Question about 1401 Remote Start/Keyless Entry System
I am trying to find the valet switch on my car so I can set up a replacement transmitter.
    Problem Solver:
  • 18 Answers
The valet switch on that model is part of the "control center". The antenna, LED and valet switch is all one piece and is most likely mounted on the top edge of the windshield by your rear view mirror. There's a small behind right by the flashing LED light. That's the button for programming different features of the system and programming in remotes. Hope that helps.
Posted on Apr 02, 2011
RS855LCD 2-way remote and key fob dreain batteries
I see this is a old post but, I have this unit in a used van that came with no remotes. A local audio shop paired it up with a AUTOPAGE XT-33. I can lock,unlock,start with this remote. Just remember to keep the drivers open while doing these steps.
1. Turn the Ignition 'switch 'OFF/ON' 3 TIMES and stay in
ON position. Within 15 seconds.
2. Push the Valet switch 2 times and hold in on the2ndpush, when a long chirp is heard then release the valet
switch. You are now in the Transmitter programming mode.
Program:1. Press the Lock button on transmitter 1 until the siren
responds on Car with a confirming chirp; the first
transmitter is now programmed to Car.
Exit: Turn Ignition to 'OFF' position, or leave it for 15
seconds. 3 long chirps will confirm exit.
Note: If more than 4 transmitters programmed, the system
will only keep the last four.
The Valet switch is a little Red Push Button that should be
mounted under the lower left side of you dash or in the lower
left kick panel near the E-brake pedal.
Jan 14, 2012 | RS855LCD AutoPage MultiChannel 2 Way...
Tip
Dei viper python valet hornet boa transmitter programming help
DEI REMOTE PROGRAMMING INSTRUCTIONS
Need a DEI Remote Replacement Now? Try our all New Remote Quick-Find
Not sure what type of Replacement Remote you need?
In order to enter Learn Routine, the Valet/Program push button must be plugged
into the main brain's Blue 2 Pin Port (Look for a small black push button located under
the drivers dash or drivers kick panel somewhere). If you do not have the Valet/Program switch, you may order it at www.lesscoelectronics.com or www.lesscosales.com
1)
Open a door and make sure the dome light is on.
2)
Turn the ignition on to the RUN position or you may also start car.
3)
Within 15 seconds press and release the Valet/Program push button
to select the channel you wish to program. For example, press and release
once for channel 1 (arm/disarm channel).
For Channel 2, press and release twice (trunk release).
For Channel 3, press and release three times (remote start).
(Some DEI systems require different programming for different channels. You
can get specific installation manuals with remote programming instruction)
Press and hold the Valet/Program push button once more. You should get a
confirmation chirp/horn-honk or a flashing LED light (If installed).
If you do not get a chirp/horn-honk the alarm may have a jumper in
the alarm that has the programming feature turned OFF (disabled).
4)
Once the alarm chirps/horn-honks keep holding the Valet/Program push button.
5)
Press the button on the transmitter that you would like to control the selected receiver
channel. A chirp/horn-honk will confirm that the code has been learned. If programming
more than one transmitter repeat step 5. Old transmitter codes will be dropped only
if programming 4 new transmitters.
6)
Once the code(s) are learned, the Valet/Program push button can be released.
Learn Routine will be Exited if:
Ignition is turned off
Door is closed
Valet/Program push button is pressed too many times
More than 15 seconds elapses between steps
One long chirp/horn-honk indicates that Learn Routine has been exited.
on Jul 29, 2010 | Car Audio & Video
Need to know how or get instruction to program new auto page xt-100 oled remote starter.
REMOTE TRANSMITTER PROGRAMMING Enter: 1. Turn the Ignition 'switch 'OFF/ON' 3 TIMES and stay in ON position. Within 15 seconds. 2. Push the Valet switch 2 times and hold in on the 2 nd push, when a long chirp is heard then release the valet switch. You are now in the Transmitter programming mode. Program: 1. Press the Lock button on transmitter 1 until the siren responds on Car with a confirming chirp; the first transmitter is now programmed to Car. Exit: Turn Ignition to 'OFF' position, or leave it for 15 seconds. 3 long chirps will confirm exit. Note: If more than 4 transmitters programmed, the system will only keep the last four. The Valet switch is a little Red Push Button that should be mounted under the lower left side of you dash or in the lower left kick panel near the E-brake pedal.
http://www.autopageusa.com/resources/2%20Push%20transmitter%20PROGRAMMING13.pdf
This sis atndard programming for the 900,915,1000,and 100 units.
Feb 12, 2011 | RS1000 OLED 2Way OLED Remote Start w 6...
How to reprogram my remote for car
http://www.autopageusa.com/resources/2%20Push%20transmitter%20PROGRAMMING12.pdf
Dec 28, 2010 | C3RS727LCD 4Channel Alarm with Remote Car...
Program remote
Enter:
1. Turn the Ignition 'switch ‘OFF/ON’ 3 TIMES and stay in
2. Push the Valet switch 2 times and hold in on the 2nd
Program:
Jul 09, 2010 | RS855LCD AutoPage MultiChannel 2 Way...
How to re program my pager? (autopage 1000
Enter:
Program:
Jun 03, 2010 | RS1000 OLED 2Way OLED Remote Start w 6...
Program replacement remote
Enter:
Program:
May 21, 2010 | RS1000 OLED 2Way OLED Remote Start w 6...
Remote says OUT OF RANGE when i try to arm it.
Reprogram the remotes using this procedure:
Enter:
Program:
May 07, 2010 | Megatronix - TW71 - 5 Button 2 Way LCD...
How do I program a Viper 473 V Replacement Remote, to my 2004 Hyundai Santa Fe?
Set lock/unlock button
· open drivers door
· turn key to ON position
· press valet switch 1 time
· press valet switch again and hold
· when alarm chirps press lock/unlock on remote
· release valet switch
· turn key off
Oct 05, 2009 | Viper Security and Remote Start System...
Need to program autopage 5b remote
Note: This mode will only retain the last 4 remote transmitters programmed. If the transmitter memory is exceeded,
the security system will start deleting transmitters from memory in chronological order.
1. Turn the Ignition 'switch ‘OFF/ON’ 3 TIMES and stay in ON position. Within 15 seconds.
2. Push the Valet switch 3 times and holding in on 3rd push until a long chirp is heard then release the valet switch.
3. Press and hold any button of the transmitter until the siren responds with a confirming chirp, indicating the signal
has been stored into memory.
4. If you have additional transmitters (up to 4) that need to be programmed, repeat step 3 for each transmitter.
Exit: Turn Ignition to 'OFF' position, or leave it for 15 seconds. 3 long chirps & 3 parking
light flashes will confirm exit.
Feb 17, 2009 | Megatronix - TW71 - 5 Button 2 Way LCD...
1401 Remote Start/Keyless Entry System Logo
270 people viewed this question
Top Python Vehicle Parts & Accessories Experts
rjivaro
Kevin Daniels
AzVip
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
