Question about Dell Dimension 2400 PC Desktop
Lights a&b r yellow lights c&d r green - Dell Dimension 2400 PC Desktop
    Problem Solver:
  • 5 Answers
According to this Dell troubleshooting page, your memory (RAM) modules are producing the error.
You should first remove and re-seat the modules to see if that will correct the error. This page will walk you through how to open your computer and how to remove and reinstall your RAM.
Since your computer is a few years old, check for oxidation on the contact points (the gold points where the RAM is inserted into the motherboard). If the contacts are not bright and shiny, take a pencil eraser and gently rub the contacts to remove any oxidation. Use a can of compressed air in short bursts and blow off any left over eraser shavings from the RAM module before you reinsert them.
If oxidation is not a problem, you may need to replace the RAM modules. I purchased this RAM for my 2400 a few years ago. Keeping in mind this RAM is a few generations old now, 1GB is the most effective size and price point for the RAM required. I am not affiliated with either Corsair or Newegg, but they are both excellent in what they do and I have used the site and products almost all my builds. Also, when installing RAM I try to use pairs so I have a little redundancy if one should fail.
Posted on Apr 04, 2011
Diagnostic lights a green, b & c orange
Rear Lights Dell Computer Error Codes
Rear LEDS are labled A through D and can change from green to yellow. Some typical LED reading might be:
A - yellow, B - yellow, C - green, D - green <-- Indicates a problem with the RAM.
A - yellow, B - green, C - yellow, D - green <-- Indicates a problem with the video card.
Refer to the Dell website for your specific model, as these lights can vary from model to model.
see more from this site
Jan 16, 2014 | Dell Precision Workstation 670 PC Desktop
Rear harness was bad they replaced with trailer harness and trying to fig out what yellow brown light green an dark green are on frame of truck it hooked in to so i can fix i un hooked not knowing what had...
Your description, I take it, is a problem with the wiring harness going from the driver's compartment to the rear lights. If that is the case, the normal color code for GM is brown for tail lights, dark green for the right stop & turn, yellow for the left stop & turn and light green for the backup lights. Any black wires should be grounded. The white wire in the trailer harness is for a ground when used on a trailer. It sounds like you have the green and yellow T&S wires shorted together somewhere! Some of the later vehicles use separate stop and turn bulbs... these would have a separate wire for the stop lights only, but I don't think your truck is new enough for that. Good luck!
Nov 25, 2013 | 1993 GMC Sierra
Wiring schematics for a kenwood kdc-mp145 to a 1998 ford ranger
Battery light green to yellow
Accessory yellow/black red
ground black black
Illumination light blue.red orange/white
Power antenna amp=blue blue
LF + orange/light green white
LF - light blue/white white/black
RF + dark green/orange gray
RF - white/light green gray/black
LR + gray/light blue green
LR - tan/yellow green.black
RR + orange/red violet
RR - brown/pink violet/black
Sep 21, 2010 | Car Audio & Video
My friend's PS3 has some light of death we are guessing! It will turn green, then will turn blue & green, then it turns green & yellow, then it turns blue & yellow. Then just yellow followed by...
This is known as the yellow light of death (ironic i know because it blinks a red light). This is caused when the unit overheats causing solder on the board to melt and bridge(connect). Once this happens it shorts out the board causing the error you have now. Contact Sony and see if the unit is still under warranty.
Feb 10, 2010 | Sony PlayStation 3 40GB System
A digram for the factory wireing for the radio
This color code works for 87-93 mustang factory radio; it might work on yours as well. I'm not sure if it has the same fuses though.
Radio Connector:
Light Green / Yellow - Hot at all times (Fuse 8)
Yellow / Black - Hot in ACC or Run (Fuse 11)
Light Brown / Red - Goes to instrument panel dimming rheostat (Fuse 4)
Red - Ground
White / Purple - Hot in ACC or Run (Fuse 11)
Speaker Connector:
White / Light Green - (+) Right Instrument Panel & Door Speaker
Dark Green / Orange - (-) Right Instrument Panel & Door Speaker
Brown / Pink - (+) Right Rear Speaker
Pink / Light Brown - (-) Right Rear Speaker
Pink / Light Green - (+) Left Rear Speaker
Tan / Yellow - (-) Left Rear Speaker
Light Brown / White - (+) Left Instrument Panel & Door Speaker
Orange / Light Green - (-) Left Instrument Panel & Door Speaker
Hope this helps.
Aug 15, 2009 | 1991 Ford Econoline
Need color code diagram for sterio
I'm not sure what year you have but this color code works for 87-93 mustangs.
Radio Connector:
Red - Ground
Speaker Connector:
Hope this helps.
Jun 19, 2009 | Ford Escort Cars & Trucks
Need fuse block diagram for a 1991 Plymouth Voyager
Cavity
1 20 amp yellow hazard flashers
2 10 amp red heated mirrors
3 20 amp yellow body lights
4 not used
5 20 amp yellow windshield wipers
6 20 amp yellow turn signal lights
7 10 amp red radio
8 not used
9 7.5 amp violet illumination lights
10 2 amp pink left tail lights
11 2 amp right tail lights
12 not used
13 20 amp yellow rear window wiper/washer
14 2 amp pink speed control
15 10 amp red gauges, warning lights
16 not used
17 10 amp red left low beam headlight
18 10 amp red right low beam headlight
19 20 amp yellow stop lights
20 20 amp yellow rear a/c heat
21 20 amp yellow fog lights
22 20 amp yellow park lights
23 20 amp yellow battery
24 20 amp yellow back up lights
25 circuit breaker power windows,power vent windows
26 30 amp lt. green a/c heater blower motor
27 circuit breaker power door locks
28 not used
May 21, 2009 | 1991 Plymouth Voyager
Need a radio wire diagram for 1989 ford mustang 5.0
Radio Connector:
Red - Ground
Speaker Connector:
Apr 04, 2009 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
Radio wiring
The factory wiring connector hook-up for the Mustang is:
Radio / Power Connector:
Red - Ground
Speaker Connector:
Your best bet is to buy a radio install kit and adapt it to the Mustang connector. Hope this information helps.
Oct 19, 2008 | 2002 Ford F250 Super Duty SuperCab
Dell Dimension 2400 PC Desktop Logo
32 people viewed this question
Alun Cox
