Question about Garmin nuvi 650 GPS Receiver
System comes up ok but does not respond to touchscreen
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 332 Answers
I own a Garmin so I am very familiar with them. The touch screen itself and the software in your unit work in conjunction with each other. I would first go to Garmins website, hook up your unit to your computer and down load any updates they may have for your unit then try your unit again. If it still doesn't work then your probably going to need to contact Garmin to see if they can repair it. If the updates don't work for you then I would think its the touch screen itself that may need replacement.
I hope this helps you out.
Posted on Apr 01, 2011
Touchscreen not responding
Power off and then power it back on. Leave it off for a couple mins then see if that helped
Jul 03, 2014 | HP Photosmart D7260 Printer
Touchscreen does not respond to touch .
CHECK THE FLEX OF UR TOUCHSCREEN IF ITS BROKEN;IF NOT JUST LIFT THE SOCKET AND PLACE IT AGAIN.
Jul 27, 2012 | Handspring PalmOne palm treo 600 Silicone...
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
The touchscreen has stopped responding. Everything else is OK.
Ok, i see your problem. Take a business card and wipe the corners of your screen gently. This should work as unresponsive screes occur when dust is trapped on the screen.Remember, practice this every 3 months.Good Luck :)
Oct 16, 2009 | HP IPAQ hx2790b Pocket PC
Bottom of touch screen (G900 handset) doesn't respond
use the myphoneexplorer free software to run the setup wizard in main menu>settings>general. use the L and R buttons on the software after you connect it via usb inphone mode to your computer to run the wizard and then calibrate the touchscreen... it solved the touchscreen problem for me..
Aug 03, 2009 | Sony Ericsson G900 Smartphone
Try to find how to calibrate the touch screen in the users manual.
May 29, 2009 | Garmin nuvi 250W GPS Receiver
My MC70 work symbol wont respond to my touch screen pen
Does it respond to keyboard entry? If not, check to see if the "lock" icon on the screen is in the locked position. It's real easy to accidentially lock the device. If it is, just click on the lock and confirm that you want to unlock.
The next few can be a problem if the screen is not responding, so you'll need to figure out the keyboard equivalent:
You may also want to check the system settings. I believe there is a setting that will enable you to "turn off" the touch screen function.
Finally, try a touchscreen alignment in the system settings.
Jan 17, 2009 | Symbol MC70
Screen Calibration
I'm a french customer with a Marantz RC5400 wich has a screen LCD broken but the touchscreen is OK
I don't have the fix for your problem but I'm searching for a screen replacement at low cost...
If you always have your Marantz with the touchscreen problem, I'm interested for a deal
Thanks
Dec 06, 2007 | Marantz RC5400 LCD Touchscreen Remote...
Garmin nuvi 650 GPS Receiver Logo
272 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
