Turned on ok. I set it for a high warm heavy duty load. Pressed start. Started filling but kept stopping in jerks and stopped with a lot of beeping. Cycle lights are lit in a pattern of: off off on off on off on on. Plesae help
  • 11 more comments
  • chantelmaree Apr 02, 2011
    It's a Kelvinator Pride 5.5 Smart Drive 9 by Fisher and Paykel.
    The beeping seems to be coming from up by the control panel.
    It partially filled with water. It won't drain. It won't fill.
    It's the agitator doesn't appear to be turning like it's supposed to when it's trying to fill.
    I turned it off and un-plugged it for 10 minutes before posting my first email.
    It lit up ok and started to fill again then stopped in the same manner.
    I tried to turn it off with the stop button on the machine but it turned itself back on with the same lights lit up across the cycle bar. No other lights are lit.
    I have removed the washing and turned it off at the power again to wait for your advice.
    Fisher and Paykel.
    It seems the agitator isn't turning like it's supposed to
    I turned it off and unplugged it for 10 minutes before posting my first
    email.
    for your advice.
    Ok I did that.
    It's now beeping in a steady piercing tone with the same lights lit in the wash progress bar.
    two lights off, one on, one off, one on, one off two on.
    Pressed the advance button to see if it would stop the beeping. Gave three rapid beeps and stopped beeping. Lights still lit.
    Ok I did that.
    Here's a pic of which lights are lit.
    Did the pic come through ok?
    Did it help with the diagnostics?
    I'm really appreciating your help.
    Hi Daniel
    It wasn't suds because there were no suds present when the error occurred.
    There is nothing blocking the clutch to stop it from engaging.
    Which hose are you referring to? I couldn't see any that were crushed.
    Have you got a diagram that you can send me so I know where to look please.
    Kind regards
    Chantel
    Hi Daniel
    I couldn't find a way to access the end of the tube attached to the bowl but when I detached and blew through the end from under the control panel I could hear bobbles that sounded like they were coming out under water.
    How can I access the bottom half of the tube to test it properly and and what is the next step please.
    Kind regards
    Chantel
    And how do I find the pressure switch - what does it look like?
    Kind regards
    Chantel
    Thank you heaps! My washing machine is now working. The balance switch was jammed to one side.
    You're awesome! Thank you. Thank you. :)
    Fantastic advice. My machine is now working perfectly. Thank you.
    Very helpful solution. I am one very happy customer.
    Hi Daniel_S
    Another tech posted a different answer which has led me to a correct fix for my machine.
    The light pattern indicated that the pressure balance switch was jammed.
    Thank you for all your help.
    Chantel
    President:
  • 1,554 Answers
The flashing of the 3rd, 5th, 7th and 8th LEDs from left to right indicates fault code 43 and it means the Motor Controller Module has detected that the out of balance switch is permanently tripped. The out of balance switch lever may have been stuck in the open position or the harness connecting it and the Motor Controller Module is disconnected.
Move the basket assembly as far as it can go towards the right rear corner of the cabinet several times to possibly lodge the lever back into close position. Raise the top cover then locate the out of balance switch at the right hand corner of the cabinet then make sure the lever is hanging freely. Disconnect the out of balance switch wire harness, if the lever is properly hanging but the same LEDs are still flashing (Fault Code 43), then join the terminals together to bypass the switch.
Reconnect power then start the machine. Replace the out of balance (OOB) switch if the machine works fine with the switch bypassed. If not, check the continuity of the OOB switch wire harness and make sure it is snugly connected to the Motor Controller Module. The problem is in the Motor Controller Module if the wire harness is intact and snugly connected but the machine still doesn't work even with the OOB switch bypassed. Replace the Motor Controller Module if that is the case.
Let us know if you need further advice. Please accept the solution should you find it helpful or informative. Accepting the solution will not stop you from communicating with the expert. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Apr 02, 2011
  • 4,323 Answers
Hi
It seems like control board has gone bad and should be replaced. However, please post back with the manufacturers name & model no. and where is this beep coming from...from the control or from the bottom of the washer. Have you already tried to unplug it and plug it back? What about the water...did that drain or it never filled with water? Do you hear any other sounds apart from the beep sound? ...please post back for further assistance.
Daniel
Posted on Apr 01, 2011
  • 5 more comments
  • Daniel Scott
    Daniel Scott Apr 02, 2011
    The washer is detecting error while it enters wash cycle. You can try and enter the diagnostic mode & check if it resolves the issue. If it doesn't then you would need check for the fault codes.
    To enter Diagnostic Mode turn the power on at the power point and off at the console. Press and hold the WASH TEMPERATURE DOWN then press the POWER button. Smartdrive will give 2 short beeps. Phase 1 & 2 Only press ADVANCE button once. From Diagnostic mode press the SPIN buttons until the HOLD and SLOW SPIN LEDs are on, (Diagnostic mode level 3). The WASH PROGRESS LEDs will now display the fault code.
  • Daniel Scott
    what two lights are lit and which is on which is off...please tell me so that I can tell you what part is causing this issue
  • Daniel Scott
  • Daniel Scott
    Hi
    From the light pattern you have posted, it seems to be error code 40. While carrying out a bowl check, the Display module has found that the bowl is not engaged even though the pressure sensor indicates that the bowl is empty. The Motor Controller continues to check for 2 minutes after which time the display this fault. If restart is on this fault can take up to 4 hours to diagnose. The first two areas to check are the clutch and the pressure tube. If these two appear correct, then the fault could be in the pressure transducer in the Motor Controller.
    Primarily it is caused by too many Suds, too much detergent has been used and to resolve this you would need toRestart product when suds have disappeared, or select a deep rinse option. However, if this was not caused by suds then it is a Mechanical failure--
    1. Check that there are no clothes or other foreign objects preventing the clutch from reengaging.
    2. Next check that the pressure tube has not come off and that it is not kinked.
    Hope this helps.... Please post back if you need more information.
    Daniel
  • Daniel Scott
    Hi
    To access pressure tube remove the control panel (2 screws on the back) and lift the deck (2 screws under lid) and you will see a clear tube that hooks to the board and the tub both ends just have a little clamp. Remove it and unhook both ends, unplug the washer and don't touch any wires. Blow through one end while you cover the other end. If you feel any air leaking then tube is the problem, if not then pressure switch is bad and you need to replace it.
    Hope this helps... Please post back if you need more information.
    Daniel
  • Daniel Scott
    Hi Chantel
    Please let me know the complete model# of your fisher and paykel washer.
    Daniel
  • Daniel Scott
    Daniel Scott Apr 03, 2011
    Good to know Chantel that your issue is resolved. Let me know if you need any other information.
    Daniel
Water will not stop when level is reached but starts next cycle
If the water will stop when you turn the washer off then the problem is the water level switch. It's a switch connected to a hose which goes between the inner and outer tub. You can blow on it and the water should cut off. The filling water puts pressure on the switch with the air in the hose.
If the water doesn't stop when you cut the washer off then the water inlet valve is probably stuck open. The water supply hoses on the back connect to the valves.
Aug 22, 2009 | Washing Machines
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
Timer stops at the end of wash cycle, won't began drain cycle
if it fills and agitates but stops at the drain/spin portion, it sounds like you have a problem with the lid switch. if it thinks the lid is opne, it will not drain or spin.
Dec 29, 2008 | Kenmore Washing Machines
Maytag heavy duty top loading washing machine stopped and won't restart
remove console screws behind timer is lid switch if you have a volt/ohm meter with washer disconnected ckd switch operation also there is a fuse on same assembly ck it
Aug 17, 2008 | Washing Machines
Kenmore washer machine heavy duty 70 series
most likely a water pressure issue try adj shut off valve off slowly until noise stops if water flow not enough ckd fill screens in back of valve for sediment and trash
Apr 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore heavy duty washing machine 70 series
The most likely cause for water fill temperature problems is the solenoid has burned out, usually cold first, it gets used more. Not a repairable item , easy to replace
Dec 30, 2007 | Kenmore 24032\24036 Top Load Washer
Washer stopped during cycle
cleanlaundry If your washer is less then a year old do nothing and call the manufacturer ASAP. It is under warranty for one year. Gendos...post back
Mar 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
