Question about Intermatic & Indoor/Outdoor Rain Tight Timer
Using manuelly, but when I flip the switch, the same zone keeps coming on. Will not switch zones. model T8805P101C
I would be interested to know if the pump does same thing when timer operates circuit instead of using switch?
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Posted on Apr 10, 2011
HOW TO SET TIME AND DATE ON LG FLIP PHONE 441g
Check your manual for guidance. How can anyone help without the model number? Duh!
Sep 19, 2017 | LG Cell Phones
I have a Carrier heating unit in my attic ,
zone controller might be stuck seek help from service co.
Mar 25, 2015 | Carrier Heating & Cooling
How do I set the alarm on my Sharp Accu-Set Model SPC452?
  • 1 Insert batteries into your atomic clock. Without these the clock won't work. The number of batteries required depends on the clock. There is usually a panel on the back of the clock where you can insert the batteries.
  • 2 Set the clock. Usually, this is done automatically, as the clock will seek out and receive the signal within 6 to 8 minutes. If this doesn't happen, you'll need to do it yourself. Hold down the "Set" button. A figure on the clock will start blinking. Adjust this by pressing the adjustment button. Press "Set" again to go to a new time. Continue until the clock is properly set. No matter what you put time you put in manually, the clock should adjust to the atomic setting within 48 hours.
  • 3 Set the time zone on your atomic clock. How to do this depends on your specific clock. On some, there is a time zone slider; you simply slide it to your time zone. Otherwise, you will need to enter the manual mode you used to set the clock. Switch the mode until the time zone starts blinking. Now, adjust until your current time zone is selected. If it goes by Greenwich Mean Time (GMT), the time zones in the United States are -5 for Eastern time, -6 for Central, -7 for Mountain, and -8 for Pacific.
  • Read more : http://www.ehow.com/how_6403731_instructions-time-zone-atomic-clock.html
    Jan 29, 2015 | Audio Players & Recorders
    How do I set the time zone? It run out of battery so when I changed it, the time zone is pacific and I need to change it to mountain time.
    To change the time zone, open the control compartment cover on the bottom of the clock. Locate the "Time Zone" switch and set it to the appropriate time zone for your area. Six time zones are programmed into your clock, "A" for Atlantic, "E" for Eastern, "C" for Central, "M" for Mountain, "P" for Pacific and "H" for Hawaiian. Once you've chosen the correct time zone for your Brookstone digital desk clock, you must select whether you want the clock to operate using the 12-hour or 24-hour format. The clock is set to the 12-hour format by default. If you'd like to change the setting to the 24-hour format, locate the "Time Format" switch on the bottom of the clock and flip it to "24-hour".
    You can also decide whether to turn your clock's automatic Daylight Savings Time feature on or off. If you turn the feature on, your clock will automatically move forward by one hour at 2:00 a.m. on the first Sunday in March and fall back by one hour at 2:00 a.m. on the first Sunday in November. To choose your preference, locate the "DST" switch on the bottom of the clock and flip it to "Autoicon1.png" or "Off".
    Read more: http://www.ehow.com/way_5585650_brookstone-digital-desk-clock-instructions.html#ixzz2phA7kQ1b
    Jan 07, 2014 | Brookstone Self-Setting Atomic LCD Clock
    How do i set time zone for model # WRC
    When the clock is NOT trying to sync with the atomic clock in Denver, press the + button to change the time zone. The default is P (pacific time).
    Jul 24, 2012 | SkyScan Audio Players & Recorders
    I have a Onkyo TX-SR604 Receiver. I get no sound
    Hello Fixya customer,
    Thank you for your question.
    A point to keep in mind here is that Zone II will only feed through an analog source. Since the Video 1 input is using the digital (coax, optical) input that that is your most likely issue.
    Thank you for using Fixya, and please let me know if I can firther assist.
    May 01, 2010 | Onkyo Audio Players & Recorders
    My Denon AVR2308 is frustrating me. I am running two zones (5.1 in main and zone 2 out of rear surround). I have made the audio setting to allow Zone 2 on/off, but i am stuck on how to turn sound off in...
    Greetings,
    Unfortunately the AVR2308 does not have the zone 2 video output connector needed to pass video to a second zone. The AVR2808 was the first receiver in that year lineup to offer a video output to a second zone. There are many different types of video outputs on that receiver, but they are all associated with the Main zone. This is why you loose the video when you shut down the Main zone. With respect to your Zone 2; the small remote that came with the receiver should have all the power and volume features you need to operate Zone 2 while keeping the Main zone turned off. The only audio that can be passed to Zone 2 though has to be in an analogue format (using the red and white RCA connections). This receiver does not pass digital audio onto Zone 2. Best of luck!
    Aug 21, 2009 | Denon AVR-2308CI
    Denon AVR-3805 zone 2 no longer working
    time to reset the microprocessor. See page 87 in manual.
    1) switch off the unit using the main unit's power operation (small power button)
    2) hold the PURE DIRECT button and DIRECT button at same time and turn the main unit's power operation on.
    3) wait for entire display to flash in 1 second intervals
    now the speakers need to be set up again but zone 2 will be working. i suspect a power surge causes the microprocesser to be corrupted. i put a power surge protector and have not had problems (lately).
    Dec 29, 2008 | Denon AVR-3805 Receiver
    Hacking code for Teac PL-D3200
    Multizone code for Teac PL-D3200
    Here is the procedure to unlock your Teac PL-D3200 to play all zones of DVD's.
    Using your remote control:
    1. Switch power on 2. Open the dvd tray (leave it open with no dvd in it) 3. Press "stop" 4. Press "734466" 5. Use cursor to scroll up or down until it says "Region 0" 6. Press "OK/Enter" 7. Switch power off 8. Switch power on
    It will now play all region DVD's! :-)
    Sep 16, 2007 | JVC TH-S8 System
    Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
    61 people viewed this question
    Top Intermatic Hardware & Accessories Experts
    Craig Butler
    Craig Butler
    Gene Haynes
    Jay Finke
    Jay Finke
    Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
