Question about Cuisinart Grind Brew DGB700 12Cup Coffee Maker
Hi, Our Cuisinart DGB700 (second one now in 2 years same problem) has gone out again.The grinder works but the heating element won't come on and brew the coffee. Is there a fuse or replacement element that can be purchased to repair the unit? Thanks Steve
4 Suggested Answers
SOURCE: Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Posted on Jan 16, 2009
  • 13 Answers
SOURCE: Cuisinart coffee maker turns on but will not brew.
Well, you could try unplugging for an hour. Sometimes that helps, but these have been having a lot of problems (but don't ask their customer service that, they can't admit it but I'm pretty sure they all know it!). I would say call customer service anyway if it's under 3 years old (800-726-0190) after you've unplugged it and let them know what's going on (model and serial # are both located on the bottom of the unit, stamped in the black part). If it's under warranty they can offer you a replacement and from what I hear Cuisinart has been getting in new coffee on demand units (like the one you have) that have fixed the problems. They're on back order right now though, so there will be a wait. Other than that, I would say you don't have many options, unless the store is willing to take it back, because this one is pretty much a goner. Not the first time I've seen it. :(
Posted on Aug 28, 2009
  • 7 Answers
SOURCE: the coffee machine (cuisinart) shuts off by itself
DCC-1200 shuts off: How to fix it
A couple of weeks ago my DCC-1200 began shutting off in the middle of the brew cycle, a problem commonly reported here. I love my DCC-1200, and it ran like a top for the 8 years I've had it. Luckily I have a backup coffee maker, so I was able to take the time to find a fix rather than having to drop another hundred bucks on a new one. I hope this helps some of you.
Behavior: The coffee maker began shutting off during the brew cycle. The whole machine would go dead, including the LCD display. Changing outlets did not solve the problem. Unplugging it and plugging it back in sometimes helped, sometimes not. Left plugged in, sometimes the power would restore and it would work for a time. This got progressively more frequent, though right before it quit working all together I was able to turn it on by pressing the self clean button. Pressure on the faceplate right above that button would shut it down again. I discovered this while following norm49629's advice on cleaning the machine. After removing the faceplate, I could see that any pressure on certain areas of the circuit board would restore or cut power to the entire unit. These experiences led me to conclude that there was an issue with the circuit board. Please be reasonably sure this is the same problem you're having before beginning this repair. My coffeemaker was out of warranty and I had nothing to lose.
If this is your problem, you will be baking the circuit board to repair micro-fissures in the circuitry which are interfering with its operation. These fissures are caused over time by the repeated heating up and cooling down of the coffeemaker when you brew. To do this repair you will need to remove the faceplate, so I am including instructions for that based on my experience with this issue as there were none to be found on Fixya when I looked.
To remove the faceplate:
You will need a tiny standard screwdriver (I used one from an eyeglass repair kit) and a smallish philips screwdriver. Begin by removing the carafe, the basket (and permanent filter, if you have one), the water filter, and the insert on the underside of the flip-up lid. With the lid open, you will notice two round screw covers towards the front of the coffeemaker to either side of the filter basket. Remove these with the small standard screwdriver. This is impossible to do without damaging them somewhat. Remove the two philips screws underneath.
There are nine clips that need to be released to remove the plastic top of your coffee maker. First, press in on and release the two located on the back just below the lid hinge. With the small standard screwdriver, gently release the six clips along the top edge of the casing. These are located two in back, near the corners and two along each side. You will have to get up underneath the plastic bezel, be gentle so that you do not bend the stainless steel housing (if you do, gently bend it back into place before you put everything back together). Lay the coffeemaker on its back. The final clip is located in the carafe “nook” to the back of the drip outlet. The upper plastic portion should now lift straight up out of the coffeemaker.
With the coffeemaker upright, remove the four philips screws holding the faceplate in place. Remove the faceplate by pulling it straight out towards you. Unplug the circuit board. Remove the three screws holding the circuit board I to the faceplate, being careful not to lose the three clear plastic washers. Remove the clear plastic switch (for the function knob) by releasing the clips.
These baking instructions are based in part on the many tutorials to be found online for repairing video and graphics cards. Preheat your oven on its lowest setting, preferably 170˚. Place a piece of aluminum foil on a cookie sheet. Tear off some extra and make three small balls of foil to place the circuit board on. With the circuit board LCD up, position the balls under the upper corners and the center bottom, away from anything important.
Bake at 170˚ for 10 minutes. Allow to cool and put your coffeemaker back together. Brew a nice fresh cup for your efforts.
Clean any scale off the parts you removed before you put things back together. To test your repair before reassembly, reinstall the circuit board and plug in your coffeemaker. Test all the buttons, switches, and functions. Be careful baking, if your oven doesn't bake as low as 170˚, ask around. My “self clean” button didn't seem to work, so I re-baked for 10 minutes at 180˚. I don't recommend doing this. At that temperature the LCD screen turned black and the glue melted and spread out. Luckily upon cooling the screen returned to its normal color, the glue hardened, and everything turned out fine. I would recommend a longer 15 or 20 minute bake at 170˚ rather than a higher temperature, should you need.
YMMV. Good luck!
P.S. Self clean works fine, full functionality was restored with this fix.
Posted on Nov 22, 2009
Brewed coffee overflowed on to warmer plate. Now water does not heat and flow and warmer plate does not heat up.
Unless it is an expensive brewer, get a new one. The brewer needs the bottom plate to heat in order for it to work at all. Should be imune getting wet though, but sounds like bad heating element.
Oct 11, 2013 | Cuisinart Model DGB-550 Coffeemaker...
The dgb900bcc doas not do anything
1) please test the outlet wall, for properly ground, and repair. put some another device such desk lamp for to see if work.
2) if work, test the power cord for defective.
3) test the main switch for open ,bad contacts, or defective.
4) see if the thermal fuse is open or bad contact fix it.+sensor defective.+heating elements defective.
5) can be the control board if have be defective.
God bless you
Jul 27, 2012 | Cuisinart Coffee Makers & Espresso...
It was working fine grinding coffee beam Ns when it just stopped grinding. I can not get it to grind again.
This model grinder has a 12 to 16 month life expectancy.. I would advise you to buy a different brand such as a Braun which last for years
Feb 13, 2011 | Cuisinart Grind Central DCG-12BC Blades...
Our DGB-700 has stopped grinding the beans. The motor sounds very weak. I have taken it apart and cleaned thoroughly with no good results. Can it be repaired or is it just time to "move on"...
I use Capresso CoffeeTeam model #454 10 cup 50 oz digital coffeemaker burr grinder combination with four grind settings. Now it is more than 5 years old, works every single day without any problem. Capresso has the great customer support. Its price for the refurbished item is compatible with the price of your Cuisinart. I am not sure it is the solution for you but I am very happy with my coffeemaker.
Jan 04, 2011 | Cuisinart Grind Brew DGB700 12Cup Coffee...
My Cuisinart grinder was working one minute and stopped the next. Stopped working, will not do anything. Could the motor have gone out?
Before I would assume it is the motor, I would double check the switch that will not let it run if the cup is not pushed in all the way...
make sure there are no bits of coffe in the way keeping the cup out just a bit. it needs to be seated perfectly for the grinder to run...
If all that checks out then probably either the motor or the switch has gone bad....
If that is the case you might better throw out this one and nuy a new one... there are selling for 20-30 bucks new...not worth spending much time on to fix...
heatman101
Oct 07, 2010 | Cuisinart DCG-12BC Electric Blades Grinder
Power turns on but nothing happens: nothing gets hot, water doesn't run through
The heating element has gone bad... the heating of the water is what makes it go through, so that is why it is not working at all...
heatman101
Aug 15, 2010 | Cuisinart Coffee Makers & Espresso...
My DGB-700BC cuisinart coffee maker grinds beans but then gets stuck and will not continue brew cycle. keeps beeping. please help!!!
We bought our Cuisinart 12 cup grind n brew less than a year ago. Almost as soon as we started using it we began having problems with it hanging up between the grinding and brewing cycles. It would sit and click. I tinkered with it incessantly and usually could, after fiddling long enough with the filter lid, get it to brew, but it was aggravating, to say the least.
When one morning it would NOT work I called Cuisinart and was relieved to hear that there is apparently a problem with some of the filter lids not seating properly. They are sending us a new one. The rep I spoke with told me that if this did not work they would replace the unit, so at least it sounds like their customer service may be on the ball.
So, call Cuisinart for a replacement of your filter lid and see if that solves your problem.
May 12, 2010 | Cuisinart Grind Brew DGB700 12Cup Coffee...
Cuisinart DBM-8 Grinder Automatic Burr Mill stopped grinding
perhaps remove the hopper (top) and inspect to see if a buildup of very fine compacted grounds as accumulated. knock the stuff loose.
Jan 28, 2009 | Cuisinart Supreme Grind DBM-8 Electric...
Grinder not working
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
Sep 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart dgb-500 automatic grind & brew
-Tha Mp3 Doctor
Jun 11, 2008 | Cuisinart DGB-500 Coffee Maker
Cuisinart Grind  Brew DGB700 12Cup Coffee Maker Logo
62 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
