Question about Sony Audio Players & Recorders
Right channel has a constant 5 to 8 volts running through it
    Genius:
  • 1,175 Answers
HI...
The transistors on that channel have failed.
What model number is it?
Posted on Apr 05, 2011
Need color code for 16 pin connector, power plug
Pin Number Wire Color Function 1 White Left Front Positive 2 Green Left Rear Positive 3 Violet Right Rear Positive 4 Grey Right Front Positive 5 Blue/White Amplifier Remote 6 Blue Antenna Remote 7 Red Accessory 12 Volts 8 Black Ground 9 White/Black Left Front Negative 10 Green/Black Left Rear Negative 11 Violet/Black Right Rear Negative 12 Grey/Black Right Front Negative 13 Sky Blue Telephone Mute 14 Orange/White Illumination 15 Not Used Not Used 16 Yellow Constant 12 Volts
Sep 18, 2015 | JVC KW-AVX706 Car DVD Player
03 chevy impala how to fix pocode 1635 is this the computer are what is it
DTC P1635
The powertrain control module (PCM) provides 5 volts to the following sensors:
The manifold absolute pressure (MAP) sensor
The exhaust gas recirculation (EGR) valve
The fuel tank pressure (FTP) sensor
The throttle position (TP) sensor
These 5-volt reference circuits are independent of each other outside the PCM, but are bussed together inside the PCM. Therefore a circuit condition on one sensor 5-volt reference circuit may affect the other sensor 5-volt reference circuits. The PCM monitors the voltage on the 5-volt reference circuit. If the PCM detects that the voltage is out of tolerance, DTC P1635 sets.
Diagnostic Aids
If any sensor using a 5-volt bias voltage, such as the intake air temperature (IAT) sensor or fuel sensor, is shorted to voltage, DTC P1639 may set in addition to DTC P1635.
For an intermittent condition, refer to Intermittent Conditions .
Does the vehicle start an run ?
Jun 11, 2015 | 2003 Chevrolet Impala
Pitcure and usb problem
usb is shorting out the 5 volts. as its only 2 months old would take it back to the place you bought it and get a replacement.
Mar 02, 2018 | Philips 27PT81S 27" TV
Need the wiring diagram for the stereo in a 1986 f-250
  1. Constant 12 Volts - Light Green
  2. Switched 12 Volts - Yellow/Black
  3. Ground - Chassis
  4. Illumination - Blue/Brown
  5. Antenna - Right Front
  6. Front Speakers - 5 1/4" Doors
  7. Left Front (positive) - Green
  8. Left Front (negative) - Black/White
  9. Right Front - (positive) - White/Red
  10. Right Front - (negative) - Black/White
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 15, 2011 | 1986 Ford F 250
Need radio cd wiring diagram for 2005 jeep grand chrokee
120706502.jpg FUNCTION PIN WIRE COLOR Accessory 12 Volt SEE NOTE ¹ Constant 12 Volt 1,12 RD/OG (2X) Chassis Ground 11,22 BK (2X) Power Antenna Remote Illumination Dimmer FUSE VALUE FUSE LABEL FUSEBOX LOCATION 20 AMP #28 DRIVER'S SIDE UNDER HOOD ¹ The receiver does not have an Accessory 12 Volt lead, it is triggered by the data lines in pins #5 and #6. When installing an aftermarket stereo, an Accessory 12 Volt lead must be run to the fusebox to a switched power lead.
² If equipped with "Hands-Free" cellular phone system.
The dash speakers are wired in parallel with the front door speakers.
Left Front Spkr + 10 D.GN Left Front Spkr - 9 D.GN/BN Right Front Spkr + 7 GY Right Front Spkr - 8 GY/BN Left Rear Spkr + 18 D.GN/D.BU Left Rear Spkr - 19 D.GN/VT Right Rear Spkr + 21 GY/D.BU Right Rear Spkr - 20 GY/TN Hands-Free Audio ² 4
16
17 D.GN/OG
D.GN/YW
D.GN Data Lines 5
6 WT/OG ¹
WT ¹ DO NOT USE THESE WIRES!
Sep 25, 2011 | Car Audio & Video
I need a wiring diagram for this stereo
FOR 16-PIN HARNESS
Pin Number Wire Color Function 1 White Left Front (+) 2 Green Left Rear (+) 3 Violet Right Rear (+) 4 Grey Right Front (+) 5 Blue/White Amplifier Remote 6 Blue Antenna Remote 7 Red Accessory 12 Volts 8 Black Ground 9 White/Black Left Front (-) 10 Green/Black Left Rear (-) 11 Violet/Black Right Rear (-) 12 Grey/Black Right Front (-) 13 Sky Blue Telephone Mute 14 Orange/White Illumination 15 Not Used Not Used 16 Yellow Constant 12 Volts
FOR 9-PIN HARNESS
Pin Number Wire Color Function 1 Not Used Not Used 2 Black Ground 3 Grey Right Positive 4 Grey/Black Right Negative 5 Blue/White Amplifier Remote 6 Red 12 Volt Switched 7 Yellow 12 Volt Constant 8 White Left Positive 9 White/Black Left Negative
MAY THIS HELP YOU
Jul 04, 2009 | Sony CDX-GT210 CD Player
My amplifier keep clipping
start with the lowest settings on all the adjustment knobs and turn your radio up to about 3/4 of the volume and go from there
Mar 20, 2009 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
2001 Buick LeSaber
you have a voltage drop problem probably a coroded wire if you can open wire harness and do voltage checks down the wire until you find the bad spot and repair or you can run a bypass wire
Sep 14, 2008 | 2001 Buick LeSabre
Amplifier main channel non operational.
first pull out the power transistor then biased the output terminal. base,emitter have dc volts .4 to .5 collector to emitter have full voltage. if this voltage are in ur pre amp buy new trasistor
Sep 09, 2008 | Audio Players & Recorders
TXN2771HF (5yr old) - Front Panel a/o Remote Issue
Sounds like the 5 volt supply is low, Look for the 5 volt regulator, Measure you can go directly to the sensor 3 pins 1 will be 0 volts one will have 5 volts the other is usually a fluctuating 3-5 volts if 1 pin has to have 5 volts if it is low check capacitors around the 5 volt regulator probably 47uf to 100uf look for rusty look on the leads. If you see it change it! check these voltages with set turned off ( standby ) do not attempt if you dont know what your doing. Good luck. The reason it works when it is on is because there is a run 5 volt supplement.
Jun 20, 2008 | Samsung TXN2771HF 27" TV
23 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
