Question about JVC Cameras
I have not used my JVC500 camera for about 6 months. When I switch it on after it boots up the screen shows the message 'lens cap' but after I remove the lens cap there is still no image showing on the screen. Is this just a setting which needs to be changed or does the camera have a problem ?
  • 17,970 Answers
If your camcorder is still under warranty, send it before it's to late. There is some kind of wide spread problem with the CCD Assembly on this line of JVC products. In particular with the GR-DxxU line.
From what I have read in the internet, the CCD Assembly is a Sony part and can be purchased for about $50. If you are handy with electronics, you could give it a go. This repair if successful, will probably not last for to long either.
I have the same problem with this camera and it's a shame that JVC is not doing anything about it. I read somewhere that there is a pending class action law suit against JVC on this line of products.
Sony has also released a statement with one of their camcorders, that they will fix the problem at no charge. Can't remember the link but it's on this site.
If you can't find the answer to your question? To contact JVC Product Support Call your Customer Care Center at (800) 252-5722
Hope this helps.
Posted on Apr 01, 2011
Hi there, i have a problem with my GZ-MG21u. error in HDD and always says"please remove lens cover".i tried to switch in sd card but still black screen appears.please help me to resolve so that i could...
On some cameras the lens cover engages a small censer that gives the message remove lens cap. fit and remove the lens cover a few time this may work , if not the censer may be at fault.
Dec 20, 2014 | Video Cameras
Finepix gives message to turn off then on again. keeps foping it no matter what.
It may be your lens cap. If the lens cap is on, the lens cannot extend, so the camera will give you notice to turn the camera on and then off again (assuming you know that you must remove the lens cap before turning on again. If your lens cap is off, check to see if there is anything else blocking the lens or impeding it from extending.
Aug 27, 2011 | FUJIFILM FinePix S4000 / S4050 Digital...
My camera keeps showing the message System Error (Zoom)
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Jul 14, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
Sony HDR-XR200 lens cover problem
You have two options, replace the motor that opens and closes the lens cover or remove the lens cover shutters all together, and use a 30mm lens cap.
May 25, 2010 | Sony HDR-XR200V High Definition AVCHD...
Lumix keeps showing message 'remove lens cap and press > button
1. Power off
2. Remove the battery.
3. Put the battery to its place
4. Power on
5. If nothing happens
6. Replace the battery with charged one
7. Power on again
It should be work.
Mar 26, 2010 | Panasonic Lumix DMC-FZ3 Digital Camera
My Nikon Coolpix L100 flashes a lens cap error
Hello
Regards
Andrea
Jan 02, 2010 | Nikon Coolpix 5700 Digital Camera
JVC GR-D270 MiniDV camera i dont see nothing to my lens
You have an internal "lens cap" that covers the lens to protect it when it is not in use. Look around the front of the camera, near the lens and you should find some sort of switch or lever that will open the lens cap.
Dec 28, 2008 | JVC GR-D22U Camcorder
FZ18 Lens Cap error message with telephoto converter
I have the same camera, and had the same problem. Make sure the camera is switched off. Then take 2 hard pieces of plastic with sharp ends. Carefully try & jam the outer ring with one, and try turning the converter with the other. I used a mini screwdriver, and left some marks on my camera. Thats why I recomend using plastic of some kind.
When you use the converter, switch off the battery saver in the camera. That way the converter won't jam again, as the camera won't switch off automatically. There is also a programme in the menu that is used for converters and external lenses. It also prevents the lens from retracting completely.
Hope I have helped you.
DaveSA
Mar 21, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
Cameras Logo
19 people viewed this question
Top JVC Cameras Experts
Michael Galve
Michael Galve
Parshiv Luthra
Are you a JVC Camera Expert? Answer questions, earn points and help others
