tub so that all the jets are covered by an inch or 2. Some tubs have push button switches or touch pads to control the motor, some have touch sensitive trim. There may be some sort of medallion from the maker on the tub, simply touching it will start the tub. Once you get it going most tubs have a built in timer that turns off the pump in 15 - 20 minutes. For more tub time just hit the switch again but keep in mind that extended exposure in a hot tub can mess with your blood pressure and cause you to loose balance or pass out, hence the 20 minute timer.
Mar 22, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
Nov 29, 2008 | Whirlpool Royal A-909 Bathtub
Home Logo
73 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
