Question about Garden
Gilson Chain Drive Rotary Tiller Model No.51147A Serial No.2105F1 need an Idler Pulley Assembly Part No.33632 can I get one?
    President:
  • 3,074 Answers
Here you go, Good Luck Tim:
http://cgi.ebay.com/13-435-REPLACES-Idler-Pulley-Assembly-Gilson-33632-/280543748522?pt=LH_DefaultDomain_0&hash=item4151b5e1aa
Posted on Apr 01, 2011
I need a parts manual for a rototiller Gilson 7Hp model 462 42045 with a serial number 920437
Give this a shot. not sure what your after (I know parts manual) but availability is vauge----they do have sections with info of certain items pertaining to your tiller---you may be led to what you need
https://www.google.com/search?q=parts+manual+Gilson+7Hp+model+462+42045+tiller&rlz=1C1NHXL_enUS713US714&oq=parts+manual+Gilson+7Hp+model+462+42045+tiller&aqs=chrome..69i57.15739j0j9&sourceid=chrome&ie=UTF-8
Jun 11, 2017 | Gilson Garden
Idler pulley bracket where can I buy one or is there an alternative to it
you need to post year, make, model and what engine?
also which idler pulley? I'm guessing you're probably looking at the accessories drive belt ("fan belt") idler pulley bracket.
Is this a serpentine belt.
a lot of cars use Idler and or tensioner pulleys on the timing belt/chain. the Idlers often don't have brackets
why are you replacing the bracket? did you break it? or do you just need the pulley? I normally replace both pulleys (idler and tensioner) when replacing either one.
anyways.. need a lot more info to answer your question
Dec 24, 2016 | Cars & Trucks
Gilson roto tiller model 51082
Something in the wheels drive is jammed preventing them from turning. That is why the turning belt starts to smoke when it is turning but cannot unstick the wheels. Need to unstick them for unit to work.
Apr 01, 2016 | WI Gilson Bycast Club Chair
Replacement Idler pulley for Gilson Compact Tiller Model 51095
Is this a press on pully or does it have a thru bolt? if press on is it a splt pully .If it is a split pully it should have 2 threaded holes in the hub where you screw in the back out bolts. These kinda act like a built in gear puller to facliitate removal.Its a easy pleasy 5 minute job.
Jul 15, 2014 | Garden
Timing chain 96 maxima broke
Check your owner's manual for the recommended mileage for replacing your timing chain. Replacement for a Nissan Maxima is 60,000 miles.2 Locate the timing chain. Replace it if the automatic chain adjuster (also known as the tensioner) is damaged or worn.3 Release the pressure in the fuel system, drain the cooling system and disengage the negative battery cable. 4 Undo the upper radiator hose, engine drive belts, power steering pulley and pump with bracket, air duct, passenger front wheel and engine side and undercovers, front exhaust pipe, cylinder head front mounting bracket and head cover, rocker cover, distributor and distributor cap and spark plugs.5 Take off the intake manifold support and move the No. 1 piston at "Top Dead Center" (TDC) of the compression stroke.6 Disconnect the cylinder head front cover, water pump pulley, thermostat housing, upper and lower tensioner and slack side timing chain guide, idler sprocket bolt, camshaft sprocket bolts, sprockets, mounting caps and camshafts. 7 Disengage the cylinder head with the manifolds, idler sprocket shaft, upper timing chain, center crossmember, oil pan and strainer assembly, crankshaft pulley, engine front mount and bracket and the front timing cover. Remove the oil seal and unfasten the timing chain cover, idler and crankshaft sprockets and the oil pump drive spacer. 8 Unfasten the timing chain guide. install Your Timing Chain 1 Grease the oil seal lip with engine oil and place it in the front cover. Verify that the No. 1 piston is at "Top Dead Center" (TDC) of the compression stroke. 2 Reconnect the crankshaft sprocket (marks should point toward the engine's front), oil pump drive spacer and timing chain guide and the lower timing chain. Line up all mating marks.3 Hook up the crankshaft sprocket and pulley, lower timing chain, front cover assembly, engine mount and front mounting bracket, oil strainer and pan assembly and center crossmember.4 Reattach the upper timing chain, idler sprocket (to the back side), cylinder head assembly, idler sprocket bolt and exhaust and intake camshafts. Place the intake camshaft knock pin at 9 o'clock and the exhaust pin at noon. Connect the camshaft bearing caps and distributor brackets and secure all mounting bolts.5 Eliminate any old material from the pan and cylinder block mounting surfaces. Rub on a 3.5 to 4.5mm bead of liquid gasket over the oil pan and cylinder block.6 Attach the upper timing chain to the idler sprockets and secure the cylinder head bolts.7 Refill the cooling system. Hook up the negative battery cable and any other disconnected items. Start the engine and look for leaks.
Oct 14, 2011 | 1996 Nissan Maxima
TILLER WILL START/RUN BUT BLADES DON'T MOVE..TILLER PART DON'T MOVE? MTD21AH413B129287-424
Hello, W/D here.
The motor drives a belt, and the belt drives a pulley that causes a chain to drive the tines (blades). For the belt to drive the tines, an idler pulley has to put tension on the belt. This is moved into position by a lever that pulls the pulley into tension on the belt, and tension is maintained with a spring when the lever is locked into place.
1. Make sure that the tines will rotate with the belt off. If there is difficulty, check for debris holding the tines (roots, etc.). If necessary, remove the cap covering the chain cover inspection port, and with the machine tilted back, observe for proper operation of the chain while moving the tines by hand. Lubricate the chain according to your manual. If your chain is not working properly, disassemble down to the chain case, and inspect the chain and sprockets. Chain is radily at places like Motion Industries, WW Grangier, or a bicycle shop. Often overlooked, check that the pulley set screws are tight, and causing the shaft attached to it to actually rotate. Check the pins and locking cotter pins in the tines, make sure that they are pinned to the shaft.
2. Check the belt. An old belt can stretch to the point where it will no longer work. The "V" belt can also wear down to where insufficient friction can be applied to the driving or the driven pulleys to cause it to rotate.
3. Check the condition of the idler pulley and spring. Make sure that the lever places tension on the belt. It should be somewhat difficult to engage the idler pulley when the belt is new. You may have an adjustor on the idler that will tighten the belt.
Best regards, --W/D-- Please provide feedback for our solutions so that we may continue to improve in helping others. Thanks.
Feb 24, 2011 | Mtd Products Yard Machines 158CC Tiller
I need a manual for a GIL1531A tiller
Hey guys found this though Google images of a tiller. It had a link to this guys site with PDF of an old Montgomery Wards tiller, which shares a lot of the same parts as a Gilson 272 42004 tiller that I have.
Here's the link:
http://499285650937238131-a-1802744773732722657-s-sites.googlegroups.com/site/texgsfiles/files/GIL-1580E_tiller.pdf?attachauth=ANoY7coGFYBBabigFFX6GwZQpDUf9M8hRylBPTSWs03W75yblm4BlmBz5Tivm3kBFSBM7maDCuEI1ALPgoBmpmtI_socNrIhd0MK2mRU6W8D1KqhMTF1Pu5BszBvM6PUVcMds5oa90MxI8XHcFa8r7opkaXo52pkW-KVY53qBQHHHDd-XS3xKlfniltgkU37r8X76R4DbZ2HcWNPz-qCZYQlfrpKHkxOcg%3D%3D&attredirects=0
Oct 08, 2009 | Yard Machines Garden
Broken belt
The web site below sells Gilson belts - you need the part number. If you do not have the part number, maybe if you contact them, they can match the belt to your tiller number.
http://www.psep.biz/store/gilson_tiller_belts.htm
Also, another web store, Jacks small Engines (jackssmallengines.com) states that they carry parts for Gilson, but I did not find Gilson in their directory. You may have to contact them.
One of the web sites mentioned that at some point Gilson was bought by Lawn Boy. If you go to a local Lawn Boy dealer, they may be able to match up a belt.
I have a 1978 WheelHorse tractor. The drive belt for the mowing deck broke. I went to Home Depot, spend a good 1/2 hour measuring belts, and found one that works perfectly. If you go to your local outdoor equipment shop, especially one that sells, repairs tillers, they may be able to match up a belt for you. A belt is a belt is a belt. If you go to a "good old fashioned shop" that will spend the time, they can measure the old belt and hopefully come up with a match.
Good Luck!
Jul 29, 2009 | Garden
Just need to see the order in which the parts go back on the drive assembly for a Ward/Gilson 1575 front tine tiller
which drive assembly do you need info on,the belt drive or the gear box/case ***'y,I have a manual and can send a pic if needed,plus I have microfiche also on most of the Gilson jed1950@earthlink.net
Jul 16, 2009 | Garden
Garden Logo
419 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
