Question about Proform 530 Treadmill Walking Belt
I have a proform lx 550 treadmill it will go sometimes and other times it wont the light comes on the trackpacer when plugged in and display comes up but belt wont go sometimes
  • 16 Answers
SOURCE: Proform 515s treadmill motor won't start
If the colse buttons make a chirping noise when you push them the console should be Ok. If there is no chirping noise with the push it is a bad console. If everything but the speed works it will probably be your motor controller that is bad.
Posted on Apr 14, 2009
  • 19 Answers
SOURCE: proform treadmill belt won't stay centered.
Adjust the tension on the right side rear using an allen wrench. Try 1/4 turn clockwise( should tighten). then run tread mill for 30 sec. to see if it centers itself. repeat again if not. if its to tight then turn the left side in a 1/4 turn
Posted on Apr 28, 2009
SOURCE: Proform 520
Not sure what's happened here. treadmill won't turn on when red key is inserted. checked electrical plug to make sure it worked. I couldn't see that there's anything wrong with the red key. Have any ideas?
Posted on Sep 12, 2009
  • 64 Answers
SOURCE: Proform Crosswalk Dual Motion Cross Trainer
I think you are talking about the front roller. It has a rubber sleeve that helps to grip the walking belt. Sometimes you can tighten this enough to keep it from slipping but you run the risk of overtightening and damaging both rollers. We recomend replacing that roller.
Posted on Nov 18, 2009
SOURCE: treadmill belt runs very slow and stops when I get on
proform 625 belt slips cause
Posted on Jan 28, 2010
Proform perspective 1.0 lx console cycling off and on
There may be a problem with the wire lume that connects the LCB to the console.
Nov 10, 2013 | Proform Exercise & Fitness
What is the power source for the display console of a proform 650 cardio crosstrainer elliptical? The display on mine is not on.
you must see the schematic diagram coming with your treadmill, or read your owner manual, and follow the instruction in section assembly or parts manual
God bless you
Nov 01, 2013 | Proform 650 Crosstrainer Treadmill
Control panel lights up but not responsive on any function
The proform console sometimes freezes up and refuses to take the input from the user. Replace the console. The manufacturer do not sell parts for this console.
May 19, 2013 | Proform Pro Form 785ss 785 Ss Treadmill,...
I have a Proform xp 550 the incline won't go up...it was starting to go up then made a noise and it dropped down ... how do i fix it?
RUN the software calibration for diagnose, troubleshooitng, fix it.
2) Lube the gear+shaft from elevation Motor
3) adjust the POT from elevation motor, see diagrams attached.
God bless you
Aug 02, 2012 | Proform XP 580 Trainer Treadmill
Hello! We have a ProForm 550 treadmill. No matter how many times we straighten and tighten the belt, it immediately moves to the side rendering the treadmill unusable. Any thoughts regarding what is...
several things could be happening, 1) the rear end caps that hold the roller can be broken not keeping in adjustment the roller. 2) the walking belt bad. 3) roller back or front worn(less likely). also make sure if your belt(the new one if you need it) uses lubrication or not.
good luck to you.
Feb 08, 2011 | Proform Exercise & Fitness
How do I get the proform xp 550 to unfold?
The pin should come out easily. If not, see the manual you can get at www.iconservice.com or maybe Treadmill Parts
Sep 11, 2010 | Exercise & Fitness
I have a pro-form 550 XL treadmill its in #10 deg. incline and wont come down. The motor keeps running trying to incline more and wont shut down or lower the incline. Reset it talked to sears rep. and they...
i ran into the same problem today with another proform model. i shut the machine off and lifted the platform to the stow position and brought it back down, turned it on. it worked fine during a workout. i was using an ifit sd card when it got stuck. were you? just wondering.
Feb 03, 2010 | Exercise & Fitness
Won't turn on at all.
If you have no lights, check the main harness that cary power to the console. Check connection at both ends.
PS Always check outlet to make ssure you have 120 volts.
Jul 24, 2009 | Exercise & Fitness
Pro-Form XP 550 Troubleshooting
My Proform 550 doess not work the treadmill is not getting any power. Wht might the problem be.
Apr 27, 2009 | Exercise & Fitness
Proform 530 Treadmill Walking Belt Logo
47 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
