Question about Crosley Dryers
I need to change the wire to a 4 wire instead of a 3 wire were does the green wire go
  • 2,418 Answers
The green wire is a ground wire. 4 wire hook ups usually have a terminal with a hook or a 90 degree bent tab that one is the ground.
Posted on Apr 01, 2011
I need to change my 3 prong to a 4 prong
Unplug the dryer then remove the terminal block cover and disconnect the 3-prong cord from the dryer. Note that the cord has red , black, and white wires but sometimes the red and black wires are both replaced by same color wire, usually gray and can switch places. There's also a ground strap wire also connected to the center terminal together with the white (neutral) wire.
Get yourself a 4-prong cord and note that it has red, black, white, and green/yellow wires but sometimes, like the 3-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect the 3 wires in the same manner they are connected as 3-prong cord to the terminal block. The ground strap wire now just need to be connected to the remaining 4th wire, the green/yellow wire instead of the center terminal together with the white (neutral) wire. Reinstall the terminal block cover and it's done.
It can be observed that converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4 whereas, on the other hand, converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3.. The links below might enlighten you further on this matter.
Four-prong to Three-prong Electric Dryer Conversion
Three-prong to Four-prong Electric Dryer Conversion
Aug 21, 2011 | Kenmore Dryers
I am replacing a 3 prong cord with a 4 since we have moved into a newer newer home and the dryer has a white wire attached to the frame instead of a green wire. Is the the ground and can I just place the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 23, 2010 | Roper RES7646KQ Electric Dryer
I have a 3 prong to change to a 4 prong cord on my dryer
The following link explains how to correctly install a 220VAC appliance cord to your dryer:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Read through the instructions provided and let me know if you have questions. This advice is how to convert from a 3 prong to a 4 prong appliance cord. You simply match the corresponding colors of the wires on the cord you intend to attach to the matching colors at the terminal block on the back of the dryer. If the wires are not color coded at the terminal block, the outer two wires (left and right) are the HOT leads, the center wire is the Neutral. Make sure the neutral ad ground wires remain independent of each other in a 4 wire configuration. The green wire should be terminated on a ground lug on the equipment cabinet while the neutral is terminated at the terminal block.
Let me know if you require further assistance. I hope this help you.
Feb 06, 2010 | Dryers
I have a 3 wire dryer and need to convertto a 4
The following link explains how to correctly install a 220VAC appliance cord:
Match the corresponding colors at the terminal block, making sure the Neutral (White) and Ground (Green or Bare Copper) wires are NOT terminated together.
If you have any questions, please post back and let me know. I hope this helps you.
Feb 03, 2010 | Kenmore 62602 Electric Dryer
Need to change from 3 prong cord to
disconnect the green or brass ground strap from the terminal block to the body then wire the new plugs three colors the same as the old then connect the green from the plug strait to the body. on a 3 wire the dryer is grounded through the neutral, on a 4 wire the ground goes to the body.
Dec 02, 2009 | Dryers
I am changing out the dryer cord on my Whirlpool electric dryer from a 3 prong to a 4. there is a green wire with a yellow strip coming from the dryer and grounded on the side of the dryer like a grounding...
Hello. Now that you are upgrading to the four prong you should unhook the green wire with yellow strip coming from the dryer and instead attach the extra green ground cord on the 4 prong to the screw on the side of the dryer. Regards, Joe.
If you prefer to see this in picture form, check this link: http://www.appliance411.com/links/jump.cgi?ID=466
Nov 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My Maytag MEDC400VWO dryer needs the 4 wire instead of 3 wire hookup. I have it, but not the manual. How do I hookup the 4-wire and in what order onto a 3-wire dryer?
red and black wires go to terminals marked L1 and L2 hook these up either way its not critical, then white is the neutral and goes to the N terminal then green is the safety ground and it should be connected to a terminal that attaches to the units frame
Sep 17, 2009 | Dryers
Wireing
3-pair version of (red/green, black/yellow, white/blue). But the first two pairs are not twisted
So it becomes green/red, yellow/black, & white-black/blue. G1/ R2 /3Y /4B /5*Blk/6Blue (this is what you physically see on the other RJ11 connections since this is a data connection and not a phone connection it should be a straight-through instead of cross-over connection.
These RJ 11 PINOUT assignments may be incorrect because they apply to a color camera instead of B/W
1 SPEAKER (+)
2 VIDEO_OUT
3 GND
4 SPEAKER (-)
5 AUDIO_OUT/ALARM_OUT
6 12V DC
Back of Camera
Clip up, contacts down
123456
RJ11-e starts off like a RJ45 Stranded Patch Cable.
The color code used in stranded patch cables is different from solid-conductor cables. For NorTel Digital Patch Cable (DPC), the coding is; Pair 1: Green & RedPair 2: Yellow & BlackPair 3: Blue & *Orange White\Black
*In Pair 3 the color coding is Blue & Black instead of Blue & Orange and the pair is twisted so that the Blue wire is the 6th pin instead of the 5th pin.
Jun 27, 2009 | Samsung Weather Resistant Security Camera...
Trying to change from 3 prong to 4 prong and there are 4 wires to connect to back of dryer.
511ca90.jpg It should go something like this ; depending on the brand and age. just remember, white in the middle ; this is the most important thing.
Aug 12, 2008 | Dryers
Cooktop WIring
To complying with changed Codes (effective in 2002 ) regarding stoves, ovens and dryers. You will need a 120/240 volt 4 wire 40 amp and 50 amp circuit. This
Decades ago it was permitted to use a 3 wire system (having two 120 volt hots (Black and Red) and 1 combination ground/neutral wire) (green and white) to serve stoves, cooktops, ovens and dryers.
The Code change now requires all stoves and dryers in NEW construction to have the 4 wire set-up (now having two 120 volt hots, 1 white neutral and one green or bare wire ground).
Existing wiring is grand-fathered under the Code change.....I advise you to change the feed wiring over to the the 4 wire set-up...
because - as with ALL Code changes in the past...it will eventually become mandatory for all stoves, ovens and dryers as the grand-father clause drops off. By complying now...
BUT the wiring will need to change to 8/3 with ground. (having 4 wires inside one outer jacket).This is the primary reason for the Code change....to provide a greater margin of safety to the user.
I can NOT recommend the 3 wire hook-up...the 4 wire provides a seperate ground and neutral -
which makes the chance of a user shock when touching the metal frame (from an internal fault in the oven) much less likely then the old 3 wire set-up....
which did NOT have the seperate ground and neutral.
Krazytech
Apr 05, 2008 | Whirlpool 30 in.GJC3055 Electric Cooktop
Dryers Logo
49 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
charles
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
