Question about Arcade Toys
I have a 1987 Romstar Top Speed game by Taito. I need to replace the entire steering assembly, i guess that i mean the wheel, the gears, and the chip that picks up the wheel motion. I can't seem to find the original part or a new complete unit to do the job. please help!!!
keemo68
  • 1263 Answers
SOURCE: Need wheel bearing replacement
unfortunately your bearing assembly is a sealed unit and you have to purchase it as a complete part. they do have a way to change out the bearing at a shop, however the labor cost involved would most certainly be alot more than a replacement it's self. I have come across this problem many times and it's not as easy to switch them out as you have been told. i hope this helps. (note) to repalce them on your vehicle if you don't do the work yourself have a small shop do it not a dealer shop. the cost will be alot less. the labor time should be no more than 2 hrs. that is roughly about no more than 120- 150 dollars for the labor . if the place you take it to quotes you way more than that take it somewhere else... good luck please rate this
Posted on Sep 01, 2008
keemo68
  • 1263 Answers
SOURCE: 1996 Dodge Ram 3.9L Pick up Steering Shudder
you could have air in the system. first try an fill the resevoir to a proper level then with engine running turn steering wheel all the way to the left until it squeals, then to the right till it squeals. repeat this several times if this doesn't cure the problem change the pump only I seriously don't that the gearbox is bad. please rate this
Posted on Oct 03, 2008
stormbrewin
  • 426 Answers
SOURCE: replaced power steering hose 1500 chevy pickup
Maybe got an air lock/bubble
Posted on Oct 11, 2008
  • 41 Answers
SOURCE: need to rewire entire jeep
If you want to rewire the vehicle, assuming that you will not be changing any systems, you can usually find complete new wiring harnesses from both the dealer and from aftermarket selllers like Quadratec and JC Witney.  Buying the complete wiring harnesses will be alot cheaper and less time consuming than trying to make them yourself.  These wire assemblies are just a plug and play deal, you disconnect a harness and replace it with the new one.  They may even include some instructions. If you need further assistance with custom wiring or diagnosis, I would recommend getting the service manual for the vehicle from the dealer or used ones from eBay ($30- $100).  The factory service manuals have complete wiring diagrams and schematics as well as full diagnostic information.  These service manuals are NOT like the ones found at your local parts store (Chilton or Haynes).  The factory service manuals are like complete blueprints for a car.
Posted on Dec 19, 2008
SOURCE: replace original steering wheel
im looking for airbags nissan altima 2003
Posted on Jan 07, 2009
I have a 06 cayon and the bearing in the left hand spindle need replace the spindle assembly to me thats the it looks
Well, I guess it comes down to what you are calling a "spindle". The hub and bearing assembly comes out of the steering knukle. Yes, the hub and wheel studs are part of the bearing assembly. It doesn't really have a "spindle" in the old-fashioned sense. Assuming that your Canyon is a 4X4, the hub and bearing assembly comes of like this:
Raise and support the vehicle. Remove the tire and wheel assmbly. Remove the brake caliper assembly and brake pads. Remove the Caliper Bracket from the steering knuckle. Remove the disc brake rotor. Remove the large nut from the end of the drive axle. Disconnect the electrical connector for the wheel speed sensor. Push the drive axle inward to gain access to, and remove the 3 bolts securing the bearing and hub assembly on the inside of the steering knuckle. Beat the S**T out of the bearing and hub assembly to make it come loose from the steering knuckle. (They ommitted this step in the service manual - LOL!)
Reverse steps to install. (it shouldn't be necessary to beat the new bearing though :) )
Apr 27, 2011 | 2005 GMC Canyon
Are the power steering lines connected to the oil lines somehow? Just before my power steering crapped out, I would top up the pump reservoir only to blow white smoke out the tailpipe all the way home. How...
Hi. Your power steering pump hoses are closed looped. They run from the pump assembly to the reservoir.They do not run to any of your oil lines. Now, with that said, i would recommend to inspect your assembly for possible leaks. This is a high pressure setup that will produce leaks during hose or clamp failure. The reservoir can crack as well. This will cause fluid to leaks on the engine block or exhaust manifold, thus, causing the white smoke or burn off affect. Use the procedure below to inspect for possible loose hoses or compromised pump seals and reservoir issues.
Once you have staged your vehicle in a safe place, open the hood and locate your power steering system on your vehicle. The easiest way is to follow the part of the steering column assembly that goes through the firewall. Follow the components connected to the steering column all the way to the wheel assemblies and hoses connected to the power steering pump and reservoir. Attempt to scrub wet and dirty components around the steering system, using shop rags if the leak source is not readily apparent. Now,start the engine, rotating the steering wheel all the way from left to right several times to increase system pressure in the pump and hoses. Turn off the engine and inspect the system from the engine compartment, using a flashlight preferably. In some cases, you might have to wait one or two days for the leak to reveal itself . Next, check around the power steering pump, for possible cracks. If you find fluid around the pump case, the case is damaged and should be replaced. Some pumps are equipped with internal seals that may be replaced when necessary. Also, look around the reservoir and make sure it is in good condition. A cracked reservoir must be replaced as well.
Now, look around all fittings and hoses. A loose fitting cannot contain the high pressure in the system. Tighten clamps using a Phillips or flathead screwdriver or ratchet and socket, depending on the type of fitting or clamp used in your system. Additionally, check along the hoses for cuts. If possible, run your fingers along the length of the hose to find hidden wet spots. A hose leaking somewhere along the middle will have to be replaced. If the gash is very close to the end of the hose, you might be able to cut off the damaged part and reconnect the hose to the component. You will also need to Check the metal lines connecting the steering gear assembly to other components. A ruptured metal line must be replaced.
Lastly; Inspect completely around the rubber boots located between the ends of the steering gear assembly and the arms linking the assembly to the wheels. If fluid is leaking at either end, then the seals at the ends of the steering gear assembly will need to be replaced. If necessary, raise the front end of the vehicle using a floor jack and support it on jack stands or ramps. Once the vehicle is safely supported, inspect the steering gear assembly more closely to see if it is in good or bad condition . Make sure you check all the ares above for possible leaks or loose connections before replacing the entire pump.
Jul 05, 2010 | Toyota 4Runner Cars & Trucks
Sloppy steering,play in steering wheel
Nort really, You have rack and pinion gear, Need to check tie rods, inner and outter, wheel bearings and any linkage in the front end first.
Mar 17, 2010 | 1987 Ford Aerostar
2004 silverado 4x4 2500 left front wheel bearing
  1. Raise and support the vehicle.
  2. Remove or disconnect the following:
    Tire and wheel assembly Caliper and rotor Wheel speed sensor and brake hose mounting bracket bolt from the steering knuckle Electrical connection for the wheel speed sensor Front drive halfshaft assembly on four wheel drive models Hub and bearing assembly mounting bolts Hub and bearing assembly O-ring seal from the steering knuckle bore (2500 series)
  3. Clean and inspect the O-ring seal
To install:
  1. Clean all corrosion or contaminates from the steering knuckle bore and the hub and bearing assembly.
  2. Install the O-ring to the steering knuckle (2500 series).
  3. Lubricate the steering knuckle bore with wheel bearing grease or the equivalent.
  4. Install or connect the following:
    Hub and bearing assembly Hub and bearing assembly mounting bolts. Tighten the bolts to 133 ft. lbs. (180 Nm). Front drive halfshaft assembly on four wheel drive models Electrical connection for the wheel speed sensor Wheel speed sensor and brake hose mounting bracket bolt to the steering knuckle. Tighten to 106 inch lbs. (12 Nm). Rotor Tire and wheel assembly.
You can go to autozone.com and register for free online repair manual with everything you need.
Jan 19, 2010 | 2004 Chevrolet Silverado 2500 Crew Cab
How to change the power steering on 96 ford explorer
Section 11-02C: Steering Gear, Power Rack and Pinion, Explorer 1996 Explorer with Power Rack and Pinion Steering Workshop Manual REMOVAL AND INSTALLATION Steering Gear SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Pitman Arm Puller T64P-3590-F
Removal
  1. Start engine.
  1. Rotate steering wheel from lock-to-lock (entire gear travel). Record n umber of rotations.
  1. Divide the number of rotations by two. This gives the required number of turns to place system in the on-center position.
  1. NOTE: Verify the front wheels and steering wheel are in the straight-ahead position.
    From the lock position, rotate steering wheel the number of turns determined in Step 3. This places the gear in the on-center position.
    Steering Gear, Explorer
  1. NOTE: Do not rotate steering column when intermediate shaft is disconnected or DAMAGE TO CLOCKSPRING will result.
    Remove bolt retaining the lower steering column shaft to the steering gear input shaft.
  1. Disconnect the lower steering column shaft from the steering gear.
  1. Remove stabilizer bar attachment from frame for clearance to remove gear.
  1. Unscrew the quick connect fittings for the power steering pressure hose (3A719) and power steering return hoses (3A713) at the steering gear housing (3548).
    Power Steering Hose Connections
    Item Part Number Description 1 3A674 Power Steering Pump 2 3A719 Power Steering Pressure Hose 3 3F780 Power Steering Cooler and Hose Assembly 4 3504 Steering Gear 5 5005 Frame
  1. Plug ends of fluid lines removed and ports in gear to prevent damage and entry of dirt.
  1. Remove two (2) nuts from P/S cooler.
  1. Remove P/S cooler from vehicle.
  1. Remove and discard the cotter pin retaining the nut to tie rod end (3A130) and remove nut.
  1. Separate tie rod ends from front wheel spindle (3105) using Pitman Arm Puller T64P-3590-F.
  1. Remove the two nuts, bolts, and washer assemblies retaining steering gear (3504) to front crossmember (5019).
  1. Remove steering gear from vehicle. If required, remove steering gear mounting bracket housing insulators (3F640) and steering gear insulators (3C716) from steering gear housing.
    Item Part Number Description 1 N807881-S60 Bolt 2 385935-S36 Washer 3 3F640 Steering Gear Mounting Housing Insulator 4 3504 Steering Gear 5 N800255-S60 Nut 6 5019 Front Crossmember 7 3C716 Steering Gear Insulator
Installation
  1. If removed, install steering gear mounting insulators into the steering gear housing.
  1. Push the steering gear mounting insulator and steering gear insulator in until there is no space between the lip on the insulator and steering gear housing.
  1. Position steering gear on front crossmember. Install nuts, bolts and washers retaining steering gear to front crossmember. Tighten to 128-172 Nm (94-127 lb-ft).
  1. Position power steering cooler onto bolts and install nuts. Tighten nuts to 68-92 Nm (50-68 lb-ft).
  1. NOTE: The fittings design allows the power steering pressure hose and power steering return hose to swivel when properly tightened. Do not attempt to eliminate looseness by overtightening, since this can cause damage to fittings.
    Connect power steering pressure hose and power steering return hose to appropriate ports on steering gear housing. Tighten fittings to 27-34 Nm (20-25 lb-ft).
  1. NOTE: Make sure the tie rod ends (3A131) are seated in the tapered spindle holes to prevent rotation while tightening nut.
    With the steering gear, steering wheel (3600) and wheel (1007) in the on-center position, attach the tie rod end to front wheel spindle and tighten to 56-76 Nm (77-103 lb-ft).
  1. If necessary, advance tie rod nuts to the next slot. Install cotter pins.
  1. NOTE: Verify that no rotation from the on-center position has occurred.
    Position steering column lower intermediate shaft over steering gear input shaft. Outer input shaft dust shield must be in place. Replace pinch bolt and tighten to 41-56 Nm (30-42 lb-ft).
  1. Replace the front wheel and tire assemblies. Refer to Section 04-04 .
  1. Replace wheel covers.
  1. Lower vehicle.
  1. Refill power steering oil reservoir (3A697) with Premium Power Steering Fluid E6AZ-19582-AA or equivalent meeting Ford specification ESW-M2C33-F.
  1. Purge air from steering system. Refer to Section 11-00 . Verify absence of any unusual power steering noise.
  1. Check and adjust toe alignment specifications. Refer to Section 04-00 .
  1. Make sure steering gear operates correctly and is not leaking.
  1. Check and adjust fluid level in power steering oil reservoir.
Jul 10, 2009 | 1998 Mercury Villager
Leaking power steering fluid from steering gear connected to pitman arm can fix with gasket rebuild for steering gear
Ok, in this case, you will need to replace the entire assembly. this is best. replace the power steering pump as well. If the hoses are worn, replace them as well.
Jun 06, 2009 | 1999 Dodge Ram
R&R Steering Wheel Assembly and/or Steering Column Assembly
if you disconnect the battery and let it sit awhile this will disable the airbag.
May 15, 2009 | 1998 Ford Explorer
Toys Logo
Top Arcade Toys Experts
jasbo
jasbo
ray gallant
Demonic-2011
Demonic-2011
Are you an Arcade Toy Expert? Answer questions, earn points and help others
