Question about JVC Televison & Video
JVC AV48P575 Was watching and popped went out won't come back on, just clicks. can't find any shorts in it. Diodes all okay and horizontal transistors check fine, no shorted components that I can find. Any Ideas? Larry @ Central Tv
  • 556 Answers
SOURCE: tv dead
no problem
replace by same number.
but remember before you replace check the following.
  1. check for normal output from power supply.
  2. check components connected to flyback transformer.like capacitors & diodes.
  3. check for print short.
  4. while replacing h/output be careful to check heat sink compound & mica sheet normal.
  5. put on the set
  6. if still it blows then flyback transformer is faulty.
  7. hope this will help.
  8. good luck.
Posted on Oct 12, 2007
  • 45 Answers
SOURCE: HOW DO I FIX TV SET AMC MODEL 1417 CANNOT POWER ON
I would check your caps first, but usually the power supply is bad when things don't power up.
Good luck
Posted on Mar 31, 2008
scott201201
  • 170 Answers
SOURCE: Horizontal output transistor failure
check b+ comming from p/s. also check for blue flat caps in line with h-output circuit. if blown out the side. remove them from circuit. also might have a HVT goin bad. I believe this is also the model that might have a mod for h-out running too hott that requires adding a resister in the h-drive circuit. also try a heavier duty h-output.
Posted on Apr 09, 2008
Slinteriors
  • 8617 Answers
SOURCE: flyback xfrm # for model 60gw948
Your flyback number is RCA 239111 the flyback is available at the following link and they provide free tech support to help you with the instalation and repair of your set. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 08, 2008
SOURCE: Hitachi will not show picture or sound
look in back fo tv on curcit board left side there should be two regular 125v 1.5 amp fuses see if they are black or wire in side is broken
Posted on Jun 02, 2008
I have a 55 inch JVC tv,today the screen went black but still have sound, also the buttons on the back wont work, but the channel down button turns it on and off? What is wrong with it?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary..
Jan 15, 2017 | JVC Televison & Video
Lt 50a330 jvc
I was watching my tv model LT-50a330 JVC and it made two popping noises and the screen went balck but the green power light stayed on. I unplugged it and could smell something bad like a short. I havnt tried to turn it back on, does this mean I need a new tv, it's not even two yrs old.
Aug 02, 2013 | Hitachi L42A403 42 in. LCD HDTV
My jvc av48p575 just turnt itself off and now doesnt turn on when you plug it in the blue power light comes on for a second and thats it....any solutions?
I f blue power light comes on and just blinks that is a short and if so I can tell you how and where to look to the problem---also if this happens do you hear a high pitched sound?
Usually in this set if a short blue light comes on and constantly blinks.
Let me know more
Apr 08, 2012 | JVC Televison & Video
Sony trinitron KV-32S26 While watching the tv it went POP and the picture went pop. Is the picture tube shot?
not really..maybe an overloading of the secondary power supply could create this problem..check first the horizontal stage circuit for shorted component..before suspecting the picture tube
Jul 17, 2011 | Sony Televison & Video
No sound JVC tv Model # AV48P575
You will have to use the control buttons on the front and navigate to personal pref. and restore that to normal. You may have to re do the initial set up. Be patient and give a whirl. Let me know......
Feb 14, 2009 | JVC AV-48P575 48" Rear Projection...
Tv shutting off timer light blinking
Your TV is in the protection mode. First, locate the horizontal output transistor. This is found very close to, or next to, the horizontal output transformer (also known as the flyback). The flyback should be on an aluminum heat sink, or on the side of the metal chassis. Disconnect or unsolder two of the three legs of the transistor. Measure it with your meter, or plug in the set with the light bulb attached across the fuse.
If the transistor is shorted, or the light bulb doesn’t glow bright anymore, replace the transistor and plug back in. If the light bulb glows bright again, you must replace both the flyback and horizontal output transistor simultaneously. In some cases this will fix the set, but sometimes there are multiple problems with a set.
Go to where the flyback is, and start measuring the diodes and capacitors on the flyback itself. If you don't find any shorts there, it could be a shorted vertical output IC, a shorted sound IC, a shorted disc capacitor in the Hi Voltage/sweep circuit, or in rare cases, a shorted capacitor or tuner.Feel free to ask and post whatever the result of your troubleshooting..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 30, 2008 | JVC AV-27D303 27" TV
Jvc tv
You need to check the horizontal output transistor first for a short,ift he transistor is good check the diodes and low value resistors of the secondary of the flyback(output trasformer),if all those are ok check the crt board,it has low value resistor for the g2 voltage,if ok you need to go back to power supply and check for a short from each one of the diodes to ground for a posiblwe short.Be careful when measuring voltages and use the correct ground.
Oct 01, 2006 | JVC AV-36F702 36" TV
Horizontal Lines
The unit most likely has a short in the horizontal section and would require repair by a service center. Go here to find a JVC repair center in your area http://maps.jvc.com/cAscList/
Sep 18, 2006 | JVC AV-56WP74 56" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
