Question about HP Pavilion a1320n (882780261747) PC Desktop
What is the maximum size of hard drive my hp pavilion a1320n can use
    President:
  • 1,623 Answers
You can put any size hard disk you want in there as long as its sata
Posted on Apr 01, 2011
Maximum hard disk size for hp a1610n
Based on The Spec's of your System you have a 250gb Hard Drive however the Maximum size will be less then that due to formatting the drive so you can expect that to be like 10% less then 250gb (just a guess) plus a lot of computers come with a restore partition which is usually around 12gb assuming you leave it factory stock.... Your computer by default will set your Hard Drive to the Maximum size... now as far as how big you can install the sky is the Limit your computer is new enough it should except any size Hard Drive available at the store.
Oct 14, 2013 | HP Pavilion Computers & Internet
Tip
Virtual memory settings
Windows XP
1. Click Start, right-click My Computer, and then click Properties.
2. Click the Advanced tab. In the Performance section, click Settings.
3. Click the Advanced tab. In the Virtual memory section, click Change.
4. The hard disk drive that is used for virtual memory will usually be the
5. same disk drive that Windows is installed on. Both the Initial and Maximum settings should be less than the reported Space available on the hard disk drive. The Initial size setting for the virtual memory settings should be approximately 200 MB in size but should be higher than or equal to the recommended paging file size as indicated in the lower section of the screen.
Once the initial size is set, Windows will reserve this amount of space on the hard disk drive for virtual memory and it will not be available to save information on.
The maximum amount allowable can be anything above the Initial size setting, but it is recommended that it be at least twice the Initial size setting
on Apr 27, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Hello I have a HP Pavilion a1320N it is running very slow, so I want to do a full recovery back to the original state, but I did not create a set up disks when I bought it. How can I do a full recovery?
Use an external hard drive to backup your files and do the recovery... or better use the System Restore utility to at least restore it to an old backup date.
Apr 27, 2012 | HP Pavilion a1320n (882780261747) PC...
Can i add an additional hard drive to my hp a1320n desktop computer? I have a hard drive from a computer of mine thats power source/motherboard died out, and i would like to be able to use that hard drive...
Yes it is possible. It depends on the IDE/SATA ports present on the motherboard that how many hard drive/CD drive can be connected to it. Also you can buy an external casing for your old hard drive that will let you connect it with your existing computer using USB port.
Hope this will help...cheers:)
Jan 02, 2011 | HP Pavilion a1320n (882780261747) PC...
When i turn on my HP Pavilion a1320n nothing happens. it sounds as if it is in standby mode and the fan is runing but the monitor never comes on. i can't get it to the initial dell screen where you can...
id check and reseat memory ram first. it should give you a beep sound for error. if nothing, then check video card and hard drive. you can also remove everything (ram, hard drive, cd or dvd rom) then restart and see if it gives a beep error.
https://kb.iu.edu/d/afzy
May 03, 2017 | HP Pavilion Media Center a1320n PC...
Trying to install a new xp install on an HP Pavilion a1320n with a new 1.5 TB drive. XP only seems to recognize it as a 131062 MB drive. Is this an XP problem or a problem with the BIOS or...
Theoreticaly win xp will support 4Tb hard driver (hdd), but, your motherboard need to support this size as well, in your case, in both accoutns you are within limits.
This was theory, now practicality, LBA (Logical Block Address) was originally created as 24bit for ATA/PATA?ATAPI devices, calculated size supported therefore is 137.4GB.
In case of your computer, this motherboard should support 48bit formating and therefore size of 144.000.000GB (144.000TB).
I would suggest following actions, go to this site:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=1818050#N1388
Download newwest BIOS, unfold it to the disk and update BIOS, then use in installation windows xp sp2 or above, windows xp alone do not format properly harddrivers that size.
Another causative agent is how windows create partition and format under NTFS/NTFS5 system. It creats enormous size MBR and reserved "patch" for system files, in your case this is main "loss" of the space.
You can actually "reclaim" heaps of this spce by partitioning, but this crates another problems and you need to investiate which method will be best in your particular case.
Aug 21, 2010 | HP Pavilion a1320n (882780261747) PC...
What is maximum size for hard drive on HP pavilion dv6105us ?
There is no maximum size hard drive for the DV series laptop, especially if you are running Vista or Windows 7. If you are running XP, make sure that the operating system has service pack 3 in it and you can run any capacity drive you wish.
Jun 27, 2010 | HP Pavilion dv6105us Notebook
Pc working slowly with 2gb ram
Step 1:-
Go to
Start > Run>
type "msconfig" >uncheck all except ur sound & display drivers then click Apply > Ok
Step 2 :-
Right click on My Computer Then select advance tab
>performance settings>select advance>click Change > click on custom size then double the values then click ok
And Ur Done
May 23, 2009 | HP Pavilion Media Center a1320n PC...
HP Pavilion a1320n (882780261747) PC Desktop Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
